High Power Also Unveils Astro PT PSUs with Load Meter
47,301 (7.52/day)
High Power also unveiled the Astro PT series of PSUs for gaming and enthusiast PCs. Its showed off a 700W model, featuring a patented LED-based real-time load-meter. Typically, PSUs are most efficient when the load is around half its capacity. This meter updates the user using colorful LEDs: blue for light-load, yellow for the load that's treading into "efficient", and red for high-load/overload. This way, overclockers know if their PSUs are coming in the way of stable CPU and VGA overclocks. The Astro PT 700W PSU is semi modular, with a few important cables being fixed, and sleeved, while redundant cables being modular, and flat. These PSUs boast of 80 Plus Platinum efficiency, feature a single +12V design, and 135 mm golf-surface fan to cool the unit.
statix
4 (0.00/day)
Processor i7-920
Motherboard GB ex58 ud5
Cooling polimatech megahalems
Memory 3x Kingston 2GB 1600 hyperX
Video Card(s) GB 560 ti SOC 950 MHz ver
Storage Hitachi 320GB + 640 GB WD Cav Blk
Display(s) Samsung 940 BG
Case CM Haf X
Audio Device(s) Creative Titanium Fatal1ty Champion
Power Supply CM Silent Pro M 700
shiny :) cool idea
5,572 (0.96/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Gimmick, but hey if we have ram with lights on them, why not right?
FreedomEclipse
~Technological Technocrat~
24,175 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Id rather there be a digital display/readout on the side of the PSU that tells me exactly how much power im pulling. but this is kind of usefull too...
the only s**t thing about it is that everytime you want to look at it you need to pull out your pc or attach a mirror behind it so you can see the reflection which is just stupid as the pulling out of the PC distracts you from what youre supposed to be doing
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
A side panel window should fix the problem
19,372 (3.54/day)
This is less of a gimmick than ram LEDs :rolleyes:...but still a gimmick. A lot of people want to know/curious about their power consumption.
FreedomEclipse
24,175 (3.74/day)
London,UK
Not if the lights are on the back it doesnt... Look more closely at the pic. Unless you have a nasty habit of mounting your PSU the wrong way, In which case you are either a genius or just plan retarded.
(the Kettle lead always goes in from the back!!)
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
This PSU is perfect for the Pantyhoser:
Besides it and the small number of actual cases with frontal PSU mounting , my guess it that this PSU would be primarily used in tech benches.
specks
440 (0.09/day)
Software WinXp
My bad.
