Help I can't boot my PC and I think it´s because of RAM´s voltage
OsKuRo
3 (0.00/day)
Hi!,
I bought a new PC a few weeks ago:
-Mobo: Asus Strix Z690-F
-CPU: i9 12900K
-RAM: Kingston Fury Renegade DDR5 6400 (2x16)
-GPU: The one that I had in another PC, 3080Ti
And it was working "fine" for 2 weeks or so but suddently I started having freezes. When CPU or GPU where totally idle and I was just posting in a forum for instance, I could hear a brief electric sound and system totally froze.
That´s been happening the last days and now I can't even boot with 2 Ram sticks (slots 2&4), I only can with 1 stick in slot "1".
I had XMP at the beginning but someone told me that i9 12900K supports DDR5 4800 and maybe if I was trying with 6400 it was not possible, so I lowered it but same result.
I guess maybe it´s because I need to set XMP on but also set specific voltages?.
This is what Kingston (RAM) , Intel (CPU i9 12900K) and Asus (Mobo) websites say about DDR5 values:
Intel says here: Procesador Intel® Core™ i9-12900K that it supports DDR5 up to 4800
As I just turned ON XMP and it assigns a Profile (XMP I or XMP II) but I didn't touch any voltage... so... maybe that´s the reason?.
I took these screenshots but I don't know if I should also enter another section for more RAM voltages. Maybe this helps you to tell me if I need to put specific values there (considering my model is 6400 version).
Any help would be really appreciated, as right now I have this PC totally useless. I can boot with 1 memory stick in slot 1, but it also says it´s 4000 Freq instead of 4800 (I would like it to be 6000-6400, but I think DDR5 has issues with Alder Lake, so...).
Thanks!!
ir_cow
4,760 (0.79/day)
USA
You shouldn't have to do anything but enable XMP the XMP profile. It will automatically set timings, freq and voltage.
Have you tried setting a lower frequency like 6200 instead?
Also are you on the newest BIOS or the one that shipped with it?
OsKuRo
3 (0.00/day)
Hi, yes I tried with 4800 or 6000 and same result. No boot, just ram led in mobo.
latest bios version 2204.
maybe the mobo it’s defective.
OsKuRo
3 (0.00/day)
Yes exactly. The thing is that I can boot into Windows using each one of the memory sticks but just when I put them in Slot 1.
And Windows says it´s at 4000 instead of 4800, so... really weird.
I sent the entire PC to RMA, so I hope they fix it soon.
43,695 (6.78/day)
Yeah next time post your power supply specs.
9,340 (5.12/day)
Louisiana
Keyboard G710+x3
Using two sticks going from left to right you should be using slots 2 & 4
