Help with making a solution (using pseudo code)
Rehsa
1 (0.00/day)
Please help me make a pseudo code solution for this problem.
A person suspects that a dice is biased and gets 10 people to throw 100 times each and record.
A algorithm is need input numbers from each person (into the a Throws array) and output the distribution of the numbers 1 to 6 as well as output the highest scoring.
Output whether or not the dice is biased.
myesilyurt
1 (0.00/day)
You'd need a distance metric for this. You'd never be sure if a dice is biased. You can throw 100 6s and it is still an unbiased dice even though probability of throwing 100 6s is 1/6^100.
So, you'd need some threshold and say a square distance metric.
Let's define M = [16.6, 16.6, 16.6, 16.6, 16.6, 16.6] array. This is 1/6 probability of each number a dice can be thrown in 100 throws.
If Throws array has the number of throws for each number, you can use a metric like
1/100 * Sum(1 = 0 to 5)(Throws - M)^2
And if this is greater than some threshold, the dice is "probably" biased.
58 (0.01/day)
2,707 (0.74/day)
On The Highway To Hell \m/
He was obviously just trying to cheat on his homework assignment. Continue to stroke your own egos if you must I suppose. Just stop pretending like you're responding to the OP while you do it. Thanks!
A flowchart would solve the max 8 software bug. Yup.
Work on that..
You can bet other planes in Boeing's fleet have the same code origins.. Maybe even airbus.. who knows..
Yeeeeeaaaaahhh....right....:shadedshu:
5,731 (1.06/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
yay another necro
