How can I OC my 3100 ?
2 (0.00/day)
System Name Lcars 4.0
Processor Ryzen 5800x (undervolted to 4.7 GHZ all core)
Motherboard Asus Gaming pro x570
Cooling Noctua D15 CPU cooler (using both fans)
Memory 32 GB ddr 3600 Cl 18 (actually have 16 gb of cl16 in box as well)
Video Card(s) Radeon 6800xt (Xfx Merc 319)
Storage internal: 970EVO 1tb boot, PNY 2tb game SSD, two 8TB iron wolf 7200 rpm HDD's. External 2x6tb
Display(s) MSI 32" 1440p 144Hz Optix MAG321CQR, secondary ASUS VS239H-P 23" Both on monitor arm
Case Cooler Master h500
Audio Device(s) Arctis 7 headset/Valve Index headset
Power Supply Thermaltake Toughpower PS-TPG-0850mpcgus-1
Keyboard Razer Cynosa Chroma Gaming Keyboard
There isn't as a commonly known device with "3100" as the name.
I'd imagine you are talking about a GeForce 3060, 3070, 3080 or 3090?
or do you mean a Ryzen 3100 CPU?
13,910 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
It depends on your Motherboard, Bios options and Ram also.
We will need more details of your system.
2 (0.00/day)
okay, that would be a Ryzen 3100. so you are wanting to overclock that chip.. Well, for one, you picked probably the worst of that generation to overclock. the 3100 was the weakest of the Zen 2 based CPU's. You'll probably want to start off by downloading a program called Ryzen Master. There are a number of utilities that use the program Ryzen Master to optimize Ryzen cpu clock speeds. To overclock your graphics card (which would probably have FAR MORE benefits) than overclocking the cpu, you should get a program called "MSI Afterburner" its a great easy to use tool for overclocking GeForce Graphics cards.
As for Overclocking your Ryzen 3100, what SPEED is the MEMORY you put in the computer? is it 2133 mhz CL 16? (both numbers are needed, a High Frequency of the memory clockspeed, and the lowest latency (low CL numbers) are important for ryzen.
For a zen 2 cpu, you will notice the MOST performance gained not by overclocking the cpu, but actually by maxing out the MEMORY speed. i had a 3800x and a 3600x, the zen 2 cpu's will give you more performance by giving them fast MEMORY, than they really will messing with the cpu's clock.
134 (0.10/day)
System Name Upgraded CyberpowerPC Ultra 5 Elite Gaming PC
Processor AMD Ryzen 7 5800X3D
Motherboard MSI B450M Pro-VDH Plus
Memory CM4X8GD3000C16K4D (OC to CL14)
Video Card(s) XFX Speedster MERC RX 7800 XT
Storage TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB
Display(s) AOC Agon AG241QX 1440p 144Hz
Case Cooler Master MasterBox MB520 (CyberpowerPC variant)
Power Supply 600W Cooler Master
There are four main ways you can overclock a Ryzen CPU. The first three are through BIOS, the second is through Ryzen master.
1: set a manual overclock in BIOS
You can enter BIOS by mashing your motherboard's BIOS key (probably delete or F2) when the PC boots. In BIOS you can set your CPU clock speed (sometimes this is given in GHz/MHz, sometimes as a clock mutiplier of the 100MHz base clock - as an example, 3.5GHz would have a multiplier of 35). You may also be able to overclock the system base clock, but this is usually not recommended because it can cause instability in SSDs, GPUs, and other devices.
You should be able to set your CPU cores to 4.1GHz on a Ryzen 3 3100 without changing any other settings. This would be a good starting point. You might get to 4.3-4.5GHz if you're lucky and/or have a decent cooler.
2. Curve optimiser
On some motherboards, the BIOS may contain "curve optimiser", which is an AMD tool to increase single core boost speed without setting all cores to the same speed. This can allow you to reach much higher single-core boost than is usually possible with Ryzen CPUs (some Ryzen 5000-series CPUs can get to 5GHz on one core with curve optimiser), but it is unlikely that your B450 motherboard will support it.
3. Precision Boost Overdrive and AutoOC
If your BIOS is up to date, B450 motherboards support automatic overclocking through PBO (which automatically raises power limits under load when the CPU's temperature is low) and AutoOC (which allows the CPU to boost higher, though is generally much more conservative than what you can get with curve optimiser or a manual OC). PBO and AutoOC are intended to be used together, but it is possible to choose to use one or the other.
