How to manually adjust pump speed on a nzxt kraken x63
1,954 (0.43/day)
Denmark
Processor Ryzen 7 7700
Motherboard Asrock B650 PG LIgtning
Cooling artic freezer 36
Memory G.Skill Flare X5 DDR5-6000 - 32GB - CL30
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Marantz PM 6007 Triangle Esprit Titus Ez
Power Supply Corsair RM850X White
Mouse Logitech G PRO Superlight
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free bitdefender
How do i manually adjust the pump speed on a nzxt kraken x63, i can set it to silent in the cam software just under 1900 rpm as the lowest but how do i manually adjust it, custom setting in the cam software doesn't give me the option to adjust pump speed.
On silent i can't adjust it in the bios msi z490 a-pro, do i have to choose custom and then go in to the bios ?
2,644 (0.56/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Well, I have a Lamptron fan controller and used to hook my Kraken up there for manual control, but other than this solution I am not sure if it is possible to get a manual software control. That's why I sold it later on, it was just too noisy for me.
1,954 (0.43/day)
Denmark
You can choose custom in the software, but how do we adjust the pump speed, nzxt say it can go as low as 800 rpm, i just wanna find a setting where i to me sounds silent,99.9% quiet
1,065 (0.30/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
1,954 (0.43/day)
Denmark
try looking at pages 60-61 in the manual:
yeah, you'll have to save/reboot to see how it works out; shouldn't be more than 20-30 minutes though to figure out the pwm % to rpms . . .
I know how to oc a aio pump in the biso, it just doesn't change no matter what i use, pwm or dc.
That's why i ask, if nzxt cam software had the option to manually set the pump speed i would just use that since my bios don't work
Would take me 10 min to do it, JayTwoCent say pump speed don't effect temps, so just to find where i think it's inaudible i would like to adjust it, so fare it's not annoying but only on silent and that is nowhere near loweste rpm
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Did you connect it to Pump header on the motherboard? You should be able to control it in BIOS that way.
1,954 (0.43/day)
Denmark
yes, if i didn't do that i couldn't se any reading from the pump in the bios
Toothless
Tech, Games, and TPU!
9,590 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Just get one of those 3-pin fan controllers that sit in the case. Has a dial so you can control as much as you need.
Honestly, the best advice would be to leave it alone. Youtube is a terrible place for advice 99% of the time.
1,954 (0.43/day)
Denmark
Do i have to try to install nzxt cam before tyring to adjust the pump again in the bios ?
I did this before connecting the micro usb to the my pc (very easy to do)
1,065 (0.30/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
first of all pump speed does matter. jay has said some pretty stupid things before but i am sure you must of misunderstood him. if not, then you just added to my long list of why to ignore him.
having said that - you sure you have the cpu/aio header? then select custom to set the curve in the bios. also not having used any NZXT cooling products; you might want check that the CAM software isn't causing a conflict?
1,954 (0.43/day)
Denmark
usb,fan and pump are connected to my mb
