help setting up 11400f on gigabyte b560m aorus pro ax
ecologist
24 (0.02/day)
hi all,
trying to get the most of this locked 11400f and set it up properly. I've already enabled xmp to 3200nhz and set power limits to unlimited using intel xtu.
1. is it possible to lock all cores to 4.4ghz on the b560 or z590 platform (i.e. use MCE on the locked 11400f)?
the b560 will not allow manually setting core ratios beyond their locked numbers (42x all core, 43x 2 cores, 44x single core), but it will allow setting their turbo ratio to 44x, however this appears to have no effect.
2. if 1 is possible, can this also be coupled with a BCLK of 102.9mhz to give 44x102.9= 4.5 ghz?
3. MCE is not available on gigabyte b560, is it available on asus, msi or asrock? (I have seen it available on asus tuf b560 but does it work?)
4. option to set BCLK is not available on gigabyte b560, is it available on asus, msi or asrock?
5. the aurous pro comes with a bclk of 99.75mhz, is there a way to set it to 100mhz?
6. does b560 support memory overclocking beyond 3200mhz with a 11400f
is there anything else I should set up/change in BIOS for this cpu?
1,533 (0.39/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
Do this in BIOS
The boost table is the highest you can set the core frequencies manually, so it will be lower for all core and higher for single core as you note here.
The previously mentioned boost tables should operate on the frequency multiplier independent of base clock. Basically the processor should assume the BCLK is 100MHz even when it is not 100MHz.
MCE is the Asus branding for unlocking power limits out of the box.
Not sure where to find it in GB BIOS and I can't find any pictures of the BIOS to scroll through. I would expect it to exist on boards from all the vendors, definitely higher end ones like the Aorus Pro. On Gigabyte Z590 boards it is near the top of the main tweaker page.
99.75MHz BCLK is usually done for EMI compatibility, usually as part of a spread spectrum technique. Disabling spread spectrum (if it is an available setting) should make the BCLK 100MHz, otherwise manually setting another BCLK as above should fix the BCLK to the set value.
Yes, keep in mind that the best memory performance with Rocket Lake is achieved at the highest possible Gear 1 frequency with the tightest possible timings.
Not that I can think of off the top of my head.
573 (0.35/day)
Florida
Processor 5800x3d
Motherboard MSI Tomahawk x570
Cooling Thermalright
Memory 32 gb 3200mhz E die
Video Card(s) 3080
Storage 2tb nvme
Display(s) 165hz 1440p
Case Fractal Define R5
Power Supply Toughpower 850 platium
Mouse HyperX Hyperfire Pulse
Keyboard EVGA Z15
What mobo do you have?
I'm surprised you don't have an option to adjust your bclk, but if you have maxed out pl and turbo ratios and overclocked your ram, it should be pretty close to maxed out already.
573 (0.35/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
I cannot max out turbo ratios on this board. is this possiple on z590 or other b560 boards for this cpu?
According to Techspot/HUB, you've got a good board. https://www.techspot.com/article/2252-intel-b560-disaster/
If you've maxed out all your settings plus overclocked your ram, you should be close to maxed out if not there. I doubt changing boards would do much other than add expense to what's supposed to be a value build.