4. Ryzen Master
You can download Ryzen Master from AMD's website. This software tells you which of your CPU's cores is the fastest/best, and lets you manually set different clock speeds for different cores. This can be a useful way to set a high single-core speed on the fastest core (which can improve gaming performance), while leaving the other cores at a lower clock to reduce power usage and improve stability.
For someone who is new to overclocking or otherwise not confident with the specifics of computer hardware, I would recommend PBO and AutoOC or Ryzen Master. Ryzen Master has the advantage that if an overclock fails and your system cannot boot, you don't have to reset CMOS and deal with the more complicated BIOS UI to get settings back, the system should automatically return to its defaults. It is overall less flexible than BIOS, but BIOS does not have the ability to manually set different cores to different speeds (AutoOC and Curve Optimiser allow cores to boost to different speeds, but does not allow you to precisely control it). PBO and AutoOC are also unlikely to cause instability or hardware damage, as the voltage and power limits should be set within a safe range by the motherboard manufacturer, though be aware that this isn't strictly guaranteed, especially considering that your motherboard is made by Biostar, whose motherboards are generally poor-quality.
Be cautious with your overclocking. Don't change any setting without knowing what it does (especially voltages and power limits - make sure you know what part you're changing the voltage for, because what's safe for one part might not be safe for another, e.g. SoC voltage is usually much lower than CPU voltage, so getting them confused could lead to you destroying your SoC with excessive voltage). The safest option for manual overclocking would be to leave all power limits and voltages as they are, or try a slight undervolt - this may cause system crashes if the voltage drops too low, but it won't damage your components. Undervolting is especially useful if you use the stock wraith stealth cooler, as undervolting reduces heat output and makes the CPU easier to cool.
As departedsense said, you may get better results from overclocking your RAM, though Ryzen 3 3100s tend to have more overclocking headrooom than other Ryzen 3000 CPUs (due to their lower stock clock speed). Making sure you're running your RAM in dual channel (i.e. with 2 sticks/DIMMs of the same speed) with XMP enabled is much more important than CPU frequency.
Memory overclocking is also generally safer than CPU overclocking, because there are fewer variables, RAM can handle much higher voltages (most DDR4 is fine at 1.5V) and is usually cheaper to replace if you damage it (unless you have a very high-end kit, in which case there's not much point in overclocking it beyond XMP).
Tools such as Thaiphoon burner and DRAM calculator for Ryzen can be used to aid with memory overclocking, and there are various overclocking options within BIOS and Ryzen Master.
1,374 (0.37/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
You're going to run out of memory and throw stuff at your page file quickly with only 8gb RAM. Games like, Warzone itself can consume 6-8gb alone. Definitely make the move to at least 16gb.
134 (0.10/day)
Agreed. This is especially important if you've only got 1 memory stick, as adding another to get dual channel can make a huge difference to performance.
1,901 (0.33/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Very Important to MATCH The memory stick, what you want is the same speed, size, etc. If not then you'll need to start over with 2 new sticks or 4.....
Digital Boy
3 (0.00/day)
Some money problems!
uJamBo
8 (0.01/day)
dont overclock on that mobo its an itx with no cooling on the vrms it will shorten the lifespan of your computer if you want to overclock buy a better mobo itx builds are purely for small spaces if you want an overclocking rig go atx in a mid or full tower
8,778 (3.27/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I would change the MB. Biostar does not supply the strongest VRM. Other than that the easiest way is to OC is use Ryzen Master and use the Auto OC feature. You should b e able to easily get 4.4 GHZ but you need proper cooling as well.
33 (0.03/day)
Saudi Arabia
System Name My PC
Processor Ryzen 5500
Motherboard TUF B450M-PRO GAMING
Cooling ID-COOLING SE-207-XT
Memory JUHOR 3000Mhz 32GB (16Gx2)
Video Card(s) RTX 2060 Super 135$
Storage Kingchuxing 500G nvme & others
Display(s) LG 24 FHD IPS 75hz
Audio Device(s) SAMSON SR850
Power Supply XPG CORE Reactor 650W Gold
Mouse Razer Basilisk X HyperSpeed
Keyboard K96
I have ryzen 3100, and i can't oc it over 4.0ghz :D worst silicon quality :laugh:
4.0 - V1.3
