How do i increase my laptops fan speed?
68 (0.06/day)
System Name Samsung Galaxy Book3 Pro 14
Processor i7 1360P
Motherboard -
Cooling Dual Fan Cooling System
Memory 16 GB 6000MHZ DDR5
Video Card(s) Intel Iris Xe G7 96EUs
Storage 512 GB NVMe SSD
Display(s) 1800p display 120HZ
Case -
Audio Device(s) Quad Speakers (2x 5W Woofers, 2x 2W Tweeters)
Power Supply 65 watt
Mouse Hp omen gaming mouse
Keyboard -
VR HMD -
Benchmark Scores Geekbench 6 : single core: 2252 multicore : 10456 compute(OpenCL):16734 compute(Vulcan):21841
Laptop model : Lenovo Ideapad s340 15iml
i7 10510u
MX230
P.S: I tried modifying fan speed using speedfan but it didnt detect my laptops fan : (
730 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
16,790 (4.61/day)
Fan Control Doesnt Work : (
try hitting ctrl + shift + 1
to turn on max fan off and on. it may not work, but it does work for some Lenovo laptops, if that doesn't work then try "fn + 1" if you have a FN key.
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
still doesnt work
18,585 (2.71/day)
System Name AlderLake
Your last option can be buying a laptop coolingpad.
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
i have one but it still thermal throttles
the fans are very quiet i can barely hear them
18,585 (2.71/day)
Try Throttlestop
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
18,585 (2.71/day)
Save up for a better "Gaming laptop" or better , save up for a desktop computer.
41,481 (6.58/day)
97 (0.05/day)
System Name Dark Flash Phantom
Processor i9-9900KS @ 5.3Ghz
Motherboard Z390 AORUS MASTER
Cooling RBG 2000 to 6000 rpm Fans
Memory 64Gb DDR4 3800Mhz
Video Card(s) RTX 4070 Super
Storage 5 Sabrent 2TB Rocket NVMe PCIe M.2 SSD Drives
Display(s) 55 inch Sony
Case Darkflash Phantom
Power Supply 1300 Watt
VR HMD Quest 3
Software Windows 11 / Linux Duel Boot
Benchmark Scores https://www.gpumagick.com/scores/show.php?id=34679 https://valid.x86.fr/cs4dc6
730 (0.11/day)
GA, USA
System Name Gamer
I tried Fan Control on my HP notebook today & it couldn't see any sensors or the fan. Sorry about that, I had some hope for it since it works so nice on my desktops.
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
1,211 (0.66/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
Can you change it from bios? Even my laptop with no fan has a fan control in bios.
Also you could try this:
  1. Open “Control Panel” and click on “Hardware and Sound,” and then “Power Options.” A new window will appear.
  2. Click “Change Plan Settings,” and then “Change Advanced Power Settings.” The “Power Options” dialog box will appear.
  3. In the “Advanced Settings” tab click on the “Processor Power Management” associated with a plus symbol to open an options submenu.
  4. Select “System Cooling Policy” from the submenu.
  5. Click the down arrow under “System Cooling Policy” to reveal a drop-down menu.
  6. Select “Active” from the drop-down menu to increase the speed of your CPU’s cooling fan.
  7. Click “Apply” and then “OK.”
68 (0.06/day)
Processor i7 1360P
Motherboard -
Case -
Keyboard -
VR HMD -
that option does not exist in my laptop.........
1,211 (0.66/day)
Canada
You can use Power Settings Explorer tool to unlock all the hidden power options if you can't see them by default.
