Help with 6600GT volt mod
DavyGT
Hello,
I like to ask if I can get some help doing a pencil mod on my XpertVision 6600GT PCI-e, just for fun and keeping my skills, as my 4850 and 3850 are being RMA'ed. The card is no longer required to serve as a backup card and isn't worth anything by today's standards, so it's no biggie if it dies. The volt mod can be either for vGPU or vmem, doesn't matter as long as there's a measure point.
The problem after Googling for some volt mods for my 6600GT, is that my PCB is different from every other 6600GT.
Here are the sites I checked already;
http://sg.vr-zone.com/articles/Gain...-E_Overclocking_&_Voltage_Modding/1636-3.html - My card's layout is different to either of those cards.
http://www.overclock.net/graphics-cards-volt-mods/62092-msi-nx6600gt-td128e-vcore-mod.html - Layout is different as well.
Here are some pics of the front and back of the card.
I can check the codes on the little chips, just highlight where you need me to check. Don't worry about the cooling either, I can get an Accelero S1 on it once I can get the vmod done.
Thanks in advance.
Solaris17
Super Dainty Moderator
27,198 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
i want that card :( but if you want to mod it i need more high rez pics tha that
i need upcloses of all the chips on the back side and as much of the surrounding area you can keep in focus.
sneekypeet
not-so supermod
29,667 (4.32/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
All I can google its the mod with a potentiometer...the links to the pencil mod goes to VR forums and they dont have the images any longer.
DavyGT
I can't do close ups, as the macro is too blurry, so instead I labelled most of the ICs on the back if it helps.
Blue: 10n03LA
GAE549
Mutant Purple: RT9214
PS7ML0R
Green: LM358
2BJMX
Orange: 74HCT08D
AV79828
Un60547E
Yellow: LM358
2BJHX
Gray: D434AB
FOD
6612A
