The turbo power limits control the maximum amount of power the CPU can use and the turbo ratio limits control the maximum speed of the CPU. Do not be afraid to do some hands on testing. You can change either of these while the CPU is loadedWhats the difference between decreasing Turbo power limits and Turbo ratio limits?
I always check the MMIO Lock box in the TPL window. After that you can clear the Disable Controls box and adjust the MSR power limits. I find it is easier to only have to adjust one set of turbo power limits.Should i change any of these settings
System Name | Lenovo Thinkpad T480 |
Processor | Intel Core i5-8350U (Undervolted) |
Motherboard | LENOVO L6SDF912 |
Cooling | Stock fans |
Memory | 16GB DDR4 |
Video Card(s) | Intel UHD Graphics 620 (iGPU) |
Storage | Samsung PM981 240GB |
Display(s) | Stock 1920x1080p IPS LCD |
Case | Stock Laptop case |
Audio Device(s) | Stock Speakers |
Power Supply | Stock 65w charger |
Mouse | "Xunfox K820" |
Keyboard | Stock Lenovo keyboard |
Software | Windows 11 Pro |
Benchmark Scores | Best stats: Cinebench R23: 4234 (Multi) 946 (Single) Geekbench 6: 4305 (Multi) 1265 (Single) |
I also have an i5-8350u. Use Throttlestop's built in benchmark (TSbench) to compare your scores with and without undervolt, and compare the scores in Cinebench. I used to get a score of about 3300 in Cinebench, and now I can get about 4100. For TSbench, I can get about 21 or below that for 8 threads and 120m.I only thought of undervolting, to decrease heat and loud fan.
I found some tweaks in other peoples threads with lenovo laptops and 8th gen processors.
I tried testing with cinebench, but it wont finish in 10 mins, rather in 15-20mins.
1.How do i check if this makes any improvements? Is there any tweaks i shouldnt have done?
2. How to know how much W my cooling can handle?
3.Thats what i changed so far:
MAIN:
OPTIONS:
- Balanced performance mode - checked
TPL:
- Prochot offset 3 - checked
- Lock Prochot offset - checked
FIVR:
- MMIO lock - checked
- Disable Controls - unchecked
- PL1 - 25 / CLAMP checked
- PL2 - 30 / CLAMP checked
- Turbo time limit - 8
- Power limit 4 lock - min 71 / max 0, unchecked
Also attaching log file with these settings
- Offset Voltage: Core and Cache -100mV
- Offset Voltage: Intel GPU and Unslice-50mV
- Core, Cache, Intel GPU, Unlsice - IccMax set to max, 255.75
