- Aug 13, 2009
- 590 (0.11/day)
There are 2 of GIGABYTE laptop brands, AORUS and AERO. AORUS, the premium gaming brand, is focusing on “gaming enthusiasts”;on the other hand, the AERO series laptops are targeting at content creators.
AERO 15, launched last year 2018, was the first laptop targeting at creatives which has high performance as well as ultra-thin screen bezel.
In 2018, the biggest laptop trend is thin bezel, and this year, 2019, the biggest highlight has to be the OLED display which is launched by only 3 brands by now.
In this article we will take a look at one of these 3, AERO 15 OLED, the latest model from GIGABYE AERO series.
First thing we saw was the packaging. With the new “AERO” logo, black and orange color combination, the packaging looks very stylish.
The AERO 15 OLED comes in 2 different colors, black and silver. The one we got is a black one.
This chassis is made of aluminum with a technique called CNC. Most part of it is matte, and there’s a V-shaped decoration with a satin finish below which makes the whole design doesn’t seem too boring.
The AERO logo on the cover will light up when the laptop is on.
The dimension of 15.6” model: 356(W) x 250(D) x 20(H) mm, and the weight is around 2229g.
Considering its solid build quality, the AERO 15 OLED did very well on keeping a portable form factor.
AERO 15 OLED B and C side design. The 2 hinges are on the left and the right.
The biggest opening angle is around 130 degree.
The hinge and overall build quality feels very solid.
The cover will close automatically when the opening angle is less than 30 degree.
B side (display) is one of AERO 15 OLED’s most attractive features.
This 3-side ultra-thin bezel design is the only design currently available that is closest to bezel-less.
There’s a rubber bumper attached to the bezel that protects the display from rubbing against keyboard.
The Samsung AMOLED panel AERO adapted is the high-end spec available now.
AERO 15 OLED is certified with VESA Display HDR 400 True Black as well as Xrite Pantone color calibration certification.
Each and every AERO gets Xrite Pantone color calibration before it leaves the factory to provide you the most accurate colors of Delta E<1.
This display also has TÜV Rheinland Eye Comfort Certification.
All these functions are added to AERO in order to offer best visual performance no matter colors or details.
Dell, Razer and AERO are the first 3 brands that launched OLED laptops. Since these laptops are very new, customers may concern about the burn-in issue.
The AERO 15 OLED applies a special cover on the back of the panel to decrease the using temperature so as to lower the chance of burn-in.
From this we can tell GIGABYTE is a brand that very much focuses on details.
As for the finish, a glossy display may cause noticeable reflections but is able to produce more intense and saturated colors; on the other hand, a matte finish may look plain but certainly not going to reflect.
GIGABYTE goes for the glossy one in order to show the nice details of AMOLED.
Besides the keyboard, on the C side the AERO uses the same matte black aluminum as the cover.
The island style keyboard supports GIGABYTE RGB Fusion 2.0 and per-key RGB backlight.
This keyboard is collaboration GIGABYTE and world’s largest keyboard provider Sunrex.
Considering it’s a membrane keyboard, It acrually offers a nice tactile feedback.
Comparing to GIGABYTE’s other laptop – AORUS 15, this keyboard feels better, almost like the one on Alienware’s high end gaming models.
The webcam is beneath the display, shooting from a lower angle but not too much focusing on your chin…
The camera works smoothly but the resolution could be improved. GIGABYTE designs a cover for it which is rare on laptops and is able to help keep the user’s privacy.
Further beneath the camera is the power button, on its left and right sit the thermal vents.
Below the keyboard is the touchpad which works accurately.
On the upper-left there’s a fingerprint sensor.
There are also stickers for features and hardware specs here.
The one on the left says this laptop is made in Taiwan and the one on the right is about AERO 15 OLED’s features. These stickers are thick and easy to remove.
I/O ports on the left.
From the left: Thermal vent/ HDMI 2.0/ DP1.4 & USB3.1 Gen1/ Audio combo jack/ RJ45 Ethernet port (which supported by Killer Ethernet E2600 and Killer Wi-Fi 6 AX1650.
The AX1650 supports the latest 802.11AX, Wi-Fi 6, that can achieve up to 2.4Gbps.
I/O ports on the right.
From the left: 2x USB3.1 Gen1/ Thunderbolt 3/ SD Card Reader (UHS-II)/ DC-in/ Thermal Vent
AERO has a built-in SD card reader that supports a higher transmitting speed of up to 300 MB/s.
The rear side
Between the 2 hinges is the thermal vent as well as a small “AERO” tag.
