Will take time, will be back later to study it all
1366/2000
Latest bios for your card
8 GB GDDR5, 1366 MHz GPU, 2000 MHz Memory
www.techpowerup.com
www.techpowerup.com
www.techpowerup.com
Here are the rest
Extensive repository of graphics card BIOS image files. Our database covers submissions categorized by GPU vendor, type, and board partner variant.
www.techpowerup.com
Use this guide to flash.
Download atiflash/amdvbflash 2.93
If you can't find 2.93, Go here
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow this Guide
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to biosname.rom
(Biosname.rom is just an example, change it to match your card model in 5 characters with .rom on end)
4. Move biosname.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked"
9. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 biosname.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0)press enter.
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen.
Please find original bios for Sapphire RX580 8GB bios Dual bios ,there unverified version can find ,am brought used Sapphire may be previous owner has modded
the bios ,has dual bios one switch position now working shows Non-UEFI low Frequency as per GPU-Z
PART NO 299-4E353-830SA
SKU-11265-05
Samsung* K4G80325FC-HC25
