- May 16, 2008
- 1,258 (0.20/day)
- North Carolina
Today's video cards come with VRM that put out some serious power and need to be cooled. It seems like nearly every aftermarket GPU heatsink for these cards always have higher VRM temps than the stock cooler. So much for an upgrade.
I came up with this idea while reading X-Bit Lab's AC Accelero Xtreme 5970 review. The two GPUs are cooled by a large heaptipe/fin array and the VRM gets a little aluminum heatsink. While the AC heatsink does beat the stock cooler in most cases, I've seen other products where this doesn't happen. Anyway.
Instead of attaching a separate heatsink to the VRM, AC should integrate the VRM cooling into the main heatsink. This pic shows the bottom of the AC heatsink. And this is how I would change it. The VRM get its own copper base and a single heatpipe that transfers heat to the main heatsink. Make sense?
This way the main heatsink is cooling the VRM than relying on the heated air from the mean heatsink to cool it. The VRM will get much more surface area as well as better airflow with this solution. There are a couple of downsides though. First, this means that every card needs a unique card. So no more 'one cooler fits all'. But that's not so much of an issue because most high end coolers were only designed for a single card anyway. The second downside is that the GPU will have one less heatpipe. But again, this is a minor reduction in cooling ability. The GPU may lose 10% cooling capacity but the VRM cooling capacity may jump ~40%+. A good tradeoff imo.
Good idea? Bad idea? Great solution? Won't work? Discuss.
