Help Flash MI50 to Radeon VII Pro
Outhawk
3 (0.17/day)
Hello together,
i got an MI50 16GB 0x66A1 and wanted to flash it to a Radeon VII Pro 16GB Bios 016.004.000.064.015319.
My first try was with the 3.31 Version, it detected the card but flashing didnt work
Second try with the 5.0 Version same problem... but now when i check the Informations amdvbflash shows me Radeoan VII Pro/ MI50 32GB and the 3.31 Version cant detect the card again.
I also tryed to reflash it to the original bios but dont work.
Any ideas or did i already killed the card?
At the first try i changed an entry in the asus bios that win 10 can detected the card but not sure anymore what exactly it been.^^
633 (1.76/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
From what I understand about these cards, it's possible to flash a Radeon VII ROM onto them but they already don't want to POST when slotted into consumer mainboards and then no longer work in Windows. You may need a programmer to write the vBIOS.
Outhawk
3 (0.17/day)
Im 100% sure some smart guys already did that and when it been just for fun. With the China Cards it should be work easy just the orignial is a bit more difficult. Maybe i was just to stupid and did something wrong. Ah and at the bios i guess had to activate the 4g decoding correct?
7,051 (4.82/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
Mmm, I never tried crossflashing when I had the Radeon VII because it didn't have dual BIOS support - thus avoiding the specific problem you ran into. You'll probably need to reflash the VBIOS with a hardware programmer if you cannot reverse it with amdvbflash anymore.
I know the Vega Frontier Edition will flash into WX 9100 and work pretty much flawlessly (of course half DP ports are available since it only has 3 full size instead of 6 mini, no genlock connector is present, HDMI and GPU tach lights don't work) - but no clue about VII into Pro VII or MI50, vice-versa.
1,009 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
I don't know if the "real" MI50's can be flashed or at least flashed easily. Something about having two(/three?) bios' and it running parity & integrity checks on power up & boot.
AFAIK only the Chinese MI50/Radeon VII can be flashed with Radeon VII/ Pro VII bios'.
42,698 (6.68/day)
@damric this i believe is your area
1,682 (0.31/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
42,698 (6.68/day)
Unfortunately not. I had the MI25, and got help from @DR4G00N and a few others.
I agree with @Dr. Dro probably going to need an spi flasher.
Now that i think about it amdvbflash works on RDNA/GCN/VLIW, not CDNA.
1,682 (0.31/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
2,401 (1.15/day)
Olympia, WA
System Name Sleepy Painter
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
MI50 is 'Vega II'. I've had success on MI25s using your Polaris flashing guide (IIRC, the older version was key)
MI50 is Vega though right?
@LabRat 891 dunno how busy you are but you might also be helpful.
Correct.
Vega (and other) cards like to go into some sort of safe mode after bad boots or crashing. I do not know the exact circumstances, but OP might have luck getting the card 'come back' after some hard power cycling while installed in the system.
I'd pedantically compare the PCBs, but The Pro VII vBIOS is what I'd have looked towards (in OP's position).
You seem to be correct though, going off reddit ( :laugh: )
https://www.reddit.com/r/Amd/comments/16oiecw
42,698 (6.68/day)
I was thinking about vega being an extension of gcn
Correct.
Ok glad it was successful, I just got tired of repeating the commands over and over to people to flash correctly.
3.15-5.0*** people always forget to install the driver which so happens to remove write protection on the gpu so the firmware can be flashed...
Outhawk
3 (0.17/day)
Thank you all for answering! Polaris didnt work because the bios file isnt supported...so no way for a noob to flashing it right?
guess i did it correctly... driver circle-save bios-unlock-try to flash
