Hight temp on idle(65-70°C) or just normal ? 7800x3d + 360mm aio
81 (0.32/day)
Processor Ryzen 7 7800X3D
Motherboard Asus rog b650e-f
Cooling Corsair h150i 360mm
Memory Kingston beast 6000mhz cl36 32gb
Video Card(s) Gigabyte eagle RTX 4070 12gb
Storage SSD PCIe Gen4 m2 Predator GM7000 2tb
Display(s) Msi Optix magcqr 32 1440p 144hz
Power Supply Seasonic SSR-750FX Plus GOLD
Software W11
Hi All ,
I just build a new system with a ryzen 7 7800x3d and a cooler corsair h150i 360mm and my idle temps are the same as when i play games , they around 60°C and 70°C degrees Celsius which for me seems a bit high for just being browsing for example. For gaming temps are the same , i saw for PUBG max 79°C and normally is around 65°C and 70°C but while doing nothing or maybe just like browsing at the internet the temps are the same ( now for example at the time im writing the temps are 67°C ) and this is whit the corsair cooler at max speed , if put it at minimum speeds temps are very similar as well but a bit high , like 3 or 6 degrees more .
The case flow is 3 front 120mm fan air in , two 140mm bottoms air in , one 140mm back air out and the corsair cooler sending air out from the top.
I re applied 3 times the thermal paste ( Thermal Grizzly Hydronaut) and the 3 times the same behavior.
Is this normal or something isn't good with my build ( maybe the cooler is failing , doesnt seem from what i see at Corsair ICUE) ?
Thank you very much in advance!
ir_cow
4,253 (0.72/day)
USA
Max. Operating Temperature (Tjmax) 89°C. You are good.
The non-x3d is 95c.
Edit: I didn't see that those were idle temps.
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Motherboard Gigabyte X470 AORUS ULTRA GAMING
Cooling Corsair H100i
Memory 32 GB Team Force DDR4 3200 CL16
Video Card(s) Power Color RX 7900 XT Red Devil
Storage 2x 1TB SSD / NVME
Display(s) AOpen 27in 1440p 170hz (27HC5UR)
Case Modified Corsair 540 Air
Audio Device(s) Logitech G35 / Corsair HS80
Power Supply EVGA 850GQ
Mouse Corsair M65
Keyboard Corsair Strafe Silent
Software Win 11 Home (Modded)
Benchmark Scores It will beat a snail in a down hill race.
Have you undervolted the chip with PBO2 Tuner?
3,024 (2.52/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Display(s) LG 27UL850W (4K@60Hz IPS)
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.5 (with latest patches)
No consumer CPU should be idling at those temperatures under a 360mm AIO.
The likely culprits are:
  • improperly mounted or tightened waterblock
  • improperly applied thermal paste (too little, too much, unevenly spread)
  • protective plastic sticker not removed from waterblock
It's possible that it could be a combination of some or all of the above. It could be something else. Fairly recently, someone else here had a similar issue with a 280mm AIO (which roughly has the same cooling capacity as a 360mm AIO) so this is a fairly frequent occurrence.
The fact that your gaming temperatures are the same as your idle temperatures also points to an improperly mounted AIO.
Remove the waterblock, inspect, repaste and try again. If that doesn't work, have a local PC repair shop or someone more dextrous do the work.
Best of luck.
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
That or there air trapped in the pump. Or the pump isnt spinning.
3,024 (2.52/day)
If the pump isn't spinning, the CPU will redline in a couple of minutes at idle. It's not that, OP is gaming at the same temps.
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Then it has to have an air bubble trapped in it.
1,045 (1.90/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
Hi All ,
Holy smokes, those idle temps are off the charts ! Im using the same cpu and aio, and idle at 35-40c.
Im thinking you might either be screwing it too tight, or not tight enough - i know it's super hard to tell, as corsairs amd bracket is quite bad, with no points that shows you when you have screwed it in the correct amount.
Or it could be your method of tim application possibly not giving sufficient coverage, or possibly airbubbles.
Or it could be a defective pump in your aio.
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Load up iQue from Corsair and set the pump to Extreme.
The only Corair AIO's I have played with are all old models, except my sons, and I just did what I would do with this old one. Ran the nuts down to the bottom, hand tight, then a quarter turn.. Personally, I think people baby their computer parts to much. I remember have to put a sping loaded monster onto my 486 DX4 100, NO IHS on those, one slip up and your CPU went bye bye.. With these IHS, pfft.. set it on, run the screws down.. give it a little twist..
freeagent
8,214 (3.72/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
My 58X3D idles in the mid 20s with a quiet fan profile..
