Help with RAM OC to 1866MHz
438 (0.10/day)
Poland
Processor Intel Core i7-2600k @ 4,4 GHz
Motherboard Asus Maximus V Gene
Cooling Corsair H80i
Memory Corsair Vengeance 16 GB @ 1866 MHz
Video Card(s) EVGA GeForce GTX 980 Superclocked
Storage Corsair SSD Force GT 120 GB & Seagate Desktop SSHD 2TB
Display(s) BenQ XL2420T & BenQ T720
Case Fractal Design Define R5
Power Supply OCZ ZT 650W
Hey
So I have a problem with RAM oc to 1866MHz. On 1600MHz, 1.5V works fine but on 1866, 1.5V, 1.55, 1.58, 1.6, 1.63 and 1.65V didn't work. Computer often shows me BSoD with code 109, 1a, 19, d1 and etc.
The question is: why?
Is the problem in CPU?
I overclock CPU but not now. I'm waiting for water cooler so for now I want oc only RAM.
Can anyone tell my what I doing wrong?
Thanks
~Tintai
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
If your memory is stock at 1866, you should be able to just switch on XMP and it should start working. You may need to loosen up your memory timings because JEDEC DDR3-1600 might have tighter timings than your memory at 1866.
It should work at 1866Mhz @ 9-10-9-27 @ 1.5v.
What are you timings right now at 1600?
7,477 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
hmm is it 2 or 4 sticks? and try with what Aquinus says it sometimes help.
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
438 (0.10/day)
Poland
43,628 (6.37/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Try 1.65v
Those sticks of RAM aren't very good overclockers to begin with. Using four sticks reduces overclock-ability.
2,132 (0.37/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
Loosen timings try 10/10/10/24. those sticks may not be compatable with your board also. look at the vendors QVL list
2,074 (0.45/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
It may be possible to reduce latency by tightening timings and leaving freq. at 1600, but in my experience you get slightly higher throughput and lower latency by getting it stable at 1800 or 1866 with the tightest possible timings and 1.65v. You should run a quick benchmark before & after (such as AIDA64 Cache & Memory benchmark) to see if performance was actually increased. Also memory overclocks work better if the CPU is overclocked.
438 (0.10/day)
Poland
Yes RAM is compatible but on XMP.
Anyway, 38 minutes and no crash. 9-10-9-26.
2,132 (0.37/day)
Chicago burbs
Congrats. Unfortunately not all ram is stable at rated timings. looks like the slight back off did the trick. Now lower the voltage, it may have just been a timing issue...:toast:
438 (0.10/day)
Poland
Thanks. I tested with AIDA64 and there is no problem. For now it works :)
When BSoD appear I change timings to 10-10-10-27. But will see.
Aquinus
Resident Wat-man
13,197 (2.73/day)
Concord, NH, USA
System Name Apollo
Ah okay. You want to OC to 1866 from 1600. The memory isn't rated to 1866. I get it now. Yeah, you might have to work pretty hard to get it to run at 1866Mhz but that really depends on the memory. Some does well some doesn't. Like my G.Skill memory is stock at 9-11-10-28 @ 2133Mhz and I have it running at 10-12-11-30 @ 2400Mhz. You tend to get what you pay for when it comes to memory though. Occasionally you'll get something sexy like those 1.35v low profile Samsung chips. It was pretty amazing to see what those could do.
438 (0.10/day)
Poland
Everything is fine. No crashes, RAM works stable.
