Help with flashing bios 16MB problem
189 (0.09/day)
Processor Ryzen 7 5600x @ stock
Motherboard B550M motar wifi
Cooling Thermalright assassin 120 se
Memory DDR4 G.skill 32gb @ 3600mhz
Video Card(s) 6700xt
Storage 2x Crucial MX500 1tb SSDs 1TB SN850x
Display(s) Acer nitro XV272U 1440p 170hz
Case Deepcool M370
Power Supply Corsair RMx 850w
I currently have a b360 a-pro trying to upgrade the bios, the problem is I can't flash the new bios no matter how I try it says the ROM size doesn't match the bios that I have but they are both the same size 16MB, tried to download a older bios from the list and it doesn't flash either :confused: Couple of things I tried: Renaming the bios file doesn't work, Used a different flash drive still doesn't work, removed and replaced cmos battery still nothing. The reason I need to update is because the one I have now from 2018 is a beta bios and it's causing boot problems where it gets the priority all mixed up upon restarting.
1,870 (0.31/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Why aren't you using m-flash?
189 (0.09/day)
Case Deepcool M370
M-flash doesn't work with it nothing pops up in the usb flash drive I have 4 all show nothing up even though it's on the flash drives.
1,870 (0.31/day)
How large is the usb drive? Do you have a smaller drive? Is the filesystem on the drive FAT32?
189 (0.09/day)
Case Deepcool M370
two of them are 8gb and two 32g. Yes formatted to FAT32.
1,870 (0.31/day)
It seems your motherboard is/was part of a prebuild (PowerSpec G223):
The reason the bios file isn't displayed by M-Flash is that the file name isn't matching.
You can try to rename E7B22IMS.240 to E7B22IZ1.240 at your own risk.
189 (0.09/day)
Case Deepcool M370
I hate OEM boards so much you have no idea, this is the reason why it's always a toss if it works after flashing it or not...
Thanks @VuurVOS
Edit: The renaming didn't work either.
1,870 (0.31/day)
Thanks @VuurVOS
I hope renaming the bios file will work for you when using M-Flash.
189 (0.09/day)
Case Deepcool M370
Do you know why it's complaining about the size of the bios not being the same size of the update bios?
Solaris17
Super Dainty Moderator
27,097 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
OEMs generally customize the verification so normal BIOSs sometimes do not function.
1,870 (0.31/day)
Does it complain in M-FLASH about the size as well? Can you make a screenshot/photo?
When you put the orginal E7B22IZ1.2M4 on the usb stick, is it visible in in M-FLASH?
If it is visible, can you rename E7B22IMS.240 as E7B22IZ1.2M5 and put it on the usb stick and try again?
Can you also share a screenshot of the content of the USB stick?
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Can you post a photo of the currently installed BIOS version?
I would also try formatting the USB stick again (FAT32), and including nothing else except the BIOS file before flashing.
Also, are you sure that your motherboard is indeed MSI B360-A-PRO? https://www.msi.com/Motherboard/B360-A-PRO/Specification
That is probably the only thing that would explain to me why it's reporting that the BIOS filesize doesn't match.
189 (0.09/day)
Case Deepcool M370
It shows up with the original name but not when it's renamed
If it's any help I got the bios file if I could upload it...
5,847 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
There is zero chance of an OEM board accepting a standard BIOS flash. Contact the OEM.
1,870 (0.31/day)
I just tested with my MSI B350 Tomahawk and "tried" to crossflash it to a MSI B350 PC Mate. M-Flash was able to detect the file which has the bios content of the MSI B350 PC Mate.
See this video with explanation:
Please make a screenshot of the usb stick since I really think the file is not properly named.
1,492 (3.67/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Using m-flash, put the new bios file without a rename to the C: drive. Right to the C:, not in a folder.
Select m-flash, the pc should restart into m-flash mode. Select the new file from the C: drive and continue with the flash.
I do this exact procedure for both Asus and MSI boards.
It won't matter if it's an OEM board, you just need the bios file from the OEM manufacturer.
GL!
1,870 (0.31/day)
GL!
It seems you dont understand the reason behind the crossflash.
Mazer already have the latest bios which can be found on the internet (MSI forum). On the website of PowerSpec they dont provide any bios updates at all.
E7B22IZ1.2M4 is more than 5 years old while MSI themselves supported the same board until last year.
1,492 (3.67/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Then it's not the same board.
He'll need to crossflash with a programmer, it won't flash with software.
GL!
189 (0.09/day)
Case Deepcool M370
I can take more pictures of the board it's in my PC might be little dark, but it's the exact same looking board it even says msi b360 a-pro on it.
I do have a cha program thingy since I bricked a amd board years ago but I forgot how to use it it's been awhile lol.
1,870 (0.31/day)
I would say, that is your assumption? Physical it should be the same board since it shares the same board ID (MS-7B22). It is just not supported by MSI due the custom bios.
I dont think a programmer is needed. I could even display PowerSpec bios (E7B22IZ1.2M4) with the adjusted name (E7A34AMS.1R1) in M-FLASH on my MSI B350 Tomahawk board.
It should be a naming issue for M-FLASH ;)
1,492 (3.67/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Not sure about "naming issue".
Have never, not once, ever, needed to rename a bios. And I don't even know why cause everyone else makes this common practice.
If he didn't need a programmer, he'd already have this flashed and wouldn't need this help thread.
That is my assumption.
GL!
189 (0.09/day)
Case Deepcool M370
I will try this again and post pics when I get home
@VuurVOS Like this?
1,870 (0.31/day)
@VuurVOS Like this?
It looks good, M-FLASH should display this file. Can you confirm there is no double file extension like E7B22IZ1.2M5.2M5?
189 (0.09/day)
Case Deepcool M370
1,870 (0.31/day)
@VuurVOS Alright sorry for another delay as I am nervous doing this, I needed to ask about using a programmer CH341A would it be okay to use this in case it bricks the motherboard it's the one I have somewhere need to find it.
I understand that it might go wrong. You need to buy a 1.8V adapter as well or you must buy a CH341A programmer version 1.7 separately which support multiple output voltages
CH341A programmer (old version) kit with 1.8V adapter, 8SOC Clip
CH341A programmer version 1.7 only:
It is wise to make a dump of the DMIData. If the motherboard is bricked after the flash, you still need to restore parts of the DMIData. DMIData is used by Windows activation.
You can download DMIEdit from here. It also explains how to use it: https://support.ctouch.eu/hc/en-us/articles/360000645679-GUID-UUID-TOOL
I recommend to make a backup of DMIData first before flashing. Just start "run_me.exe" and "Save All" to a file.
