HOT RYZEN 9 5950X TOO HOT?
411 (0.25/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
My Gamer, built for MS Flight Simulator 2020, is buttery smooth running the defaults. Installed 'Core Temp' 1.17.1 and it's reporting a steady 80º C when flying. The CPU is paired with Noctua NH-D15 Chromax with dual fans. It's been suggested to try re-paste the heatsink before going AIO liquid and possibly having to change the case too. Thoughts and experiences?
540 (0.12/day)
Processor AMD Ryzen R7 5800x
Motherboard B550i Aorus Pro AX
Cooling Custom Cooling
Memory 32Gb Patriot Viper 3600 RGB
Video Card(s) MSI RTX 3080 Ventus Trio OC
Storage Samsung 960 EVO
Display(s) Specterpro 34uw100
Case SSUPD Meshlicious
Power Supply Cooler Master V750 Gold SFX
Mouse Glorious Model D Wireless
Keyboard Ducky One 2
VR HMD Quest 2
Software Windows 11 64bit
That's normal as that is a CPU heavy game. And no, an AIO is not "better" than the NH-D15. You can try tweaking the curve optimizer.
411 (0.25/day)
Texass
I presume the "curve optimizer" in the BIOS? Otherwise known as EZ System Tuning in ASUS UEFI BIOS Set to Normal. CPU @ idle 32º C.
540 (0.12/day)
VR HMD Quest 2
Yes, it is in the bios. I don't have an ASUS board but it usually is in the PBO settings in the bios. With the right dial you can overclock it and undervolt it at the same time.
456 (0.12/day)
System Name Desktop / "Console"
Processor Ryzen 5950X / Ryzen 5800X
Motherboard Asus X570 Hero / Asus X570-i
Cooling EK AIO Elite 280 / Cryorig C1
Memory 32GB Gskill Trident DDR4-3600 CL16 / 16GB Crucial Ballistix DDR4-3600 CL16
Video Card(s) RTX 4090 FE / RTX 2080ti FE
Storage 1TB Samsung 980 Pro, 1TB Sabrent Rocket 4 Plus NVME / 1TB Sabrent Rocket 4 NVME, 1TB Intel 660P
Display(s) Alienware AW3423DW / LG 65CX Oled
Case Lian Li O11 Mini / Sliger CL530 Conswole
Audio Device(s) Sony AVR, SVS speakers & subs / Marantz AVR, SVS speakers & subs
Power Supply ROG Loki 1000 / Silverstone SX800
VR HMD Quest 3
A repaste/reseating of the cooler is never a bad idea just to eliminate that variable. Don't get too wrapped up in the brand of paste or trying to find the absolute (claimed) lowest temp, but make sure you're getting one that spreads easily and evenly. Some times you can have the "best" paste but not the best temps due to it being hard to work with. Beyond that though, we would need a little more info on your setup. Case? number and orientation of fans? gpu?
I have a 5950X with a 280mm AIO, and I'm in the 60's during gaming. The cooler you have should be more than fine, it is the best air cooler on the market and regularly holds its own against 240 aio's. Assuming you do have a good mount/paste, I would first look at your fan speed/curve and make sure you're not just simply running it too slow for the given load. I see you are using an ASUS board, which I do as well. I use the Fan Expert software that comes with it to automatically set my curves, and then adjust if needed for more silence or more cooling. Then I would look at case air flow and determine if you're getting sufficient cool air to the cpu cooler. Also, if you're running a high wattage GPU then look again at the flow though your case and determine if you are exhausting that hot air efficiently or just recycling it through your cpu cooler. There are many things that could be contributing, but that's where I'd start.
411 (0.25/day)
Texass
Well... I changed my Memory speed D.O.C.P. from default @ 2666 MHz to 3200 MHz. and the temperature changed??
Can't figure that out???
Corsair case Obsidian 450D has 2 x 140MM be quiets in front intake and one Noctua 140 MM intake on the bottom. Has 3 x 120MM (2 x be quiets and 1 Noctua) for top exhaust and 1 x be quiet 120MM exhaust fan rear, in-line with the 140MM Noctua HS Fan on the After cooling fins and a 120MM be quiet fan on the Forward cooling fins pushing air aft to the rear exhaust.