3,024 (2.52/day)
An air bubble in the AIO loop will not cause a +20°C increase in idle temperature. The liquid coolant will flow past the air bubble anyhow.
And the air bubbles would quickly work their way to the top-mounted radiator in minutes.
I have a Ryzen 5800X + Arctic Liquid Freezer 360mm AIO idling at 25°C right now (radiator fans at 550 rpm). Even if the 7800X3D draws a little more power, it still should be idling around 30-40°C.
1,045 (1.90/day)
Software Win10 pro
That's the issue, you can't do that with this cooler - you will completely bend the bracket if you try to screw it all the way down.
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
yeah.. but we dont know its top mounted. He could have put it on the bottom for all we know
3,024 (2.52/day)
But we do know.
Read the original post:
"... and the corsair cooler sending air out from the top."
329 (1.29/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
But we do know.
Yeah.. he did say that didnt he.. It does sound like there is a peel before use sticker or a plastic ring around his cooler base.
81 (0.32/day)
Software W11
Hi All ,
Thank you very much for all your answers and recommendations! Like i said is the third time re installing the cooler , i always put like a drop of water , no more than that , probably little less i can say. Isnt my first time building a pc , but just for the sake of trying i will use the plastic mini spatula that comes with the thermal paste and distribute the paste on the cpu and see if that helps. Or maybe im just screwing it to tight , im one of those person that tries to tighten the screws as much as possible but hard to tell if thats good or not .
The water block had a plastic cover on it , i removed that one and also removed the thermal past that came pre applied and put the Hydronaout
Either way i will try one more time distributing the thermal paste and see what happens , weird thing for me is that the temps are the same not matter what i do , one would thing that while gaming temps should be a lot higher
3,762 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
This is classic bad mounting.
74 (0.06/day)
System Name Main
Motherboard AsRock B650M Pro RS
Memory 2x16GB G.Skill FlareX 6000MT/s CL30
Video Card(s) Asus RX 6600 XT Dual OC
Storage Samsung 970 Evo 500GB + Crucial MX500 2TB
Display(s) AOC C24G1 + Lenovo L24-i10
Case Deepcool CH370 White + 6x Arctic P12 + 2x Arctic P14
Audio Device(s) Beyerdynamic DT770 Pro 80 Ohm + Fifine T669 Condenser Mic
Power Supply SeaSonic Focus GX-850 + sleeved extensions
Mouse Logitech G Pro Superlight
Keyboard Logitech G Pro KDA w/ GX Brown
Software W10 64bit Home | Linux Mint Cinnamon
As several other 7X3D owners have said, definitely not normal temps. I'm getting high 20s/low 30s °C during idle with just a regular degular dual 120 tower cooler. You could try tilting the PC side to side ~45° while it's on, if there are any air bubbles stuck somewhere, that can help dislodge them. Helped me massively when I did a hardline build. I'd also verify that the pump is indeed pumping, i.e. gently holding/squeezing the tubing to feel whether it feels like liquid is moving through them. I've seen it before where AIOs have been "all wired up" just for the pump block header not to be connected, thus leaving only the fans spinning. Even more deceptive when the block's RGB was hooked up and working :D
1,045 (1.90/day)
Software Win10 pro
Hi All ,
Im willing to bet that's the issue. One little drop is very unlikely to be evenly spread across the entire heatspreader.
I find what works best is first spreading a layer across the entire heatspreader, and then afterwards place a pea sized drop in the middle - it should ensure there is full coverage and no airbubbles :)
Tatty_Two
Gone Fishing
25,889 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
Hi All ,
I used to be the same and I too sometimes had issues, so now I tighten them as tight as they will go (without forcing them) and then when I have done them all, release each one half a turn of my screwdriver, no issues since.
HTC
4,656 (0.77/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
I have ZERO experience with AIOs, but i thought of something: could it be the temp reader reporting wrong temps?
You didn't mention how you got the temps reading: BIOS? HWinfo? Other?
81 (0.32/day)
Software W11
I use HWInfo , core temps and ICUE from corsair
  • Like
Reactions: HTC
81 (0.32/day)
Software W11
I think the thermal paste was right applied or maybe to much , i leave some pictures
2,172 (1.27/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
If you're certain your mount is gtg it's time to seriously consider replacing that aio. Pump may be dead or dieing. It may be clogged up.
Can you feel or hear the pump running?
Does one of the tubes coming off of the block feel excessively hot to the touch?
Is it connected to the pump header on your mb?
