- Jun 2, 2014
- 470 (0.13/day)
- Midwest
System Name | Core |
Processor | Intel 12700k @ 5.1/3.6 no HT |
Motherboard | ASRock z690 Steel Legend |
Cooling | Artic Cooling Freezer 420 AiO |
Memory | GSkill 64GB 3200 cas 14 b die |
Video Card(s) | Asus Nvidia RTX 4070 Super OC |
Storage | Optane 900p x2, SK Hynix p41 Pro |
Display(s) | ACER 250hz 1080p 25" IPS display x2 |
Case | Phanteks p500a with all Noctua Chromax/Arctic fans |
Audio Device(s) | Focusrite interface, Presonus Studio Monitors and Subwoofer |
Power Supply | Seasonic 850w plat with cable mod cables |
Mouse | Glorious Model O |
Keyboard | Corsair mech k65 |
Software | Win 11 Pro |
Benchmark Scores | 3dmark TimeSpy 20240-rtx 3090FE/12700k/Optane 3dmark TimeSpy 21862-rtx 4070Super/12700k/Optane |
First off, I appreciate any help you guys can give. My ISPs router has been failing for two weeks, dropping to 100mbs when it should be 1000mbs. A reset fixes it for now, but its daily.
So I built a router and loaded PFSense, but the only way I can get the WAN on my diy router to connect to the internet is to run network from my ISPs router to my router. Not ideal. I have used the GUI on the ISPs router to copy settings for the fiber internet and applied them in PFSense, but alas, it doesn't connect to the net.
Any PFSense or network masters out there able to lend a hand or send me in the correct direction?
Thanks
DIY router, Intel i7T, 16GB, 250GB, Intel 550 pcie 10gbe x2
Thanks
