How Big of a Difference is Between 2933MHz and 3200MHz RAM?
275 (0.14/day)
Processor AMD Ryzen 7 3700x
Motherboard Aorus X570 Elite
Cooling EK AIO 120 D-RGB
Memory Corsair Vengenace LPX 2x8GB @ 3000MHz
Video Card(s) Aorus GTX 1080 Ti
Storage 1x 1TB PCIe 4.0 NVMe, 2x 1TB hard drive, 1x 120 GB SSD
Display(s) Aorus FV43U
Case Corsair 110R
Audio Device(s) Sound Blaster Z Card, Sennheiser GSP 600, Razer Nommo
Power Supply be quiet! System Power 9 600W
Keyboard Logitech G915
VR HMD Oculus Quest 2
So I'm looking into potentially upgrading from an fx-8350 to a Ryzen 2700x, so I have to buy a new mobo and RAM with it. I currently have my eye on two different mobos, a B450 chipset one with worse IO but supports up to 3200MHz RAM, and an X470, with better IO and support for up to 2933MHz. Since I don't really know how much difference RAM speed makes, I decided to ask here, as if it's not that much I would definitely prefer the better IO, but as far as I know it could be cause a huge difference. I'm here with 2207 MHz DDR3 RAM and I'm able to run all games apart from one at a constant 60 FPS at 4K, so I don't need to big of a performance boost, but it really depends how much of a difference it makes.
7,012 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Difference between 2933 and 3200 is miniscule.
Deleted member 67555
On my 8700k I can only tell the difference between 2400mhz and 3600mhz in benchmarks.
7,412 (2.88/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
19,368 (3.62/day)
For Ryzen, you want the fastest you can get within reason... I would go 3200 for the pittance it is over 2933. It does matter in some things (not gaming typically) and shows notable improvements from base to 3200. 2933 to 3200 obviously not much.
Your DDR3 RAM being 'good' has nothing to do with Ryzen... it works completely different than your old CPU so let's disregard that. :)
'support' speeds are the base speeds. For the most part,, all boards will run past those speeds (with exceptions).
275 (0.14/day)
Case Corsair 110R
So what kind of things will be better with 3200, and will it be worth the worse IO?
19,368 (3.62/day)
Did you click on Cucker's links (though jesus... a single link to the article would be fine, lol)? You should... and figure out if those differences are worth it to you.
339 (0.15/day)
Well, theoretically around 10%, it is probably can experience in memory intensive benchmarks. But in normal everyday usage i guess its around 5% max, where avarage people in avarage program probably wont notice.
19,368 (3.62/day)
You should also take a look at those results.
7,412 (2.88/day)
Poland
Cooling Noctua D15S
583 (0.28/day)
Ryzen (Gen1 or 1+) is a bit affected because the Infinity Fabric that connects the two core complexes works at DRAM speed.
So theoretically, with faster ram well multi-threaded software will get faster.
Stuff that can run on a single core complex (like most games with very few exceptions) will only use one of the CCXes so RAM speed won't make much of a difference.
TL;DR
- Playing very new games or professional applications that use all 8 cores -> Get the faster RAM ( 3200 or in case of Ryzen 2xxx even 3600 works)
- Playing older or e-Sports games or casual user that doesn't do much with the computer - Get the most affordable RAM, it will be the same.
Low quality post by EarthDog
9,270 (3.33/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
You are all missing the fact that the question was aimed more about the motherboard not the RAM itself.
99% chance they'll both get you 3200mhz with the same kit. Get the one with the better I/O, those speed ratings don't mean much.
21,749 (6.00/day)
Mouse XTRFY M42
If 60 FPS is your minimum target, and not an average target, then yes, get the faster RAM option if the price isn't wildly different, and for 3200 mhz it really isn't. Well worth going for on any half decent gaming rig IMO, whether it is Zen or Core.
275 (0.14/day)
Case Corsair 110R
60 FPS is more of an average target, seeing how I already getting it. I'm not sure how possible it is with a 2700x, but with my current fx-8350 it's not far off, and any drops are barely visible.
