System Name | Compy 386 |
Processor | 7800X3D |
Motherboard | Asus |
Cooling | Air for now..... |
Memory | 64 GB DDR5 6400Mhz |
Video Card(s) | 7900XTX 310 Merc |
Storage | Samsung 990 2TB, 2 SP 2TB SSDs, 24TB Enterprise drives |
Display(s) | 55" Samsung 4K HDR |
Audio Device(s) | ATI HDMI |
Mouse | Logitech MX518 |
Keyboard | Razer |
Software | A lot. |
Benchmark Scores | Its fast. Enough. |
yes same and some horizontal lines on screen.. bios is updated for gaming x trio as per mention in https://www.techpowerup.com/vgabios/?did=10DE-1E07-1462-3715.Looks like the GPU/Memory is either dying, or someone loaded the wrong BIOS.
What happens if you launch anything 3D? Does it show the same corruption, and or does GPUz report the increase in clocks?
System Name | H7 Flow 2024 |
Processor | AMD 5800X3D |
Motherboard | Asus X570 Tough Gaming |
Cooling | Custom liquid |
Memory | 32 GB DDR4 |
Video Card(s) | Intel ARC A750 |
Storage | Crucial P5 Plus 2TB. |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Eweadn Mechanical |
Software | W11 Pro 64 bit |
What do you mean "updated"?.. bios is updated for gaming x trio
You likely flashed the wrong VBIOS. You need to reflash the original(assuming you backed it up) and if it fixes the problem, not tamper with the VBIOS again. You might have done damage to the card. You'll only know for certain after you reflash the original VBIOS.yes same and some horizontal lines on screen.. bios is updated for gaming x trio as per mention in https://www.techpowerup.com/vgabios/?did=10DE-1E07-1462-3715.
Anyone had this issue? how did you fix this?
System Name | C₂H₅OH |
Processor | AMD Ryzen 7 9800X3D 5,45GHz Alphacool Core 1 Black |
Motherboard | ASUS ROG Crosshair X670E GENE |
Cooling | Custom loop - MO-RA3 420 & 360 Pro - Heatkiller 200 & 150 D5 pump/res combo |
Memory | G.Skill Trident Z5 RGB F5-8000J4048F24GX2 8GHz 36-44-44 |
Video Card(s) | MSI RTX 4090 Suprim X Alphacool block |
Storage | Samsung 980 Pro 1TB - Intel 660 Pro 2TB |
Display(s) | Asus PG27AQDM 240Hz OLED |
Case | Streacom BC1 Silver |
Audio Device(s) | Topping DX7Pro - Topping A90 - Hifiman Ananda - Focal Elear - Focal Radiance - Adam A5X & Adam Sub 7 |
Power Supply | Corsair HX1200 |
Mouse | Logitech G Pro Wireless |
Keyboard | Ducky One 2 SF White MX Speed Silver / Logitech MX Mechanical |
Software | Windows 11 Pro |
System Name | Tiny the White Yeti |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
System Name | Dumbass |
Processor | AMD Ryzen 7800X3D |
Motherboard | ASUS TUF gaming B650 |
Cooling | Artic Liquid Freezer 2 - 420mm |
Memory | G.Skill Sniper 32gb DDR5 6000 |
Video Card(s) | GreenTeam 4070 ti super 16gb |
Storage | Samsung EVO 500gb & 1Tb, 2tb HDD, 500gb WD Black |
Display(s) | 1x Nixeus NX_EDG27, 2x Dell S2440L (16:9) |
Case | Phanteks Enthoo Primo w/8 140mm SP Fans |
Audio Device(s) | onboard (realtek?) - SPKRS:Logitech Z623 200w 2.1 |
Power Supply | Corsair HX1000i |
Mouse | Steeseries Esports Wireless |
Keyboard | Corsair K100 |
Software | windows 10 H |
Benchmark Scores | https://i.imgur.com/aoz3vWY.jpg?2 |
System Name | Quantumville™ |
Processor | Intel Core i7-2700K @ 4GHz |
Motherboard | Asus P8Z68-V PRO/GEN3 |
Cooling | Noctua NH-D14 |
Memory | 16GB (2 x 8GB Corsair Vengeance Black DDR3 PC3-12800 C9 1600MHz) |
Video Card(s) | MSI RTX 2080 SUPER Gaming X Trio |
Storage | Samsung 850 Pro 256GB | WD Black 4TB | WD Blue 6TB |
Display(s) | ASUS ROG Strix XG27UQR (4K, 144Hz, G-SYNC compatible) | Asus MG28UQ (4K, 60Hz, FreeSync compatible) |
Case | Cooler Master HAF 922 |
Audio Device(s) | Creative Sound Blaster X-Fi Fatal1ty PCIe |
Power Supply | Corsair AX1600i |
Mouse | Microsoft Intellimouse Pro - Black Shadow |
Keyboard | Yes |
Software | Windows 10 Pro 64-bit |
This ^^What do you mean "updated"?
Did you flash the VBios?
Was it working correctly before?
Thank you..Do you have a backup of the original VBIOS? I'd flash that back before trying anything else. I've flashed a lot of cards and this, to me, looks like a incompatible VBIOS flash. Another thing you could try would be to ask an MSI rep if they can identify which VBIOS you'd need based on serial number. I've never tried that before but hey who knows. Good luck!
No i did not flash the bios. i bougth this card from a friend go for exit 1month ago here in middle east. then this happen after few days ago. that i got error code 23 annd when icheck CPU-Z this is what i found. my friend told me this card has update bios and driver before he exit.You likely flashed the wrong VBIOS. You need to reflash the original(assuming you backed it up) and if it fixes the problem, not tamper with the VBIOS again. You might have done damage to the card. You'll only know for certain after you reflash the original VBIOS.
Ah ok. It seemed in the OP that you had. You might have a card that's gone bad..No i did not flash the bios. i bougth this card from a friend go for exit 1month ago here in middle east. then this happen after few days ago. that i got error code 23 annd when icheck CPU-Z this is what i found. my friend told me this card has update bios and driver before he exit.
