HIS X1950 Pro ICEq3 Turbo 512mb AGP Dead??
2,330 (0.36/day)
Australia
System Name All Ryze
Processor Ryzen 7 1700
Motherboard MSI X370 Pro Carbon
Cooling Air
Memory G-skill Flare x 16GB 2400MHz
Video Card(s) MSI 1080
Storage Intel 600p NVMe 512GB for OS , 1TB WD Black and a 4TB Toshiba
Display(s) BENQ PD3200U
Case Phanteks
Power Supply Corsair 750W
Mouse Logitech G403 wired
Keyboard G19
:eek: I came home from work today and decided to play a little BF2
:eek:
As you can see I was not at all inpressed with the graphics.
:eek:
So I uninstalled the 7.6 drivers and re-start system.
It will not display post!:eek: Card is only 1 month old:twitch:
Luckily I have also onboard so connect that. Motherboard is brand new ( put in at the same time as the card) I cleaned with CC Cleaner and Driver sweeper even though I knew that it wouldnt do any good AS IT WONT DISPLAY POST SCREEN:(
Is she buggered??
6,959 (1.04/day)
Australia, Sydney
Um tell us properly please, anyway, you should have just posted this in the clubhouse instead of posting it here. GPU POSSIBLY dead, RMA or even refund it if possible, and grab yourself a new mobo :).
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
I am thinking the memory died in it?
It wont switch on the display when turning on the pc.
Cannot even get to see the post screen.
It powers up red light goes out fan spins.
Is that telling it properly.
The specs are on my system specs.
I guess I will switch over to pci e sooner than I thought:0
mortal
151 (0.02/day)
Croatia - Umag
Processor q6600 G0 @ 3400 1,30V
Motherboard DFI LP T2R P35
Cooling Sonic tower @ 40C
Memory 2x1024 Team Elite 4 4 4 12 @ 850mhz
Video Card(s) x1950xtx @ vf-900
Storage Segate 500GB server edition
Display(s) Hanns-g
Case Chieftec LCX Big tower
Audio Device(s) Hercules Muse
Power Supply Silwerstone Strider 560W 12.01-12,04V
Lower down GDDR mhz. even below manofacture clock, and then try. Those are normal artifacts which appear on hight ddr clock
276 (0.04/day)
Brunei Darussalam
System Name E3 3.0
Processor Intel Core i7 6700
Motherboard Asus Maximus IX Apex
Cooling Corsair H5 SF Low Profile Cooler
Memory Corsair CMK32G4M2E3200C16
Video Card(s) ZOTAC GeForce GTX 1070 Ti
Storage 500GB SSD | 2 TB HDD
Display(s) 19" Acer + 30" MSI MAG301CR2
Case Corsair 460X Crystal Case
Power Supply Seasonic Focus Plus GX-850
i had weird artifacts before with my pc x1950 pro, but i ended up fixing it by lowering my o/c. maybe you o/c ?
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
I had Ati tool installed but was using the standard clock.
It will not even switch on my LCD Now
7,662 (1.18/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
4,815 (0.75/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
What I can see is definitley GPU artifacting.
Did a bit of a study on artifacting when trying to figure out what the lines were on my screen which turned out to be the monitor.
Fortunately for me my Sapphire X1950pro 512mb AGP is still going strong.
Looks like mobo and GPU upgrade?
Perhaps a HIS X1950pro PCI-E this time? lol
Better luck this time round.
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
had the same thing happen to me but on 3dmarks FPS just would drop so i turned the computer off and checked to make sure it was in the slot ok and the power was in all the way and it would show the post and just beep(think long beep) i had to RMA but i got a refund because they didn't sell the card anymore.It was only 2 weeks old also a HIS but it was PCI-e
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
I am just a little peeved about it but you get that.
But at least I am putting together a better setup so when this mess gets sorted out I will have a X1950 Pro for sale.
Anyone used the MSI p965 Platinum before is it anygood?
4,815 (0.75/day)
Wangas, New Zealand
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
you said vi(pukes) aaaaaaa. jk What i like about via is that there chip-set runs cooler than nvidia and ATI i wouldn't buy one for a rig that i would want to do alot of ocing.
4,815 (0.75/day)
Wangas, New Zealand
I cannot find were it says about a BIOS update except for the intel chipset. But I have a VIA chipset.
The link is about the intel chipset for the MSI motherboard you were talking about.
pos pc seems to be correct since my motherboard is also terrible for overclocking.
I was a bit iffy about choosing this motherboard since it just didn't add up.
"Overclockers motherboard. . . . . VIA chipset.":wtf:
BIOS also reads temps which are too high but from what I have read it's a AV8 issue with certain CPU's and not pointed directly at the VIA chipset.
I'm unsure what caused the death of you GPU.
Apparently there more threads about people having issues with these cards than any other because they are very popular.
Back in the day when the X800pro came out which was also a very popular card, I don't recall this many threads about it dying though. . . .
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
When my x1950pro went i could underclock it and still nothing.
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
did you ever get the answer to what the jumpers are for?
43,619 (6.43/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
for ntsc/pal.
p_o_s_pc
F@H&WCG addict
13,006 (2.00/day)
Newark ohio
2,330 (0.36/day)
Australia
Cooling Air
Case Phanteks
Keyboard G19
sorry this isn't my thread and this maybe a n00b question but what teh hell is ntsc/pal?
lol
I thought I was the only Noobie in here, Its like region setting
I sort of have it going now but have missing icons on desktop with any driver installed.
I used the analog dongle and it switch on my lcd
I was using the digital when it went.
