HELP! need original bios for Sapphire Pulse RX 580 4GB Samsung (with sku)
lowspecguy
7 (0.00/day)
my current bios has low clock speed because i think mine has a mining bios, i have found many bioses in the site but im not sure what to flash, last time i flashed it was a failure which bricked my card because i flashed the wrong bios. can someone help me find my original bios :( been searching forever.
specs:
i5 6500
asrock h110m-dgs
2x4 gb ram dual channel
600w true rated psu (gigabyte)
GPU-Z: http://gpuz.techpowerup.com/19/09/24/ern.png
attached my sku and gpu photo
1,118 (0.57/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g, ryzen 2600 upgrade:)
Motherboard msi b350 pc mate, biostars a320, asrock ab350m micro
Cooling x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh
Memory klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick
Video Card(s) back to square, using vega 56 now:D
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
43,007 (6.72/day)
Im not here 24/7, i sleep too. It is 6 AM here
@lowspecguy
Open gpu-z again, click the arrow right next to the uefi checkbox and attempt to upload your bios to the vga database through the program only. You should receive a prompt window that the bios is already in the database with a link to the bios, copy the link and post it here please.
lowspecguy
7 (0.00/day)
@lowspecguy
sir it didnt detect any duplicates, though i still uploaded it.
1,118 (0.57/day)
ofcourse it wont duplicated since yours got mofifed by miner, tpu always pick selection bios, not much random mod one, the normal clock for pulse 580 is 1366, i dont own samung chipset model so i cant share it for you, just follow instruction from the man, he could fix this for you, wory not:toast:
lowspecguy
7 (0.00/day)
ofcourse it wont duplicated since yours got mofifed by miner, the normal clock for pulse 580 is 1366, i dont own samung chipset model so i cant share it for you, just follow instruction from the man, he could fix this for you, wory not:toast:
thank you sir
43,007 (6.72/day)
The only difference between this bios and yours is yours has a 1+MHz boost on yours over this one but everything matches.
I will keep on looking
This matches your uploaded bios too
Download this tool
Download one of these 4
They match throughout but are correct clock speed
Do not flash this one (last resort)https://www.techpowerup.com/vgabios/213033/213033
This may work
Open the tool, find the file you downloaded flash and follow prompts.
@lowspecguy here are the files
specs:
i5 6500
asrock h110m-dgs
try this one
try
i would sugest you wait for the pros @eidairaman1:)
yeah waiting for him too :)
lowspecguy
7 (0.00/day)
Download this tool
This may work
will try now
lowspecguy
7 (0.00/day)
Download this tool
This may work
WORKED PERFECTLY! tested on GTA V very high settings getting no drops, temps are pretty normal too. THANK YOU SO MUCHHHHH U SIR IS A TRUE PRO u made my day man! ill keep you updated or be seeing you in my future threads here :))
1,118 (0.57/day)
i think the 2000mhz mem clock should work yes, i always got limited to 1750 on all my card pulse model, if it is elpida somehow:D
43,007 (6.72/day)
That is true
