Help with Video Card HelpZotac Geforce GT730 Zone Edition 4gb Pcie16
10 (0.00/day)
Processor I7 2.8
Motherboard Asus P6X58d Premium
Cooling Cooler master
Memory 6g Triple Channel Corsair
Video Card(s) Radeon HD5850
Storage 1 SSD 550 gig 1 1tb
Display(s) Acer 22 inch
Case Corsair
Power Supply ThermalTake TR2 850W
Mouse Razer Death Adder
Keyboard Logitech G15
Software Win 10
Hello, I hope someone can help me. My motherboard is a Asus p6x58d Premium says it has 3 PCIE slots 2 of which can be configured as x16. I am only using 1 card in the 3 slots however my video card is running x8 not x16 according to GPU-Z.
After a stress test it jumps to
. It was originally in slot 1then I tried moving it to slot 2. Initially in the Bios I had to to change it to x16 x1 for slots 2 and 3. I did that but still no change. Running out of things to try. Am I missing something here or is this running x16? Sorry for the newbie question. just trying to figure out what is going on. Any help is greatly appreciated. Bios and Drivers are up the the latest.
OneMoar
There is Always Moar
8,800 (1.64/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
card is so slow its not capable of putting enough load on the buss to get it to spin up to 16x
you can probably disable some of the pcie power management stuff in the bios but you aren't gonna see any improvement a GT730 was pretty awful when it was not its positively useless these days
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Thanks for the reply. So if I am playing a game say 7 days to die would it then spin up to x16?
2,417 (0.40/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
According to the min spec you won't be able to run it anyway. Your video card is so slow that it won't matter what the bus speed is.
Here are the 7 Days to Die System Requirements (Minimum)
  • CPU: 2.4 GHz Dual Core CPU
  • CPU SPEED: Info
  • RAM: 4 GB
  • OS: Windows XP (Service Pack 3)
  • VIDEO CARD: Nvidia GeForce 8800 GTX or ATI Radeon HD 4770
  • PIXEL SHADER: 3.0
  • VERTEX SHADER: 3.0
  • SOUND CARD: Yes
  • FREE DISK SPACE: 1 GB
  • DEDICATED VIDEO RAM: 256 MB
https://www.systemrequirementslab.com/cyri/requirements/7-days-to-die/11924
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Sorry if I am not understanding. I have run 7days to die but it on the lowest setting. So if I have the video card overclocked comparable to the 8800 would that help or is the video card bottlenecking because of the memory interface or the memory bandwidth or is it only running at x8? Just trying to understand what I need to do to make that game and others run smoother. Thank you for your time.
OneMoar
8,800 (1.64/day)
Rochester area
  • CPU SPEED: Info
  • RAM: 4 GB
  • PIXEL SHADER: 3.0
  • SOUND CARD: Yes
it doesn't even run correctly on the recommended specs
its a ddr3 card its just plain slow there is nothing you can do to get more out of that card other then replace it
847 (0.36/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
The card is only wired for x8, you could run it at x4 and not see a difference. Also a 730 is more powerful than a 8800GT guys, not by a lot but it is.
42,684 (6.68/day)
You need a better card, plain and simple.
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Doh!! Thanks everyone for helping me figure this out. Any recommendations for under $150.00??
4,844 (1.51/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
847 (0.36/day)
Haswell, USA
System Name Bruh
Used: RX 580, GTX 1060
New: RX 570
42,684 (6.68/day)
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
United States
OneMoar
8,800 (1.64/day)
Rochester area
42,684 (6.68/day)
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Thermaltake TR2 850W
42,684 (6.68/day)
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
@eidairaman1
I have a question My motherboard pcie is only 2.0 will the Rx 580 still work ? My understanding is it will but not at the 3.0 speed is that correct?
hat
Enthusiast
21,747 (3.29/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Sure it will work. I've been running video cards with newer pci-e revisions than what my slots are for years. I'm running GTX1070s, which are 3.0 cards, in my 2.0 slots right now no problem.
You might want to fill out the rest of your system specs, though.
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Thanks, updated my specs. After the vid card update need to concentrate on ram in my opinion.
hat
Enthusiast
21,747 (3.29/day)
Ohio
6GB is okay, but just barely okay. You can squeak by on 8, but typically 16 is recommended these days. If you could find a 12gb triple channel kit though, I think you would be in real good shape. Also, those 1366 i7 chips were monster overclockers... and for the price of a pizza you can get a 6 core 32nm Xeon that will easily hit 4GHz or more.
If you want to know more, I suggest you pay a visit to the Xeon Owner's Club.
847 (0.36/day)
Haswell, USA
System Name Bruh
Most can hit 4ghz on stock voltage, let alone 4.5+
10 (0.00/day)
Processor I7 2.8
Case Corsair
Software Win 10
Yes currently mine is OC'd to 4GHz at the moment. Runs good.
