Help:Pc suddenly shut down, Now can’t turn on
Mko
1 (1.00/day)
Went out of my room to do something while my pc with only a single chrome tab open,then when I came back it was just off and won’t turn back on
How do I figure out what wrong? My guess is PSU but iam not sure,if it was the PSU suddenly dying should I be really concerned of the other hardware being damaged
430 (0.11/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Did you try flipping the psu switch?....could be a tripped psu.
14,094 (6.37/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Could be the PSU. Or it could be some other component causing a short, like a failing HDD or GPU.
And whether you should be concerned about other components if it is your PSU, that depends on your PSU. If it's a high quality model, then probably not. If it's a cheap noname sh**, then... well...
1,429 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Yes, flip the back switch on the psu off then on. Most boards have lights that will show up if there is power but if not you can pit power and see if any thing tries to turn on. If does then its a short in something. It happened to me a great many years ago which my gtx1080 just randomly dying and shorting out.