965 (0.26/day)
System Name Sham Pc
Processor i5-2500k @ 4.33
Motherboard INTEL DZ77SL 50K
Cooling 2 bay res. "2L of fluid in loop" 1x480 2x360
Memory 16gb 4x4 kingstone 1600 hyper x fury black
Video Card(s) hfa2 gtx 780 @ 1306/1768 (xspc bloc)
Storage 1tb wd red 120gb kingston on the way os, 1.5Tb wd black, 3tb random WD rebrand
Display(s) cibox something or other 23" 1080p " 23 inch downstairs. 52 inch plasma downstairs 15" tft kitchen
Case 900D
Audio Device(s) on board
Power Supply xion gaming seriese 1000W (non modular) 80+ bronze
Software windows 10 pro x64
not getting the 2700x purchase over a 2700 non x to be honest, they aren't like Intel K vs non k series cpus. the price would have to be near enough identical for me to buy the X version vs the non x. But i would be happy to overclock them both ans would probably end up at the same performance unless silicone lottery went mad,
as far as im aware (i may be wrong) the only difference between the 2 is out of the box clock speeds, and the non x cannot do single core over clocks so has to be all core over clocks which may result in 100mhz or so less single core performance after overclocking compared to a per core over clock on the x version)
But the ram speed probably wont factor that much.
5,581 (0.78/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
About 267MHz I'd say.
3,653 (0.87/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
@avrona
if i were in your shose i'd hold cpu upgrade till mid year when ryzen 3000 (ryzen2) is expected to launch.
your current setup is running fine and should hold for few more months.
if you need to upgrade now go with 470 taichi
275 (0.14/day)
Case Corsair 110R
@avrona
However seeing how good they seem, they'll probably be way out of my budget.
3,653 (0.87/day)
GMT +2
Processor 5800x
Cooling stock wrath
Case tt core x5 tge
Software windows 10
853 (0.35/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
It depends on price. If 3200MT kit is 10$ more than 2933MT kit, then go for 3200MT kit. Though make sure the kit works well with Ryzen.
26,239 (6.46/day)
For what you've said here and in other threads, a Ryzen 2600 would be great for your needs. A 2700X would not give you much more in the gaming arena, especially if you overclock.
This. 2933 is good.
Go with a Ryzen 2600(and OC it) and 2667mhz DDR4(you will not feel the difference). Take the money you save on those parts and put it into a better GPU if the 1080ti isn't giving the performance you want..
773 (0.12/day)
System Name Daedalus | O'Neill | ZPM Hive |
Processor M3 Pro (11/14) | Epyc 7402p | i5 12400F |
Motherboard Apple M3 Pro | SM H11SSL-i | TUF B660M-E D4 |
Cooling Pure Silence | Noctua NH-U12S TR4 | Noctua NH-D14 |
Memory 18GB Unified | 128GB DDR4 | 16GB DDR4 |
Video Card(s) M3 Pro | RTX 4070FE (VM) | ARC A750 LE |
Storage 512GB NVME | ALOT of SSD's | 1TB NVME |
Display(s) 14" 3024x1964 | IPMI | 1440p UW |
Case Macbook Pro 14" | NZXT H510 Flow| BC1 Test Bench |
Audio Device(s) Onboard | None | Onboard |
Power Supply ~ 77w Magsafe | EVGA 750w G3 | HX1000i |
Mouse Razer Basilisk
Keyboard Logitech G915 TKL
Software MacOS Sonoma | Proxmox 8 | Win 11 x64 |
Judging from experience on my wife's 2700x based system the different in real world usage between 2800Mhz C16 (overclocked 2400Mhz ram), 3000Mhz C15 and 3200Mhz C14 is relatively small.
It will probably show up in benchmarking terms, and I won't argue there isn't a difference, but in actual use I found it hard to tell.
That said the price difference between 2800 and 3200 (at least here in the UK) is pretty small. Going above 3200 is where the price starts to rise quickly.
