Help with OS Transfer on a new build
25 (0.01/day)
Processor i7-6800K
Motherboard Asus X99- A ii
Cooling Corsair H100i GTX
Memory 32GB Corsair LED 3000mhz DDR4
Video Card(s) Asus Strix ROG GTX 1080 OC
Storage Intel 600P 512GB M.2, Samsung 850 Evo 500GB, Intel 730 240gb, Seagate Barracuda 2TB
Display(s) Acer XB270HU bprz 1440p 144hz gsync, Dell S2340m
Case Corsair 460X RGB
Audio Device(s) Blue Snowball, Sennheiser HD558
Power Supply Seasonic Prime 750W 80+ Titanium
Mouse Corsair M65 RGB
Keyboard Corsair K70 Lux RGB MX Browns
Benchmark Scores http://www.3dmark.com/fs/11219459
Need some help figuring out what I need to do for a fresh build tomorrow. I will be moving off of my old CPU and mobo to a new X99 system. Right now I have my OS on a Sata SSD and want to transfer it onto a new NVME drive.
Some issues:
  1. I have a windows 10 upgrade from a RETAIL windows 7 license so I should have migration rights correct?
  2. I have 3 other non-OS drives so after I do the install with my old/ current Microsoft account will my fresh install of windows recognise those drives?
If you guys could shed some light on how to do this or advice please lend a hand. thanks!
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
Do a fresh install Widows 10 with the Windows 7 license. Good to go.
After the install then hook up your data drives. You may have issues with some programs if they are install to the secondary drives. Just reinstall them
If the license does not transfer just call MS
25 (0.01/day)
Processor i7-6800K
Thanks! I grabbed my license key but had heard some mixed stories of if the free upgrade would let you take your OS to a "New PC" even then I was not sure what would constitute a new pc over a hardware upgrade. I have my MCP and Microsoft still manages to confuse the hell out of me sometimes.
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
What you should do is create a Microsoft account and link it to your Windows 10 installation.
It'll be easier to track and re-use the Windows 10 license, and even if you have it tied to your account you don't have to use the MS Account as a Windows Account, you just tie it to your install through your local account. Pretty easy to do and will help you keep track of your W10 activations.
Click Start > Gear (Setting) > Activation > Add an account.... then login with your MS account.
Depending on the license you have though, if it's OEM, well you might try to be sneaky as they're limited to one hardware install for the life of the hardware...that I won't discuss here.
http://www.windowscentral.com/how-re-activate-windows-10-after-hardware-change
I believe with 1607 they may have stopped accepting Windows 7 keys for install, so unless you have a 1502 ISO and install it without a network connection, that old method won't work anymore. The last time I tried it failed. But upgrading still worked as of 2 weeks ago using the assisted services options, and it was legitimate because my son is disabled and needs visual and audible assistance at times.
25 (0.01/day)
Processor i7-6800K
My license is retail (non oem) so I should have migration. it is also tied to a Microsoft account as well not local.
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
You should be able to get 10 installed then, if for some reason you need a key to install 10 Pro, which you likely will...simply use a Microsoft KMS key which will get you past installing the OS then use your MS account to activate on the new hardware and retire activation on the old hardware.
https://technet.microsoft.com/en-us/library/jj612867(v=ws.11).aspx
25 (0.01/day)
Processor i7-6800K
Appreciate all the help. Its been a while since I've had to migrate an OS over to a new machine so I'm glad Microsoft made it a little "easier" now. Thanks for all the links I did check and my Microsoft account is tied to my login so hopefully I shouldn't run into any issues.
12,333 (2.24/day)
Oregon
If you do just call them. They have said they will honor the retail license on an upgrade to 10
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
I'd also recommend a fresh install
You'll have to enter the key once the new operating system is completely installed you can't do it in the beginning of the process when it asks you because the key was still technically be bound to your original OS. Other than that you're fine
@OP
1,125 (0.36/day)
System Name Team Crimson
Processor AMD FX 8320
Motherboard Gigabyte GA-78LMT-USB3
Cooling Corsair H80i
Memory DDR3 16GB Crucial Ballistix Sport
Video Card(s) Sapphire Nitro+ RX 480 8GB RAM
Storage Samsung 850 EVO 250GB / Crucial MX300 275GB
Display(s) AOC 2752H 27" 1080p
Case NZXT Source 220 Windowed
Power Supply Antec Earthworks 650W
Mouse Logitech M510/ AGPTEK T-90 Zelotes
Keyboard Logitech K360/ iBUYPOWER TTC RED Switch Mechanical
Software Windows 8.1 64 Bit
I too, need visual assistance since I cannot see paying for Win 10.
12,333 (2.24/day)
Oregon
Start your own thread
Info needed: What version of Windows you have (OEM, Retail, Pro, Home) Did it come with a PC you bought or did you buy the retail version of Windows (comes with both 32 bit and 64 bit)
Most likely if you want W 10 your going to have to pay for it
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
I don't think Windows 10 can provide the sort of help you need. :p