The thermal system is called “Supra Cool 2”, which carries dual 71-blade fans, 5 heat pipes and 11 inhale and exhale vents.
According to GIGABYTE the overall cooling performance is 30% better than the former generation.
A huge part of the bottom side consists of a unique shaped cooling vent.
On the both side of the lower part are the speakers. The 94Wh battery is attached to the laptop, not a detachable design.
This thin and light model is equipped with 8C16T i9-9980HK and NVIDIA RTX 2080 Max-Q high-end components. Here we will go through all the benchmarks.
On the right is the Chicony 230W adaptor, the weight is 722 g.
Due to its high-end performance of i9-9980HK and NVIDIA RTX 2080 Max-Q, the AERO needs more power of a big adaptor.
It’s big but is till portable. The laptop comes with a backpack that looks more “business”.
It has a large capacity and lots of pockets for your personal belongings.
GIGABYTE Control Center
The first page “Smart Dashboard” shows the hardware specs and helps you monitor the system.
On the upper right of the desktop is an AI icon.
The Microsoft Azure AI function can detect what app is running and dynamically adjust CPU and GPU’s power settings by accessing/learning the data on Microsoft Azure’s cloud server in order to optimize the hardware usage and make the whole system work more efficiently.
“Manager” is shortcut page where you can turn to other most used functions.
The RGB Fusion 2.0 Per-key backlit keyboard supports 16.7 million colors.
You can turn it off when you are not gaming. As mentioned before, the tactile feedback is very nice.
Besides quiet, normal, gaming and customize, there’s also “deep” setting for the system fans. The “deep” mode allows user to assign different fan speeds to individual temperature.
The fan speed is up to 6000 RPMs.
“Smart Utilities” is where you can find update info, system backup, product description, FAQs…
GIGABYTE Control Center is basically the same as AORUS Control Center.
Although it’s functional and easy to use, we think AERO should have the control center in AERO’s own style.
Nahimic Audio Driver
There are lots of MSI laptops applying this software.
This software has been updated a few times and now carries many functions: it mainly provides 4 different sound fields along with 3 more detailed settings.
AERO 15 OLED comes in with 2 different CPU, i7-9750H and i9-9980HK.
The one with “YA” carries RTX 2080 Max-Q and “XA” is RTX 2070 Max-Q.
In this article we are going to test the “XA”: with i9-9980HK, 8 cores, 16 threads, TDP 45W, 2.4GHz base frequency and 5.0GHz max turbo frequency.
This frequency is a single core highest frequency. Here are some benchmarks with AI functioning and other default settings.
We compared it to the AORUS 15, i7-9750H/ GTX 1660Ti.
*The following () are scores of i7-9750H (6C12T, 2.6~4.5G)
CINEBENCH R15
CPU => 1477 cb (1123 cb)
CPU(Single Core) => 189 cb (183 cb)
CINEBENCH R20.0
CPU => 3212 cb (2208 cb)
CPU(Single Core) => 446 cb (305 cb)
CPUZ 1.89.1
Single Thread => 512.8 (479.6)
8C16T Multi Threads => 4070 (3476.2)
Fritz Chess Benchmark => 47.81 / 22948 (42.97 / 20624)
Geekbench 4
Single-Core Score => 5514 (5278)
Multi-Core Score => 27592 (21049)
FRYRENDER
Running Time => 2m 28s (3m 13s)
x265 Benchmark 2.1.0 => 45.88FPS (37.05FPS)
PCMARK10 => 5253
We can find the difference between Intel 9th gen mobile CPUs (6C12T vs 8C16T).
The creator laptop aims to accelerate video preview and rendering or image/ 3D model processing.
2D image processing requires a lot of CPU power, including how the frequency and number of cores can help accelerate the process.
The benchmarks above includes CPU multitasking and media editing results for your reference.
As for the storage, there are 2 built-in SSD slots and this model is equipped with 2 Intel 760P M.2 PCIe 512G SSD.
SSD benchmark: CrystalDiskMark
Seq Read - 2417.0 MB/s,Write - 1560.1MB/s
AS SSD Benchmark - 2773
Seq Read - 2233.79 MB/s,Write - 1489.70 MB/s
4K - 64Thrd Read - 878.31 MB/s,Write - 811.00 MB/s
Most of the premium models tend to use Samsung or Toshiba SSD, however, GIGABYTE choose to use Intel’s solution.
This Intel 760P SSD supports 3230MB/s read speed and 1625MB/s write speed, which is goof for an M.2 PCIe SSD, plus Intel’s brand image and its SSD product line good reputation,
that’s why GIGABYTE decides to go for Intel SSD and marketing is as “All Intel Inside” – the usage of more Intel components than competitors to provide a more reliable system.