[url=https://imgur.com/cqaUATN] [/URL]
[url=https://imgur.com/oJoM38V] [/URL]
[url=https://imgur.com/ppvWv3X] [/URL]
29,100 (6.86/day)
Pictures of the case would be helpful. Reapplying your TIM(heatsink compound) couldn't hurt. With a CPU like that, you need a big case with lots of airflow for that heatsink to be effective. Otherwise liquid cooling with at least a 240mm rad is the way to go.
411 (0.25/day)
Texass
Pics posted above.
456 (0.12/day)
VR HMD Quest 3
To me it doesn't seem like the CPU would be getting choked for air just judging by the number of fans and the case you have. Again I guess I would be looking into fan speeds/curves of your front intake fans and the cpu cooler fans and just making sure you're putting enough flow through the case. Also I see you're running a 3090 which definitely puts out some serious heat. Have you tried playing with your case side panel off? You have 3 fans exhausting on top so I'm guessing that could possibly be encouraging airflow out of the gpu heatsink upwards and around your cpu cooler. Perhaps if you try with the panel off and let that beast exhaust all of the hot air outside the case instead of circulating it through the case you may see a difference. This again to just start eliminating the easy to test possibilities. It may just be the combo of a cpu intensive game, and a whole lot of heat inside the case from the gpu, requiring a lot more work/higher rpms from your case fans and cpu cooler.
I jumped on GamePass to grab FS and try it myself to give you a more apples to apples comparison on my temps, but at 152GB :twitch: download it's ganna be tomorrow evening before I can try it out... my 50mb/s connection is crying at the moment. I just got the AirLink setup on my Oculus up and running and have been looking for some new things to try out, and I'm betting this sim looks incredible in VR.
1,789 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
80C isn't bad for your setup for FS2020. That CPU will basically turbo its clocks up hard until about 90C or a power limit is reached, and that is by design, and that game is a real CPU eater. I bet it performs very well though compared to most modern rigs which really struggle to run FS2020.
17,577 (4.66/day)
System Name Patient King of Finding Good Sales
Processor 7800X3D -25 all core ($196)
Motherboard B650 Steel Legend ($169)
Cooling Frost Commander 140 ($42)
Memory 32gb ddr5 (2x16) cl 30 6000 ($80)
Video Card(s) Merc 310 7900 XT @3100 core $(705) (July 2023)
Display(s) Agon 27" QD-OLED Glossy 240hz 1440p ($399)
Case NZXT H710 (Red/Black) ($60)
Power Supply Corsair RM850x Gold ($109)
yep, if it were my rig, i would just adjust the noctua fan settings to be a bit more aggressive in the BIOS. that alone will prob bring it down to 75. (if you don't mind the extra noise when at full load)
60 (0.04/day)
System Name TR7970X
Processor ThreadRipper 7970x
Motherboard Asus TRX50 Sage
Cooling Noctua TR5 140
Memory 4x Color 5600Mhz x 64GB total 256GB
Video Card(s) Asus RTX 4090
Storage Sabrent 4TB Rocket Plus
Display(s) LG 5120x1440 49"
Case Thermaltake Core W200 BEAST AKA MINI FRIDGE :)
Audio Device(s) Creative SB AE-9
Power Supply Rosewill 1600 Watt Gold
Keyboard Mountain Modular System with media Dock
VR HMD Quest 3
Benchmark Scores NA
I would also request some zoomed out pictures, it might just be me but it doesn't seem very flow optimized in there. What size is your case?
17,577 (4.66/day)
woops, I forgot, not just the fans on the Noctua, but also adjust the fan curve on the exhaust fans. i have mine set very aggressive... and my temps stay very cold. you would be surprised how much a stronger fan curve can accomplish.
411 (0.25/day)
Texass
29,100 (6.86/day)
That looks like good airflow. So you're likely just pushing the CPU to it's max and it's hitting it's upper temp range. If it starts thermal throttling, look into some better cooling. Otherwise you're alright, IMHO.
tabascosauz
8,219 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Use either HWInfo or Ryzen Master for temps on Ryzen. CoreTemp and HWMonitor are pretty pointless for Ryzen as they can only read the fan control-bound Tctl/Tdie which doesn't tell the whole story of what's going on between your 2 CCDs.
