HELP i failed bios modding my GPU
Letiv
28 (0.02/day)
Hey mates, i bios modded one of my GPU's like in this video shown
But i missed the pixel patcher step before restarting the PC and now i dont get any video output from the GPU... but the GPU is still working (fan is moving and the light is on).
Please help me
152 (0.04/day)
Processor Amd Ryzen 7 Pro 1700@3.6Ghz
Motherboard Asus Prime B350 Plus (needed pci slot for Ht Omega Claro Halo)
Cooling Noctua C-14
Memory 16GB A-Data DDR4-3200
Video Card(s) AMD Radeon Pro Duo
Storage Patriot Torch 512gb, Seagate Barracuda 512gb , Adata 128gb SSDs & 1TB Western Digital Black
Display(s) Seiki 39" 4k
Case MetallicGear Neo Air
Audio Device(s) Ht Omega Claro Halo
Power Supply Rosewill Glacier 850 watts
Mouse Ancient Razor Diamondback
Keyboard Logitech Illuminated
Software Windows 10 Home 64-Bit
Letiv
28 (0.02/day)
becaus of space reasons i can only plug one GPU at once, but i have a integrated GPU in my CPU with video output that works,
but if there is a real GPU allready plugged in it priorities the real GPU how can i change that ?
139 (0.04/day)
Ukiah
System Name The Tempest
Processor i7 5960x at 4.5ghz 1.255 bios vcore 3.4ghz cache 1.13v on custom water 1.85vin llc5
Motherboard Asrock X99X Killer Fatality
Cooling Swiftech DDC mcp50-x pump XSPC RaystormPro waterblock Acool xt45 Supernova1260 rad 9 140mmfans 1vrmF
Memory 32gb 4x8gb Kingston HyperX Fury (Micron rev.b) 2400mhz 15-15-15-35 @ 3200 16-19-19-36 2T 1.4v
Video Card(s) AMD 6800 XT reference OC 2525~2625 1.1v mem oc 2150 Fast timing Alphacool Eisblock gpx waterblock
Storage M.2 2 TB SSD Seagate 4tb 5400 Western Digital 6tb 7200
Display(s) 4k HDR TLC 43" 60hz TV
Case Antec 900 Top fan 200mm/1side/2front/1rear 120mm AC Supernova 1260 rad 9/140mm fans 1700RPM 1VRM fan
Audio Device(s) Onboard Realtech Logitech 5.1 surround/ Bluetooth headphones
Power Supply Corsair RM1000i PSU
Mouse Logitech
Keyboard Logitech
Benchmark Scores Time Spy ~20000 Extreme 7800 Fire Strike 55000 Extreme 27415 Ultra 13604 Port Royal 10032
Take out the graphics card and go into the bios, usually it is delete key or f1 before booting into windows. Look for cpu integrated graphics or onboard video. Set it to the integrated graphics or onboard video option, then save and shutdown. Put the graphics card back in the pc. Now when you startup and boot to windows you should be using the onboard cpu graphics, allowing you to reflash the card.
If there is a dual bios switch on the video card it is usally on the edge of the video card.
Letiv
28 (0.02/day)
Thanks i will try it now.
i will be back
This one?
Or integrated peripherals?
Advanced chipset configuration
I DONT KNOW :(
139 (0.04/day)
Ukiah
Mouse Logitech
Keyboard Logitech
Look under integrated peripherals or miscellaneous.
Letiv
28 (0.02/day)
Miscellaneous
Integrated peripherals
Would help to use a secound dGPU instead of the iGPU?
but than i need some equipment to plug in
Becaus i have only space for one dGPU at once
139 (0.04/day)
Ukiah
Mouse Logitech
Keyboard Logitech
Do you have 2 video card pci-express slots on the motherboard? If so you can boot to the other working card and then reflash the other one.
Letiv
28 (0.02/day)
I dont know how they are called, but this are some connections for more GPU's right?
But i would need some equipment that i have to buy...
139 (0.04/day)
Ukiah
Mouse Logitech
Keyboard Logitech
I don't think those are video card slots, I think those are like pci-e 4x or 1x.
Letiv
28 (0.02/day)
How can i check that?
The label say pcie_x1_1 and pcie_x1_2...?
1,858 (0.39/day)
Romania
Did you try to plug the monitor cable to the motherboard, maybe it will detect it like that.
Letiv
28 (0.02/day)
What do you mean?
If i remove the GPU, the monitor plugged to the motherboard is working
But if the GPU is plugged in, the monitor that is plugged to the motherboard is now sowing anything.
I bought this now it will arive tomorrow. Maybe i can try one more gpu for video output
Letiv
28 (0.02/day)
FUCK YEAH.
BOTH GPU'S are working now both are fine.
I DID IT everything is good :)
the PCI-E riser was all i needed to get get a video output to reset the bios to stock and change the overclock values.
I am also Thank you to everybody even if it dident help.
Thank you all of you !
152 (0.04/day)
Cooling Noctua C-14
Awesome man! Glad to hear that. :D Good learning experience for you.
50Th Anniversary Happy Dance GIF by Sesame Street
