Help choose M.2 Key E Wifi card
2,731 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) RTX A2000
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Greetings all,
I am in a bit of a pickle. I need to choose a wifi card type E for motherboard: Asrock B760M Pro RS/D4. Here is the QVL list on Asrock's support page:
I am not much of a "network" person, but as far as I get it: CNVio / CNVio2 are not backwards compatible. Yet both are listed.
Which card would you pick? I see "Killer" I think it must be good, yes?? :)
202 (0.03/day)
Switzerland
Processor Intel i5 13600K
Motherboard MSI MPG Z790 CARBON WIFI
Cooling Corsair Nautilus 360
Memory Kingston Fury Renegade DDR5 32GB 6400MHz
Video Card(s) ASUS TUF RX7900XT OC 20GB
Storage Western Digital WD850X 2TB
Display(s) Dell G3223D
Case Fractal Design Meshify XL
Audio Device(s) Creative X3
Power Supply Corsair HX1000i
Not an expert as well on "network" but I would suggest an AX210.
The "killer" models are simply the AX with extra features in software and very minor differences I believe.
Unless you have specific needs, you won't notice much a difference in daily normal use.
7,671 (5.04/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
My laptop has the Killer AX1650x, works well I suppose. Never really had any issues with it. I would do some searching and see if the Intel BE200 WiFi 7 card works though. Probably will.
2,731 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
No specific needs, I mainly use the BT for some MS mice I have, headset and transferring files from the phone. The WiFi is backup only as the PC uses LAN connection.
That might as well be my choice. I saw it on Aliexpress and the price is very manageable ~€24 or so. Card is sorted, now off to find antennae. :)
18,153 (2.45/day)
Check which ones have issues, as several Intel solutions have various issues, many aren't working well with some Broadcom WiFi chips in routers, as an example.
Avoid WiFi 7 for now, as there are loads of extra issues with those.
7,671 (5.04/day)
São Paulo, Brazil
First I'm hearing of this? My router is an old Wi-FI 5 (ASUS RT-AC68U), but I haven't had issues with the BE200 yet. What's up? :)
3,443 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Greetings all,
I got this one for my ASRock motherboard and it's been working fine with Intel WiFi & BT drivers ver23.40. If needed you don't have to use the backplate and can take out the antenna ports to mount if you already have built in motherboard i/o panel holes for antenna ports. I didn't want to take my motherboard apart (lazy) and just used it as pictured.
AX210NGW DTK WiFi Card WiFi 6E Supports 6GHz, 2230, 2x2 AX+BT 5.3+Tri-Band, Includes RF Cable (11 inch), 5dBi High Gain Antennas and Low-Profile Brackets​
https://www.amazon.com/dp/B088NHCX46
1,616 (2.13/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
Perfect, added to my Deskmini x300
AX210​
18,153 (2.45/day)
That might be why, as people appear to be having problems with the BE cards with WiFi 7 routers.
The Broadcom thing was more a general Intel WiFi issue that's been known for years.
Solaris17
Super Dainty Moderator
27,371 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
My be200 card is a nightmare I’m on number 2 for JUST Bluetooth and it needs to be reset all the time. Even ran Linux for awhile and it was the same deal. As of late I have considered a third times the charm and simply going with another chipset all together.
931 (4.48/day)
7,671 (5.04/day)
São Paulo, Brazil
Dang. I gotta look into it, if possible might swap it out when I get around my rebuild (when/if my 5090 arrives, given the situation).
9,816 (3.47/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The biggest issue with WIFI 7 is it does not work with Windows 10.
