Rx570 or Rx 580 2048 SP because of the chip.
Verify if all ram chips have the number 4 to the right of the code H5GQ.
So I previously bricked the gpu mentioning in the title. see this thread I am trying to find a proper bios for it, as it is a bit of an odd thing. It is a Asus ROG Gaming OC 8gb 570 to be precise (samsung memory), but the actual gpu chip is labeled 215-0876406, which Ive seen is either for 470...
www.techpowerup.com
I recently pulled this guy out to see if I could get it going. Tried a few of the OEM RX580 4gb and 8gb bios that look similar with the squirrel fan and they will flash successfully but then it shows 0 mem and 0 mhz even after pixel patching. I’m stumped! Sticker says RX580DE PA7103. Any help is most appreciated as always!
Does the card hestsink look like this?
Find many great new & used options and get the best deals for AMD Radeon R 8GB GDDR5 Graphics Card - OEM RX-580DE PA7103 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Nvmd you said squirrel cage, some research states its a dell oem most likely. And cards badged oem tend to be cut down models.
There are 3 files there, try them, if it still doesnt work, scrap the card
Extensive repository of graphics card BIOS image files. Our database covers submissions categorized by GPU vendor, type, and board partner variant.
www.techpowerup.com
Or try these
www.techpowerup.com
