Help needed to identify RGB pin 1 on Gigabyte mobo
3,228 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
I'm not sure which is pin 1 on B450 Aorus Pro WiFi, but I do know that the arrow on the RGB connector lead needs to meet it. The pins aren't numbered but there may be a rule of thumb that I'm not aware of.
This is from the manual:
Motherboard:
Perhaps the orientation of the manual drawing is a hint?
Thanks.
213 (0.23/day)
Processor Ryzen 5 5600X
Motherboard Asus B550-F Gaming WiFi
Cooling Be Quiet! Dark Rock Pro 4
Memory 64GB G.Skill Ripjaws V 3600 CL18
Video Card(s) Gigabyte RX 6600 Eagle (de-shrouded)
Storage Samsung 970 Evo 1TB M.2
Display(s) 2 x Asus 1080p 60Hz IPS
Case Antec P101 Silent
Audio Device(s) Ifi Zen DAC V2
Power Supply Be Quiet! Straight Power 11 650W Platinum
Mouse JSCO JNL-101k
Keyboard Akko 3108 V2 (Akko Pink linears)
I would just use a multimeter grounded to the chassis to find the 12V pin. It's best to check and be on the safe side.
Looking at the PCB for clues, the bottom pin has a wider trace on it than the other three. So I suspect the bottom one is 12V.
ir_cow
4,297 (0.73/day)
USA
My guess is the left is 12v (button pin in photo). Because the text above it makes that the top. It would go 12v-R-G-B. I plug them in wrong all the time. If you don't get lights, flip it around.
5,523 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
Ruru
S.T.A.R.S.
12,399 (2.87/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p144
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
I agree on this one as I have a Gigabyte board as well. But it should be just like pointed out in the pic above.
5,964 (2.90/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Motherboard:
Thanks.
First drawing is always oriented the same way the connector is actually oriented on the board. Pin 1 is the bottom one.
3,228 (1.02/day)
Buenos Aires
Ruru
S.T.A.R.S.
12,399 (2.87/day)
Jyväskylä, Finland
