Help me pick a smaller case for a watercooled PC!!!
4,286 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
Hey guys, so as yall probably noticed I am getting rid of my old PC and starting mostly from scratch. I want to do something MATX or ATX this go round with a complete water cooling setup but kept confined so its a bit easier to move it around. Really interested in a white build this round.
Any ideas? I have been searching but I am not finding many cases that I really like. I am also considering if I want to keep my current style loop or build a new one so if you see any that have at least two bays that would be great. Up for just about anything as long as its not giant like my Obsidian 800D was.
Basic specs:
i7 8700k
ATX or MATX White board
Water cooling custom built
Titan XP or Next Generation GTX 1180/2080/1180ti in the loop
M.2 SSD and 3 2tb HDD's
14,062 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Is the Obsidian 450D too large?
Unfortunately it's black, but a spray with paint would fix that :D
7,493 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
If you want it really cheap... I took COOLER MASTER CHASSIS MASTERBOX Q300L for my LP box.
4,286 (1.11/day)
Texas
Mouse Logitech G5
I don't mind doing that but I want something with a bit more pizzaz or a cube PC.
One of the ones my eyes are on is this one.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811139130&ignorebbr=1
Wow that's not bad and looks very clean. What size radiators did you fit in there and how many?
Price is not an extreme concern of mine but I don't want to spend a crazy amount.
13,065 (1.96/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Make sure you really, I mean REALLY want white. White does look nice when brand new. But it does not take long for that to change.
Did you mean to say "ATX"? ATX is full size yet you said you want to go smaller. A mid-tower case will support ATX boards, but unless you go "thin", they are not that small. And I don't recommend thin cases as they restrict your cooling options, and often your expansion card options too.
4,286 (1.11/day)
Texas
Mouse Logitech G5
I know but I intend to keep it clean. Plus just want to be different.
Yes, I guess the context for this is needed because I have an E-ATX PC right now and want to go down to an ATX or MATX system. I was going to be exclusive MATX but I am now having trouble finding white Z370 motherboards in MATX so I may just do ATX.
7,493 (1.47/day)
Rīga, Latvia
Software FEDORA 41
Did manage to fit two 240mm rads... no probs. I got it for 30€, total gem for the price. Look up some vids on youtube. The only badside is the plastic window... it scratches. But whatever... Very good design, for moving around I don't care for that.
550 (0.12/day)
Processor Intel Core 2 QX6850
Motherboard ABIT AB9 Pro
Cooling Zalman CNPS-9900 MAX-R
Memory Patriot PDC24G6400LLK (4x 2 GB)
Video Card(s) Palit GeForce GTX 560 Ti Twin Light Turbo
Storage Not Enough!
Display(s) Samsung T240HD
Case NZXT Zero
Audio Device(s) Creative Labs Sound Blaster X-Fi Elite Pro
Power Supply Thortech Thunderbolt Plus TTBPK00G 1000W
Mouse Elecom M-DUX70BK
Keyboard CM Storm Trigger (Cherry MX Brown)
Software NOT Windows 10
4,286 (1.11/day)
Texas
Mouse Logitech G5
Maybe try the Thermaltake Core V21? It's a cube, and if you want "pizzaz", grab two of them and stack them like a Transformer or something.
I had been glancing at that case earlier I will take a look in depth more at it as it seems to fit everything I am thinking of.
peche
Thermaltake fanboy
6,709 (1.84/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
4,286 (1.11/day)
Texas
Mouse Logitech G5
i was about to mention that case and some new others
Core X9 Snow Edition
Thermaltake Core X5 snow
Also, but limited to mATX and small builds....
Core V1 Snow Edition
Regards,
Wow those two are awesome looking and was what I was imagining pretty much!!! I wonder how big they are in person and how heavy they will be as they seems to be a pretty big size to fit all those radiators. The X9 is on sale on newegg right now. But I found the X5 for 189 is a good deal and looks to be about what I am wanting size wise.
peche
Thermaltake fanboy
6,709 (1.84/day)
System Name Athenna
glad to be able to help. click on link / name and you will be redirected to official site, sizes and other data is at bottom, you can do your math and analyze if the size is correct for you, actually Core X9 is a option i still conssider!
Regard,
12,315 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
They make some pretty nice SFX Power supplies now maybe go that route?
Enermax STEELWING
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
I enjoyed building in the Fractal Design Meshify-C. It's classified as a mid tower ATX, but it's roughly 20% or so smaller than other cases classified in the Mid tower ATX size group, I just recommend you verify the length of your video card before buying it.
Thermaltake core V21 was a fun build as well. It's a cube design, so be aware it's not a tower in the traditional sense, but it's definitely an amazing case
I've been leaning towards smaller pc builds recently, but I would recommend that unless you really want to go tiny ,because of function or size restrictions, you stay in the micro ATX or greater area, when you go under micro ,things get pricey and fairly difficult in some situations
2,963 (0.84/day)
Long Island
Evolv mATX Tempered Glass - Fits twin 280s -r 360 + 240 (_ a 140 in rear which I wouldn't waste time on)
You said you wanted a white MoBo and for that Id suggest the gray anthracite color. Have Black, Gray, Silver and White Phanteks cases ... Black is the hardest to keep clean, white the easiest. It's a "designed for water cooling" case so it is by no means small by mATX standards but smaller than ATX
4,286 (1.11/day)
Texas
Mouse Logitech G5
Enermax STEELWING
Have not seen that one yet, thoug hI am trying to do a bit bigger than MITX because I still want some space inside and MITX boards are not my favorite when I do a bunch of overclocking and such. That said that case looks pretty sick, I may look into doing a build like that.
Yea I want small but not tiny, I just don't want a humongous machine made out of all steel like the 800D again mostly.
I have my eye on that one for awhile, really like it.
4,286 (1.11/day)
Texas
Mouse Logitech G5
Thank you guys for all the help, I went with the Core X5 after all the suggestions as it seemed to fit what I wanted to do best in my eyes.
crazyeyesreaper
Not a Moderator
9,811 (1.72/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
I have the corsair air 240. I don't have WC in it, but it is designed to work with a 240 rad and I think it's possible to fit a couple in there.
6,159 (1.52/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
View attachment 105622View attachment 105623View attachment 105625
I was gonna recommend the Air 540, which is almost the same as the 240 but a bit bigger (~30)%, which will allow for practically any cooling & storage options you could imagine....
I have a used black one I could sell for cheap, if you wanna explore that possibility :)
