Help fixing fake 7670 4GB from ebay back to 1GB
164 (0.13/day)
System Name HAL
Processor AMD Ryzen 3700x
Motherboard ASRock B450 Pro4
Cooling AORUS Liquid 240
Memory 32GB Teamgroup 3200mhz
Video Card(s) EVGA 2060 GTX
I have one of the "4GB Radeon 7670" cards sold on ebay. Obviously , these cards are fake, as there was never a 4GB model of this card. The card works in some apps, right up until one expects it to actually have the 4gb it reports.
I've determined the one I have to be a 7670M chip, as most others are. The RAM on it seems different, but if my math is correct, is still 1GB total. It has 4x SK Hynix H5GQ2H24AFR-T2C chips on it.
I have access to dos atiflash currently, and have a chip programmer on the way I hope will help me fix this card and a 1050ti/550ti I have. The fake 1050ti has several corrected bios files here, but I haven't found a corrected one for this 7670M.
The bios file is attached. Can any of the gurus here edit it to report 1GB, or point me to the relevant bits in a hex editor so I can do it myself? Thanks in advance for any assistance.
The bios has been uploaded here.
FreedomEclipse
~Technological Technocrat~
24,073 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Can we get a picture of the card with the cooler removed??
8,297 (3.93/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
With these fakes you usually need to remove the cooler and clean the goop off the die so that you can read the die markings.
Knowing which silicon narrows it down to a handful of cards, and then the type and number of VRAM packages gets you even closer. At that point you have a shortlist of BIOSes to try and if you're lucky there's one with the right display outputs that will work with your fake card.
With Nvidia it's easy - it's 99.9% of the time a GTS450.
With AMD it could be one of many things, so pictures of the board, where the experts here (I'm not one of them) can read the GPU die markings and the labels on the VRAM packages really are required.
164 (0.13/day)
System Name HAL
I'm somewhat puzzled by the responses here of "take pictures" and "remove the cooler to see die markings". I did that already, and had hoped including the relevant information in the OP would save some time.
Unlike the nvidia cards, where it's truly a rebrand of another card, these cards seem to be custom made. They've taken a mobility chip and put it on a pcie card. I suspect trying to fix the existing bios would be easier than finding one that matches, because from what I can tell, there isn't anything that matches this.
It's a Radeon 7670M chip (p/n amd 216-0833000) with 4x SK Hynix H5GQ2H24AFR-T2C VRAM chips.
Think I may have found why this doesn't match up with any actual 7670 boards...
Maybe this is really a firepro v4900?
2,715 (0.58/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
If you know what the card is, what help do you need.
164 (0.13/day)
System Name HAL
Copy and pasted from the OP, "The bios file is attached. Can any of the gurus here edit it to report 1GB, or point me to the relevant bits in a hex editor so I can do it myself? Thanks in advance for any assistance."
I know what the chips are. The card itself appears to be something that never existed in a retail format. So, as originally asked, need help editing the bios to report 1gb.
Seems like this may not be the place to look for assistance after all. No one actually read the post before replying. :/
8,297 (3.93/day)
Case Veddha T2
Mouse MX Anywhere 2
You said the RAM on it seems different, so it's not a 7670M - and that's exactly why @FreedomEclipse and I asked for more info.
7670M refers to the combination of die, disabled units within that die, and VRAM type/speed/quantity. There will be multiple options of 7670M BIOS for various clock/power/RAM configurations but even if you match all of those things you have to get a BIOS that (partially) matches the display outputs you have on your card too. That's why the experienced people here will want to know the markings around the die and the VRAM so that they can look up the exact RAM type/speed/quantity.
I don't think the fake BIOS is much use as that will basically cause a bluescreen when the driver tries to use VRAM that isn't physically present on the fake card. Some people here may be willing to edit your BIOS but until that happens you might as well try existing BIOSes instead. I'm not a BIOS editor but it's not a trivial task, and I think it's doubly difficult if you don't have the card in hand. Blind edits can go back and forth several times before arriving at a set of edits that works properly.
Could be; It matches the die config and RAM type/quant/speed you posted. If you can find a BIOS that matches the video outputs of your fake then try it.
You've already made a backup of the original BIOS so at this point you've got nothing to lose, assuming you have a second card or IGP to fall back on and let you restore a working BIOS to the card.
2,715 (0.58/day)
Mouse Logitech m705
The issue is that this card is a mobile version and its at least 10yrs old and very few people know how to edit these types of files.
And a little patience really helps.
164 (0.13/day)
System Name HAL
Ok, so for anyone else who comes across this looking for a fix...
I bought a $8 CH341A bios programmer to test this thing.
The card is a custom card. There is no direct equivalent for it.
The BIOS they used for it is a dump of a VTX3D HD6570 , which was a GDDR3 card. They added SKHynix GDDR5 memory registers. Flashing the original BIOS doesn't work.
OK so I've used a hex editor a couple times before.. I can fix this.
Compare all the bits that have changed. Easier to edit the amount of RAM in their existing BIOS than to add memory support for the original.
Trial and error time. Get it right on the second flash. Reports 1GB to windows. Time to have a beer and run Furmark for a few hours.
Here's the fixed BIOS I created.
Note: My VGA & HDMI ports work, but my DVI doesn't. It didn't before I messed with, either. Possibly a bad port on mine, or possibly DVI just doesn't work on these things. I don't care enough to really fool with it.
1,891 (1.43/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
He he ...nice job mate!
Congratulations!
42,269 (6.64/day)
Use it as a spare test gpu...
164 (0.13/day)
System Name HAL
I've attached a few pictures here for anyone that comes across this thread later. Pics of the card, the type of ram on it, and GPU-Z showing it now being reported correctly.
42,269 (6.64/day)
Looks like a GA hsf
How many ram chips are on the card front to back?
That card is reminiscent of this
