matias.comesana
- Aug 24, 2024
- 2 (0.05/day)
My laptop is a Gigabyte Aorus 17 XE4, which I bought in October 2022 (it's not under warranty anymore). It comes with an RTX 3070 Ti. The problem is that very often, the GPU clock gets stuck at 210 MHz, and most importantly, the board power draw increases and gets stuck at 752 W, which is obviously a bad reading or something, as there's no way it is actually consuming that amount of power.
I took 2 screenshots and a full video showing the problem while using FurMark (to stress the GPU), GPU-Z, and HWMonitor at the same time. These 2 screenshots show the "before" and "after" of the exact moment where the clock decreases from 1245 MHz to 210 MHz, while the power increases from 128.6 W to 752 W. When this happens, the laptop remains with these values until I shut it down or reset it. Sometimes, when I start the PC and after using it for a while with non-demanding tasks like Chrome, Outlook, or some other non-gaming activities, I check GPU-Z and find that it’s stuck at 752 W.
So far, I've tried uninstalling GeForce Experience, installing older GPU drivers from the Gigabyte website, and nothing seems to solve the problem. I also have MSI Afterburner installed. I don't recall when the problem started. I've never flashed the vBIOS.
I don't think the problem is the thermal paste since it doesn’t explain the sudden bad readings from GPU-Z. Perhaps it is a faulty sensor? But it's strange that a faulty sensor gets stuck with faulty values; I would expect a faulty sensor to give us faulty readings all the time, but who knows. Really, I'm by no means an expert, so I need your help, guys.
What do you think the problem is? What should I do first? DDU and install GPU drivers from the Nvidia page? Reinstall Windows? Flash the vBIOS (I don’t know where to find the most recent and compatible ROM in such a case)? Change the thermal paste?
Before
After
Full Video
Before
After
Full Video
