How can I increase my lan speed?
3,276 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
I've shared a folder on each of my PCs simply to move large game folders about, but the transfer speeds are very slow, as per the image below.
I'd like to know if I can increase the file transfer speed, because moving a 64Gb folder takes about two hours, meaning it would have been quicker to download it from the Internet.
Router/modem is a Huawei Echolife hg8245q2, one PC has Intel(R) I211 Gigabit, the other has Realtek GbE through a LAN switch. I'm not sure if I'm using cat 5 or 6 lan cable as networking is not my strong point.
Deleted member 185158
Step 1
Click "Start | control panel | Network and Internet | Network and Sharing Center."
Step 2
Click the "Change adapter settings" in the left pane, and then right-click the "Local Area Connection" connection and choose "Properties" from the context menu.
Step 3
Click the "Configure" button, and then click the "Advanced" tab.
Step 4
Select "Speed & Duplex" in the Property list.
Step 5
Select the speed and duplex settings in the Value box. Your choices are 1.0 Gbps Full Duplex, 10 Mbps Full Duplex, 10 Mbps Half Duplex, 100 Mbps Full Duplex and 100 Mbps Half Duplex. Auto Negotiation allows the network adapter to negotiate the maximum speed with the device it's connected to.
Click "OK" to apply and save the new settings"
Solaris17
Super Dainty Moderator
27,007 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Mouse Lamzu Maya Grey
VR HMD Quest 3
Have you looked at your NIC status under adapter settings to see if you are actually connecting at 1g?
Solaris17
27,007 (3.83/day)
Alabama
VR HMD Quest 3
From the graph, it looks like 10Mbs.
We also have to take in consideration of read and write times of the drives too. If the drives are slow, so will the transfer speed.
Thats what I was thinking 7 sustained sounds alot like 10mb linkrate.
8,091 (1.35/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
3,276 (1.02/day)
Buenos Aires
Solaris17
27,007 (3.83/day)
Alabama
VR HMD Quest 3
Ah!
I think that's the answer. It's a 10/100Mbps switch, so I suppose data will only move at the speed of the slowest component?
you got it. Replace the switch and watch the speeds increase.
100mbit has a max speed of 12megabytes on paper.
3,276 (1.02/day)
Buenos Aires
We live and learn, so thanks for all your answers :)
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
11,988 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Backplane bandwidth is important if you want multiple machines to be able to connect and transfer sustained high speeds. Most consumer grade switches/routers aren't even capable of sustaining a single stream at their "rated" connection speed.
Solaris17
27,007 (3.83/day)
Alabama
VR HMD Quest 3
1,836 (0.75/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
Your setup is probably different, but I have my main system and media server connected through an old D-Link gigabit switch with static IPs on their GbE NICs (since they're also connected to a wireless network for internet). I get transfer rates of around 85MBps (680 Mbps) when moving large files between them.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.45/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
I can recommend GS105/GS108 switches from Netgear. Have quite a few of them and they "just work."
17,683 (2.41/day)
Modern network cards tend to allow for automagic crossover if you use a standard networking cable. However, you'd have to set up manual IP addresses on each system for this to work.
Or you know, plug both PCs into the router, as that's most likely a gigabit capable router as far as the switch in it goes.
3,276 (1.02/day)
Buenos Aires
That's what I ended up doing as it was the least expensive way, so I made up another network cable - which is not one of my favourite jobs, getting those pesky wires to stay in position when pushing them into the plug - and connected the other PC directly into the router, with the switch connected simply for workshop use.
Mind you, the wifi on my main PC is lightning fast and I always run the TV with a cable directly to the router as the performance is better with Netflix and Prime, so I can swap around as needed as all the ports are now occupied.
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
That's not true at all. Even the cheap consumer stuff, as long as it is from a known brand, can do a single duplex transfer at the rated speed. I've seen some off-brand garbage that struggled with a single 1Gbps transfer, I'm talking stuff branded with names I've never heard of before that they probably bought off alibab or something like that, but to say most can't is completely wrong. In fact, most can handle multiple transfers at the rated speeds.
forgot a 0 dont be like that newtekie you know im not an idiot.
I'm not being like anything, I'm just posting the correct info for the guy coming along in 5 years to necro this thread with the same problem. The ... was because I was actually confused why you'd make that mistake, because I know you know better than that.
The SG105 is $12 on Newegg right now. They are great plug and play switches, with good build quality. I ordered 5 last week just to keep in stock and to my surprise they even came with lifetime warranties(Newegg lists 5 years, but the boxes all had lifetime warranty stickers).
3,276 (1.02/day)
Buenos Aires
It's impossible for me to order from here and know 100% that it will arrive and not get stolen or be subject to bribes at customs, so I have to source locally.
TP-Link is the dominant make here and I can pick up an 8 port for around $37 if I need to. In the meantime, I'll improvise/prioritise.
