HELP ! RX 580 BIOS OR DRIVERS
sfzxc
6 (0.01/day)
Hello everyone, I immediately apologize for the off-topic if I suddenly posted the topic in the wrong section.
I bought a video card after mining as RX 580 8 GB Sapphire Nitro
I want to play games on it, they said I need to flash the BIOS in it.
It is different from the 580 Nitro, it has a 1x8-pin power connector
Video chip from RX 470 as I understand it
Tell me, can I play games on it?
What bios do I need to flash it so that I can install drivers and play games?
Video chip : 215-0876204
P/N: 113-FE3533U-O99
Memory chip (Samsung) k4g80325fc-hc25
5,475 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
2,100 (0.49/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Need to use AMDVBflash 2.93 to flash also. ;)
sfzxc
6 (0.01/day)
Thank you very much kind people!
Please tell me if such a video card will be suitable for games if I send it to the BIOS sent by Athlonite?
Try this BIOS as it's the original Sapphire Nitro+ RX580 8GB GDDR5
https://www.techpowerup.com/vgabios/191262/sapphire-rx580-8192-170320
Video chip from RX 470 as I understand it....
um no they were originally a RX480 chip that was binned to run at higher clocks and then with a die shrink were called the RX590
UPD:
I checked, my SubSyst, Device ID and memory marking (k4g80325fc) do not match the bios that was sent above, should it definitely fit?
578 (0.37/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
Its a 580 2048sp edition, if it came from china then its absolutely normal. 2048sp is identical to 570, its name is just a marketing gimmick as its not a normal 580. Regardless of all that, here on tpu there are 2048sp specific bios'es available, you just need to double check the vram specific model, for this you will need to open the card and take pictures of the gddr5 chips.
Edit: If you are sure about the vram chips (samsung k4g80325fc-hc25, there is no typo, and you saw the chips with your own eyes), the bios that should work is this one https://www.techpowerup.com/vgabios/249377/249377
sfzxc
6 (0.01/day)
Thank you! :love:
I dismantled the card and saw that these vRam chips were there.
Is this bios good for gaming? And what driver will I need to install? from 570 or from 580?
P/N Doesn't match, is this normal?
What version of AtiFlash should I use for this Bios?
1,864 (1.53/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
Yes you have the RX570 chip implemented in your card.
But the producer implemented it as an RX580 with 2048 streams.
Let me search an exact BIOS for your card.
Here you have an exact match for your card ID, subID and memory code :
Remember to flash the BIOS use ONLY version 2.93
A short tutorial for flashing a card:
sfzxc
6 (0.01/day)
Thanks for the help!
Hello.
Hello.
1,864 (1.53/day)
Romania
sfzxc
6 (0.01/day)
The BIOSes i provided earlier are the original ones.
Yes you can play any game you like, but remember that Polaris is suitable for 1080p games only.
The newest games requires more capable video cards.
There is no driver for 570 or for 580.
The driver itself will identify your card and will be installed according to it.
I suggest you to use the following driver :
Thank you so much kind person!
I will try :love:
1,864 (1.53/day)
Romania
you are most welcome!
sfzxc
6 (0.01/day)
Everything is great
Installed :
1) https://www.techpowerup.com/vgabios/225271/225271
2) Just installed the LATEST DRIVER! ! ! (With low scores in Furmark tests above happened)
3) Patched it atikmdag-patcher-1.4.14
OK Everything is fine and stable
Hope this article can help someone else.
Thank you so much everyone, peace :love:
1,864 (1.53/day)
Romania
We are glad that you solved it.
Cheers mate!
5,475 (1.03/day)
Gougeland (NZ)
UPD:
My bad I assumed it was the same as my card which is an propper Sapphire Nitro RX580 8GB don't use the BIOS file I linked to if it's some dodgy chinese market only jobbie