Recently NVIDIA announced its new “RTX Studio laptop”, solutions that’s optimized for creatives.
The RTX studio laptops support “Studio driver”, which can accelerate more than 40 creative applications.
Here are some RTX 2080 Max-Q 3D rendering performance. Driver: NVIDIA STUDIO DRIVER 431.70
SPECviewperf 13
Resolution: 1080p
Resolution: 2160p tested results
We can see from the SPECviewperf 13 result, you can gain more performance while applying 1080p resolution.
SPECworkstation 3.0
Resolution: 3840 x 2160/ GPU: RTX 2080 Max-Q
Geekbench 4
OpenCL Score => 26205
Creator laptops usually need OpenGL or CL performance while running 3D content editing software.
The benchmarks we ran (shown above) are mainly testing OpenGL or CL performance, you might heard some of these apps before.
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FOyZaGRH.jpg&hash=22403a01a8c396e7c6ad1dac181e43eb)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FKCGM5WY.jpg&hash=2a60b3d20625ba8468d2baa93c2fa5ec)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F08tAUxG.jpg&hash=46274b8e0fcdcb8f3ad47a6cc2d6f092)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FVr7iNcq.jpg&hash=e66780a95be0a32c36abfaead2d4b582)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FVc89Irz.jpg&hash=25c2a4d82f1967da986efe2764e93ed9)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FJBCIOUu.jpg&hash=186f8e5667a96bb14985d5adb696aee4)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FzTyAMg7.jpg&hash=b57b789ab8f8a80f6215600a059bce5d)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FPzaHgDZ.jpg&hash=5dedc2a918dfdde3538639bb0bbb9724)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FXArttwO.jpg&hash=24a3e46f78aea958d0da89e53e3f2379)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FQ18QNxa.jpg&hash=3315099c931fe029d041133c553b4b77)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FxntSwgB.jpg&hash=a0ceee32333d996b212dcfa8b8a9933b)
The rear side
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FV8jjusK.jpg&hash=af71e1d853e0b90835c2e8ffca32b8cc)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F1AETMKD.jpg&hash=a89b12eec91baaf327c426f6836d6b1a)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FMUaT8Rc.jpg&hash=a2f2a1617e5ddb4d99dab0a85c5fc182)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FuwwFutG.jpg&hash=740a25e428cacb5942912ae9cd6a554d)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FxvF1Ict.jpg&hash=c7c473c1f5e0156b8d9765d9bbf80af2)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FBVcdyen.jpg&hash=9ad8609e4cea9d67b56d1cedebfda89a)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FgS550kS.jpg&hash=0c6bfbd9a1fb8c921e9c48fdeaf7a6c7)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F9VHoPwA.jpg&hash=978ebff5e6f988867173d3195f675540)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FvJfOHsX.jpg&hash=0e41059f577f01bc201dc33c509933ff)
CINEBENCH R15
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F6JySzPS.jpg&hash=7ef4a3129848877f2bfd1a7544e3bcfb)
CINEBENCH R20.0
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FkpXC49K.jpg&hash=04e917746907d5865458549f0327c1a7)
CPUZ 1.89.1
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FjW9wMEG.jpg&hash=b2c514dd29c81c73c53f5e649c982436)
Geekbench 4
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F8AyjOzO.jpg&hash=4967e7940854b88786ea7c78dfa9b553)
FRYRENDER
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2Fq86nGt6.jpg&hash=0486287df84c34e3085add34a3097af8)
PCMARK10 => 5253
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FS4BJRHU.jpg&hash=da5285ca1a8390c3eaa2f422f5a4265b)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2Fg9sl4wu.jpg&hash=6bec2986bf6596eb51a0aef56e03d9e2)
SPECviewperf 13
Resolution: 1080p
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FB9vnvqX.jpg&hash=c1f92f9bf1f070f5132abe5f2985a5a4)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FOyTJXgZ.jpg&hash=76ed5452152056bcf3ef9dbaef4d0872)
SPECworkstation 3.0
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2F1f4MFtc.jpg&hash=43d9fd7aa755079ca601c3f14a19f9da)
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FjWlcxz6.jpg&hash=12dd35cfc0f547778f24a9071840eff7)
Geekbench 4
![](/forums/proxy.php?image=https%3A%2F%2Fimgur.com%2FUqriOxq.jpg&hash=ba92e8aace7b2bc07499a2890d325a55)