As for airflow, those Shadow Wings fans don't really push much air or have much rpm range either. You might get slightly better performance by replacing the Be Quiet fan on the cooler with another NF-A15, but it's more a recommendation than an actual problem.
But honestly it's normal, the 5900X and 5950X make aggressive use of their 90C throttle limit. Usually get pretty hot in 1- or 2-core loads - so, demanding games basically, not uncommon to see a game pull 15-16W each out of your best 2 cores and reach 80-85C on air despite generally low power draw. Multi-core temps (so, benchmarks) on these two chips is actually pretty tame as long as you have PBO disabled, I'm guessing you probably sit around just 70C in Cinebench.
Ryzen 5000 can reach wildly different temps in "gaming" depending on what you're playing, so take opinions on "gaming temps" with a grain of salt. Something less demanding sees like 65-70C average on my 5900X, while demanding games can reach 85C on warmer days. Conversely, I can play older games from say 2005 and some of them also keep the CPU pegged at 80C, because they're almost entirely CPU-bound from being so old.
43,619 (6.43/day)
Memory 32GB G.Skill 6000Mhz
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Was it for the better or worse? If the temps went up, it's most likely due to increased load/voltage on the memory controller.
411 (0.25/day)
Texass
CPU temp went down. Now I'm seeing low 50's and collaborated by other software. ??
My new ETEKCITY Infrared Thermometer reports 78º F Intake and 106º F Exhaust air temps. The 3DMark time Spy tests never showed over 62º C in the CPU during tests. So original temps were erroneous or the change in memory speed helped. The exhaust fan turns full blast @1800 RPM. The Core Temp now reports 51-53º C last night while flying the Turboprop French Daher 930 TBM. Looks better now. :banghead:
[url=https://imgur.com/1Umqwrw] [/URL]
Ryzen Master
60 (0.04/day)
System Name TR7970X
VR HMD Quest 3
Benchmark Scores NA
OK, well , WOW that CPU cooler is just massive !, I honestly thought this might be an MATX or ITX configuration with the initial pictures.
You seem to have adequate intake but I wonder if the backside exhaust doesn't get a bit overwhelmed due to the limited clearance.
Even with that you shouldn't be running so hot.
I just got one of the Ice Giant coolers myself, it would likely be about the same size as your current solution but according to LTT even the Engineering sample of that particular unit
might be what you are looking for. I haven't deployed it yet but according to the testing of the engineering sample by Linus the unit actually "BEAT" a 360MM Liquid cooling system.
You might want to consider a bigger case if you go that direction.
the costs are not terrible for the Ice Giant solution either. About $169.00, they had some issues with getting it out the door, but seem to have deliveries in under 30 days shipping now.
1,196 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Well temps seems fine to me - but why the fan grill on the intake on the cpu cooler and the out take behind?
738 (0.42/day)
Processor Intel i7 13900K
Motherboard Asus ROG Strix Z690-E Gaming
Cooling Arctic Freezer II 360
Memory 32 Gb Kingston Fury Renegade 6400 C32
Video Card(s) PNY RTX 4080 XLR8 OC
Storage 1 TB Samsung 970 EVO + 1 TB Samsung 970 EVO Plus + 2 TB Samsung 870
Display(s) Asus TUF Gaming VG27AQL1A + Samsung C24RG50
Case Corsair 5000D Airflow
Power Supply EVGA G6 850W
Keyboard Razer Huntsman Elite
Benchmark Scores 3dMark TimeSpy - 26698 Cinebench R23 2258/40751
Normal ? Using FS 2020 with my 5900X I'm not going over 70/71° :wtf:
I don't think the 5950X is very different, temperature wise.
do you remember the game you were playing when read 80° ?
Because I never saw anything like that, playing quite a few different games.
60 (0.04/day)
System Name TR7970X
VR HMD Quest 3
Benchmark Scores NA
TDP wise they are rated the same, 105 Watts, however in testing its been found that the 5950x can draw about 145 watts.
738 (0.42/day)
there is little difference between 5900X and 5950X. Surely not 10° if properly cooled.
60 (0.04/day)
System Name TR7970X
VR HMD Quest 3
Benchmark Scores NA
I would agree with that, the only difference is one more chiplet, 4x more cores, I wish I had more performance data regarding the cooler he is using though.
738 (0.42/day)
yep.
I'm using a Noctua DH15
