Help: I think I have "bricked" my ssd
Air
203 (0.05/day)
Processor AMD Ryzen 5600X
Motherboard B550i AORUS PRO AX
Cooling Noctua NH-D9L
Memory 2 x 16Gb G.Skill Trident Z Neo 3600 MHz C16
Video Card(s) EVGA GTX 1070 SC
Storage Samsung 980 Pro 1 Tb
Case Ncase M1 V3
Power Supply Corsair SF600 Gold
Benchmark Scores CPU-Z: 655.8 single, 4999.7 multi Cinebench R23: 1563 single, 11275 multi
Im not sure if I can ask this kind of stuff around here, but this is the only pc hardware community Im part of so Im trying:
I have an 250 Gb 840 EVO SSD. So i saw this option to "optimize performance" or something of the sort in the magician software. So, i tried it. Magician issued a "data loss can occur if interrupted" message, but i was like "yeah whatever". I started closing some programs after it started, then my pc hang up.
Ok, booted again, freeze shortly after. Next try, cant even boot. Turns out magician was serious about that
warning.
Ok np, no important data on this drive. I proceeded to reinstall w10 from usb drive. But on the partition select screen i cant format any partition on the drive. I deleted all partitions, still no sucess. Each time i try to create a new partition it fails and create a small partirion for system, recovery, and msr. On the 5th try it gives an error but creates a 230gb partition. But i cant format or install windows on it. Image follows. This is after i disconected my hdd after seeing some recomendations around. Also tryed to format using cmd comands. Didnt work.
Im about to order a new ssd but decided to give it a shot here. If thats indeed beyond fixing... another question, is an 850 evo worth 30% more than a MX300?
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
Can you stick it in a working computer and try to reformat or maybe try updating the firmware?
Air
203 (0.05/day)
Case Ncase M1 V3
Got no spare computer unfortunately, but firmware is last version, i had just checked it.
New development: tried the "clean all" comand in diskpart and it failed "due to a fatal hardware device error"...
5,731 (1.06/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
That suckers dead! RMA time.
  • Like
Reactions: Air
FreedomEclipse
~Technological Technocrat~
24,349 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Optimising performance just means changing a few windows registry settings and 'trimming' your SSD instead of letting windows handle it afaik...
I cant see this option on the new samsung magician though
Air
203 (0.05/day)
Case Ncase M1 V3
Yeah i guess so... not sure if Im still in the warranty time... gonna have to check.
Yeah, i think it got replaced with this new function. It said something like "data will be realocated to improve performance". Perhaps thats something exclusive to the 840 evo? After all, this is the model that has the performance degradation over time issue.
43,263 (6.74/day)
Secure erase
  • Like
Reactions: Air
Air
203 (0.05/day)
Case Ncase M1 V3
Its not dead. Use a linux boot CD with Gparted and delete all partitions
Ok, tried it. There is only on 450 mb partition, unknow format, with an exclamation mark icon right next to it, and unused space. When i try to delete the partition, it gives an sucess message, but the partition does not go away. Trying to format it has the same results. Sucess message but no format change. Tryin to create a new partition fails.
Secure erase
Magician does not let me create a usb bootable disk because i do not have an samsung ssd on my laptop. So i tried in the gparted drive using the comand line, comand hdparm --security-erase NULL /dev/sdb. Ends in error, "bad/missing sense data"
Solaris17
Super Dainty Moderator
27,189 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Air
203 (0.05/day)
Case Ncase M1 V3
Ok, this was what i did as a last try: Created a new 100 Gb partition on my HDD, instaled windows on it (which only takes around 15 Gb? nice), installed Samsung Magician (which reports SSD condition as "good", ha), created a bootable Secure Erase USB drive, used it, operation failed and told me to try again. I did, same results. And again.
So i gave up and ordered a new one. Lost way too much time on this....
But regardless, thanks a lot for all the replies
EDIT: I strongly adivise against EVO 840 users running the "performance optimization" tool in the new magician. Not worth the risk at all.... my drive was perfectly fine.
1,294 (0.17/day)
thanks for letting us know, at least your bad luck will serve as a reminder to everyone reading this thread.
