Help with ram clocks.
25 (0.01/day)
hi there friends, i have a asus x570 tuf gaming board and g skill ddr4 3600mhz ram, i have an issue, i cant set the ram to its real speed, it runs a 2133mhz, if i ativate D.O.C.P it sets to the real values but the computer dont boot.
18,584 (2.66/day)
System Name AlderLake
Did you check if the ram is on the motherboard QVL?
1,212 (0.62/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
If you mean xmp profile isn't booting try manually setting ram voltage in bios 1.35v for most kits
850 (0.42/day)
Processor Intel i9 13900KS
Motherboard z790 Apex
Cooling LT720 + Phanteks T30
Memory 32GB
Video Card(s) RTX 5090 Astral
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Hx1200i
Mouse G502 X Plus
Keyboard K95 Platinum
Try to set voltages manually. (chipset too)
18,584 (2.66/day)
i checked and in fact my kit is not on the list, what that really means? It won't run faster than 2133mhz?
In that case it's not guaranteed the ram will work at it's rated speed.
Try to set the voltage/timings manually.
3,826 (1.92/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
What model is this Gskill 3600 kit?
25 (0.01/day)
i managed to fix the problem, right frequency and all, my issue now is that if i set it to 3600mhz my sistem becames unstable
5,598 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
Welcome to the Asus world of not so TUF products anymore.. Have you tried running the ram at 3200MHz or 3400MHz and see if that is stable failing that just take the ram back and get a kit that's on the QVL for your mobo these kits are listed as compatible
G.SKILL F4-3600C18D-16GTZRX 16GB(8GB*2) SS SK Hynix 18-22-22-42 1.35V 3600 3600 ●
G.SKILL F4-3600C15D-16GTRSB 16GB(8GB*2) SS Samsung 15-16-16-36 1.35V 3600 3600 ●
G.SKILL F4-3600C16D-16GVKC 16GB(8GB*2) SS SK Hynix 16-19-19-39 1.35V 3600 3600 ●
G.SKILL F4-3600C18D-16GVK 16GB(8GB*2) SS SK Hynix 18-22-22-42 1.35V 3600 3600 ●
G.SKILL F4-3600C14D-16GTZN 16GB(8GB*2) SS Samsung 14-15-15-35 1.4V 3600 3600 ●
tabascosauz
8,219 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
From his other post, it's allegedly a 3600 C19 kit. Which is a whole other can of worms, because the DRAM itself could literally be anything at those loose timings. It could be AFR, but @Fgroia will have to screenshot what Thaiphoon Burner says first.
Try to set the XMP timings but manually instead, and manually set DRAM voltage to 1.35V. That, or try the timings that Ryzen DRAM calculator gives you, but to use the calculator you need to find out what chips you have in Thaiphoon first. Though, if it is Hynix AFR, the calculator doesn't even recommend 3600.
Deleted member 185158
Gah. 1.35v for Cas 19 3600mhz.
No suggestions without screen shots.
tabascosauz
8,219 (2.33/day)
Western Canada
System Name ab┃ob
I think you're too used to B-die, bro. 95% sure this ain't it. lol. 1.35V is the setting for pretty much all XMP profiles. SKUs this loose are usually where G.skill dumps all its miscellaneous trash ICs.
848 (0.35/day)
System Name Batman's CaseLabs Mercury S8 Work Computer
Processor 8086K 5.3Ghz binned delidded by Siliconlottery.com 5.5Ghz 6c12t 5.6Ghz 6c6t on ambient air
Motherboard EVGA Z390 DARK
Cooling Noctua C14S for all overclocking so far Noctua Industrial PWM fan 2000rpm rated (700rpm inaudible)
Memory Gskill Trident Z Royal Silver F4-4600C18D-16GTRS running at 4500Mhz 17-17-17-37 (new mem OC) : )
Video Card(s) AMD WX 4100 Workstation Card (AMD W5400 7nm workstation card coming soon)
Storage Intel Optane 900P 280GB PCIe card as Primary OS drive / (4) Samsung 860Pro 256GB SATA internal
Display(s) Planar 27in 2560x1440 Glossy LG panel with glass bonded to panel for increased clarity
Case CaseLabs Mercury S8 open bench chassis two-tone black front cover with gunmetal frame
Audio Device(s) Creative $25 2.1 speakers lol
Power Supply Seasonic Prime Titanium 700watt fanless
Mouse Logitech MX Master 3 graphite / Glorious Model D matte black / Razer Invicta mousing mat gunmetal
Keyboard HHKB Hybrid Type-S black printed keycaps
Software Work Apps text and statistical
Benchmark Scores Single Thread scores at 5.6Ghz: Cinebench R15 ST - 249 CPU-Z ST - 676 PassMark CPU ST - 3389
that's what Gskill sent me, miscellaneous randomness. :cry:
Where is A-die? :confused:
I don't know what i'm saying, only gots 28hrs left until end of year - end of forum visits. :cry:
Oh haha, I didn't say anything yet. But I agree.
Do have some lower end Hynix. They love Cas 12 at 3000mhz ;)
3,826 (1.92/day)
What exactly have you fixed if you can’t run the kit to rated speed?
Really we can’t suggest anything if we don’t know more details.
Download ThaiphoonBurner
...click the Read button and choose one of the sticks. Take a screenshot and post it here.
Additionally take a screenshot of RyzenMaster where all the info is visible about the CPU, Dram, and all the clocks of the system.
25 (0.01/day)
the picture above is from my system, i tryed the ram at 3000mhz and 3200 and i had no issues, later i will try going up.
3,826 (1.92/day)
Ok, those are some low grade B-dies from Samsung.
When you try 3600 and does not work do you have XMP on or off?
A RyzenMaster screenshot will help for all to see how the settings are now, at 3200 I presume...
25 (0.01/day)
well, today i turned off xmp, set at 3200mhz, no issues. Later i can add a pic of ryzenmaster
thats my ryzenmaster, as far has i tested above 3200mhz the system becames unstable.
3,826 (1.92/day)
Happy New Year!!
Is this the latest version of Ryzen Master? I see some things lack of reporting... as DRAM voltage, SoC voltage and the CPU clocks, the PPT/TDC/EDC limits, Temp...
Should be like this...
Now that you’re at 3200 did you have DRAM voltage auto or manual?
3,826 (1.92/day)
Have you tried XMP on(3600), with manual voltage 1.35 or even 1.4V ? Could help...
7,690 (3.27/day)
California
System Name His & Hers
Storage lots of SSD.
Some R5 3600 can't do 1800mhz on the IF he may need more soc voltage to run stable at 3600mhz even with the crap timings.
@Fgroia if it runs stable at 3200 its most likely the UMC/IF on your 3600 not liking 1800mhz.
25 (0.01/day)
guys perhaps this is a bit late but i am selling the currente ram and would like an advice on the best ddr4 3600mhz 2x8 for the asus tuf gaming x570, using ryzen 5 3600 cpu.
18,115 (2.45/day)
Best, I don't know, but this RAM works very well with Ryzen 3000. I run four sticks at 3800MHz with reasonable timings. It's been going up a bit in price lately though. Note that XMP doesn't work for me, but they're easy to tune manually.
