High VRM temp makes OC unstable
983 (0.21/day)
Memory 2x24gb Gskill 8800c38
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
My z390 prime a vrm hits 90c during stress test while my cpu stays 70c-75c. Does it cause my oc unstable? I don't see any option to water cool it. Do put a vrm fan help or just buy a new mobo?
26,119 (6.47/day)
Those temps for VRMs are fine. Most VRMs, even the low quality ones, can withstand 130C nominal and 160C spikes without damage. However, mounting a heatsink/fan to them can't hurt.
3,050 (1.71/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (378W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
First you spend 5~15$ for a fan over VRM, and if not work then spend, X10~20 the amount of fan money for a new board...
6,087 (2.84/day)
California
System Name His & Hers
Storage lots of SSD.
Seems the board is just pretty meh vrm wise for a 9900k
4 phase with 8 45 amp power stages. The Maximus Hero/Code/Formula all have pretty weak Vrms compared to other similarly priced high end boards as well.
Not sure about if that's enough to make your OC unstable but on boards with shittier vrms you sometimes need more vcore to keep a stable overclock on high wattage chips.
5.2ghz is pretty difficult even on a KS chip according to silicon lottery depending on the type of workloads you're running.
Also if you're not crashing I wouldn't worry about it unless you were hitting 110C under heavy load on the VRMs
814 (0.48/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
You really should have bought a better board for the 9900KS, but it is still fine to use this board as long as no problem occurs, though the service life of the board might be shorter.
You can put a fan to help cool it if you want
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
I passed 8hr of realbench, 1hr occt large with avx , but fail occt linpack 2019 within 10m. Im so lazy to buy a new board coz I need to drain the whole loop then install 2tb games.
6,087 (2.84/day)
California
What are you primarily using your pc for?
Also are you stable at 5.1ghz in occt linpack 2019? You may just need an avx offset of like 2-300Mhz
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
Stable 5.1 with linpack. I just game.
40,806 (6.55/day)
6,087 (2.84/day)
California
636 (0.15/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
The difference between 5.1GHz and 5.2GHz for anything outside of benchmarking, is very minimal.
Save yourself the mental ache and be happy with your totally stable 5.1GHz and call it a day - unless you wish to shove ungodly amounts of voltage at the CPU or spend money on a new board and get to draining that loop and maybe gaining 100MHz for your money/effort - keep what you have and smile. :toast:
326 (0.19/day)
Nuremberg
Processor Core i7 8700K@5 GHz
Motherboard MSI Z370 Gaming Pro Carbon
Cooling 2xEKWB Rads, EKWB Reservoir 250, Aqua Computer Kryos Next CPU Cooler, Phanteks Glacier GPU Cooler
Memory 16 GB DDR4 GSkill Trident Z 3200
Video Card(s) Asus ROG STRIX RTX 2080 O8G (GPU@2115 MHz/VRAM@7800MHz)
Storage 1x Samsung Evo 840 SSD 256, 1x WD Blue 1 TB HDD
Display(s) Asus ROG Swift PG248 1080p Display/144Hz/G-Sync
Case Fractal Design R6 with Window
Audio Device(s) Realtek onboard
Power Supply be quiet 650W Straight Power
Keyboard Cherry KB
Benchmark Scores FireStrike: 25953/Extreme: 13141/Ultra: 7099/TimeSpy: 11426/Superposition: 7667/CinebenchR20: 3916
If it‘s only in Linpack and use case is gaming then there is no problem as you are stable during gameplay. What is the problem in Linpack, does CPU throttle or do you get blue screens or error messages? Usually most boards throttle down cpu if vrm gets too hot to avoid damaging vrm. If your cpu run Full Speed and Linpack fails it‘s rather a problem with too low voltage to get stable there. Also worth to take into account is that mosfets can‘t handle their max capable current over the whole temperature curve. The hotter they get the less capable they are with current load, so active cooling would rise their current capability. A rear fan intake lowers vrm temps up to 10C according to measurements.
19,368 (3.64/day)
1. Those vrm temps are fine. Cooler is always better. Spot cool and/or replace thermal pads.
2. Why are you stress testing with multiple tests?? Passing two but not a third (which that third is overkill). Is your pc mission critical status? You say you just game so... pick a test, I like aida64 for my uses, and run a stress test for a few/several hours. If it passes, chances are you will be fine to simply game.
PS- love the passive aggressive lol emoji trolling in the first post...
2,219 (1.07/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
stick a small fan on it, my vrm is pants with fan it stops in the 70s on high load.
mines holded on with double sided tape.
FreedomEclipse
~Technological Technocrat~
23,619 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Look for something like an Antec Spotcool
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
I put a 120mm fan which run max speed and blow to those vrm area. Temp never has a chance to crack 65c. The problem is I think my pc is freaking loud.
40,806 (6.55/day)
Get water cooling or a potentiometer
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
There is no monoblock option for my mobo.
40,806 (6.55/day)
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
Which one fit my asus z390 prime a?
tabascosauz
7,902 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
We all appreciate your work, but you can't just throw lmgtfy at other people without yourself understanding an ounce of what you're actually suggesting. Those aren't monoblocks, and neither do any of those board-specific MOSFET blocks work on his board.
@mrthanhnguyen It's a 9900K @ 5.2GHz and your VRM isn't the greatest around (neither is it the worst). The only way to get around it is to have airflow over the heatsink, which you are already doing. Try and find a quieter fan, rearrange the airflow to work without the extra fan, or use fan control...you can't have everything at the same time.
40,806 (6.55/day)
Ask EK, sometimes we have to adapt and overcome challenges that is why ASepoxy mixed with as5 is a solution...
1,586 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
VRMs will be much cooler with a 5GHz clock vs 5.2GHz, you can lower voltage and consumption/heat will drop a lot. Performancewise there is very little difference in games. If you use a 240Hz monitor and game at medium settings fullHD with a mid range or better GPU then you might lose a few frames, but in most scenarios it won't make a diffetence.
21,593 (6.00/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
Drop 100mhz and forget about it.
The board won't give you much more, so back down so you get assurance of a stable setup, and start gaming.