Don't tweak it if it ain't broken ! (obviously i'm not following this advice as often as i should too)
1,100 (0.32/day)
Latvija
Motherboard Asus
Memory 4GB Samsung
Video Card(s) rx 460 4gb
Storage 750 Evo 250 +2tb
Audio Device(s) Pioneer
Power Supply 430W
Mouse Acme
Keyboard Trust
That new version is no good secure erase bootable usb dont work.
dorsetknob
9,107 (1.26/day)
So the Program gave you a Warning of possible Data loss that's Fair enough
You Run the Program and Then
Closing or opening new programs while the Drive is low level Optimizing would Seriously mess with that low level Optimizing as its Probably interrupting data Optimizing
Resulting in Data loss/corruption ( are you Surprised ) AS WARNED BY THE PROGRAM
If all unnecessary Programs are shut Down prior to running Program and you walk away/leave it well alone while running there should not be any problems
You Unfortunately did not
Air
203 (0.05/day)
Case Ncase M1 V3
Yes, Im not claiming to be smart or anything. But, if I may, given the risk of such operation, I do think the warning should be a little more "scary", or maybe the option should be hidden in an "advanced users" menu or something, so dumb fucks like me just trying to look to the old "OS optimization" menu don't stupidly destroy their SSDs. Normally you can't damage hardware from the inside the OS, simply by clicking a button.
But I'm not mad at Samsung or anything. I know this was my fault.
Ok, you just made me go back and try yet again with magician 4.x...
43,263 (6.74/day)
Evos are cool and all, but required a firmware update to fix a major flaw, the Pro line was not affected. Just like other patts, their support diminishes over time as their focus is 850 series and 960 series. So next time find an old version of Magician and use it.
Air
203 (0.05/day)
Case Ncase M1 V3
Go to:
http://www.samsung.com/semiconductor/minisite/ssd/download/tools.html
Check:
Samsung SSD Firmware Updates for Windows Users section
And download ISO for your drive. Boot up the system using this ISO and try updating drive with that. Maybe bootable firmware update will be able to re-flash the drive even after failure.
Thanks, I'll try that at night.
Ill hardly do any tweak on ssds ever from now on, but thanks, I will keep it in mind (I think magician updated itself though).
On a side note... I have ordered an 250 Gb EVO 850. Where i live its 30% more expansive than a Crucial MX300 275 Gb. I opted for the EVO based on reviews and popularity, but starting to have second thoughts after rembering the 840 flaw, and the price difference is kinda huge (~$206 x $157). Thoughts?
43,263 (6.74/day)
I'm using a 840 Pro. No issues.
The 850 EVO. I would suggest installing the Included software and updating the firmware, I would also disable the automatic updates function
Air
203 (0.05/day)
Case Ncase M1 V3
So, creating a Secure Erase USB from magician 4.9 yelded same results. I also tried updating the firmware using a bootable USB, but could not make it work for some reason. The drive does not boot to the firmware update software. I'm too tired to thoubleshot also this problem.
850 EVO on the way. Once again thanks for all the replies. At least I learned some new stuff in this process.
95Viper
Super Moderator
13,139 (2.21/day)
Have you tried... from the Samsung F.A.Q.s page:
If you run into the ‘Frozen state’ message during a secure erase, unplug the SATA power cable from the SSD, wait a few seconds, and plug it in again without turning the PC power off. And, execute secure erase again.
Also, you may want to have a look at disconnecting the SSD and boot into the BIOS. Check in your security section and make sure there is not any HDD, SSD, or other passwords or encryption set.
43,263 (6.74/day)
I do recall that for secure erase to work you must pull power on the ssd then replug and then start the process. Good find.
brandonwh64
19,542 (3.48/day)
We bought about 50 or so of the 840 evo 256/512 models and I believe we only had one die due to bad firmware flash. I still have two or three in personal computers around the house without an issue. I have 2 samsung 950 evo m.2's in raid 0 on my main PC. I love them they are super fast.
2,748 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
I've had a drive do something similar before with a unknown partition that woudn't go away after it ran into a problem.
Ran DBAN to completely wipe the drive clean then reformatted and all to fix it. If you've already decided to toss it then doing this won't hurt a thing if you do give it a shot.
  • Like
Reactions: Air
Air
203 (0.05/day)
Case Ncase M1 V3
Yeah, the secure erase software orients you how to do it. Will have to look about the security on the BIOS, but i think thats unlikely, since I never had any problem before the "event".
Thanks, will try it when i have the time.
