Rubix_chow
- Jan 24, 2022
- 4 (0.00/day)
System Name | 4K-gaming |
Processor | AMD Ryzen 7 5800X |
Motherboard | Gigabyte B550M Aorus Elite |
Cooling | Alphacool Eisbaer w/ 2x 240 rads |
Memory | 48GB Kingston Fury DDR4-3200 |
Video Card(s) | Asus GeForce RTX 3080 TUF w/ EKWB FC |
Storage | ~4TB SSDs + 6TB external HDDs |
Display(s) | Acer 27" 4K120 + Lenovo 32" 4K60 |
Case | Define Mini C |
Audio Device(s) | Asus TUF H3 Wireless |
Power Supply | EVGA Supernova G2 750W |
Mouse | Logitech G MX518 + Asus TUF P1 mousepad |
Keyboard | Roccat Vulcan 121 AIMO |
VR HMD | Oculus Rift CV1 |
Software | Windows 11 Pro |
Benchmark Scores | It runs Crysis remastered at 4K |
does the high memory clock cause hardware problems?OC it as much as it's stable. Run some benchmarks and when it's unstable, lower the clocks a bit.
Here's mine for reference.
Nope, the card is just unstable if you overclock it too much.does the high memory clock cause hardware problems?
System Name | daily driver Mac mini M2 Pro |
Processor | Apple proprietary M2 Pro (6 p-cores, 4 e-cores) |
Motherboard | Apple proprietary |
Cooling | Apple proprietary |
Memory | Apple proprietary 16GB LPDDR5 unified memory |
Video Card(s) | Apple proprietary M2 Pro (16-core GPU) |
Storage | Apple proprietary onboard 512GB SSD + various external HDDs |
Display(s) | LG 27UL850W (4K@60Hz IPS) |
Case | Apple proprietary |
Audio Device(s) | Apple proprietary |
Power Supply | Apple proprietary |
Mouse | Apple Magic Trackpad 2 |
Keyboard | Keychron K1 tenkeyless (Gateron Reds) |
Software | macOS Sonoma 14.5 (with latest patches) |
Benchmark Scores | (My Windows daily driver is a Beelink Mini S12 Pro. I'm not interested in benchmarking.) |
This is correct.Nope, the card is just unstable if you overclock it too much.
Yeaaah... and like I do, I have still a 60Hz monitor and I play with vsync on, the extra performance is only to ensure the stable 60fps frame rate.This is correct.
I set up OC profiles for my 2070 Super Founders Edition based on this guide:
NVIDIA GeForce RTX 2070 SUPER FE Overclocking
We take the NVIDIA GeForce RTX 2070 SUPER Founders Edition and overclock it to the max so that we can compare retail custom video cards overclocking.www.thefpsreview.com
but the system was unstable with the values used by TheFPSReview while running Unigine Heaven 4.0.
So I backed off some of the OC values and finally arrived at a profile that worked with Heaven.
When I ran Shadow of the Tomb Raider, that OC profile caused graphics artifacts. So I painstakingly created two more profiles with lower OC values. In the end, the profile that worked with SoTR was only a 4% overclock. Not worth the time/trouble.
If a game runs at 60 fps at the factory settings, a 4% OC is 62.4 fps. Can you tell a 2.4 fps difference? I can't. Admittedly my eyes are old and tired.
System Name | Codename: Icarus Mk.VI |
Processor | Intel 8600k@Stock -- pending tuning |
Motherboard | Asus ROG Strixx Z370-F |
Cooling | CPU: BeQuiet! Dark Rock Pro 4 {1xCorsair ML120 Pro|5xML140 Pro} |
Memory | 32GB XPG Gammix D10 {2x16GB} |
Video Card(s) | ASUS Dual Radeon™ RX 6700 XT OC Edition |
Storage | Samsung 970 Evo 512GB SSD (Boot)|WD SN770 (Gaming)|2x 3TB Toshiba DT01ACA300|2x 2TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Corsair AX760 |
Mouse | Logitech G900 |
Keyboard | Duckyshine Dead LED(s) III |
Software | Windows 10 Pro |
Benchmark Scores | (ノಠ益ಠ)ノ彡┻━┻ |
Yep, the Black version.Is your card an Gaming OC card? we have similar clocks expect my memory clock is much much higher.
I don't concern myself with this.Yeaaah... and like I do, I have still a 60Hz monitor and I play with vsync on, the extra performance is only to ensure the stable 60fps frame rate.
I'd love to get a block for this, even though I'll keep my CPU on airI have the white version.... Or at least i did have till i put an Accelero Xtreme IV on it.
Yup. Well, my next monitor will be a 4K60 one.I don't concern myself with this.
My primary gaming display is the LG C1 OLED television (4K, 120 Hz, Nvidia G-Sync certified). I have another rarely-used gaming computer which outputs to a 2K/1440p, 165 Hz, FreeSync Premium certified) display.
I picked 60 Hz as a random example but in most cases my gaming builds run beyond that.
I don't really see the appeal of gaming on a 4K/60 Hz PC monitor when there are vastly superior OLED televisions running at 4K/120 Hz.Yup. Well, my next monitor will be a 4K60 one.
I'm too poor to get a high refresh monitor, and actually I don't game that much - I'd love just to get a higher resolution for basic usage.I don't really see the appeal of gaming on a 4K/60 Hz PC monitor when there are vastly superior OLED televisions running at 4K/120 Hz.
However, 4K/60 Hz is great for productivity work. I have an LG 27UL850-W for my daily driver computers (one Mac and one Windows PC). Even the 1440p monitor is a terrible experience for something like web surfing.
Exactly! this is why OC is adding more value to the consumers purchasing power if there a gamer.OC it as much as it's stable. Run some benchmarks and when it's unstable, lower the clocks a bit.
Yeah... and usually cards have a lot of headroom especially with VRAM overclockingExactly! this is why OC is adding more value to the consumers purchasing power.
Overall, we pay a lot of money (relatively speaking) for shiny new hardware, so wring every bit of performance out of it!
Yes, I suppose it varies from card to card but some factory OC cards can be OC even further & still be stable in AAA modern games.Yeah... and usually cards have a lot of headroom especially with VRAM overclocking
Yeah... though I could try push this farther, I've just kept the GPU clocks that it boosts to around 2GHz when gaming.Yes, I suppose it varies from card to card but some factory OC cards can be OC even further & still be stable in AAA modern games.
