Help Choosing GPU/CPU
JoshL
5 (1.25/day)
I am building a new computer and I don't know if I should go with a R7 7800x3d and Rx 7800xt or r5 7600x and Rx 8800xt when it releases. I mainly play Fortnite and call of duty and I have a 165hz monitor. The motherboard I went with is the MSI x670e. Thanks for the help
71 (0.10/day)
Processor Ryzen 7 9800x3d
Motherboard Asrock X870E NOVA wifi
Cooling Noctua NH-D15 g2 LBC
Memory Gskill Trident Z Neo DDR5 6000 2x32GB
Video Card(s) Inno3d 4070 TI
Storage 4 TB SSD Samsung 990 Pro + 2 TB SSD Samsung 980 pro + Toshiba 18TB
Display(s) MSI MAG274QRF-QD
Case Antec Flux Pro
Audio Device(s) Creative Soundblaster AE-9
Mouse Razer Basilisk V3
Keyboard Razer Blackwidow V3
I guess its a question of budget, so go for 7600x with 8800xt, its for gaming so GPU will have a bigger impact and the 7600x is still pretty good, but you could get a 5700x3d for the same price which will give you more performance.
JoshL
5 (1.25/day)
I would have gone with the 5800x3d it's just I wanted to get on am5 for longevity. Thanks
437 (0.91/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
Are you playing at 1080p or 1440p?
Either way, I'm pretty sure 8800xt won't be bottlenecked by 7600x at 1080p, so that'd likely be the way to go. If you're at 1440p, that's definitely the way to go.
2,094 (0.53/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
R7 7800x3d now and when the 8800xt releases then that. Then upgrade again when AM5 will become an EOL platform with new and better components
2,033 (0.63/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Wait for the drastic price drop a few months after release on new AMD cpu and gpu.
