How do I overclock a Pentium D?
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
System Name Cozad (Asus G60JX)
Processor Core i5 M 430
Memory 8 GB DDR3 1066
Video Card(s) nVidia GeForce 360M
Storage 500GB
Display(s) 16 inch LED LCD
Software Windows 7 Ultimate x64 SP1
As you can tell from my specs I have a Pentium D 925, which is just a crippled 930... I'd like to overclock it. My BIOS has all the needed settings to do it, but I've never overclocked a 'modern' CPU, so I don't have the first clue what settings to change. a quick Google search didn't reveal anything obvious except one review that claimed to get the 930 overclocked to 4.125GHz with the stock cooler, but they used a differnt brand of motherboard than mine. I do have an aftermarket cooler installed and idle at 46C (one hot chip, lol). So... What do I do first? :confused:
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
With no multiplier adjustments available it was simply a matter bumping up the bus and adjusting the memory ratio for my P4D overclock.
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
What kinda temps do you get with that?
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I am interested as well... 1.360 is the same as is read in CPU-z for mine at stock.
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
I used the Asus Overclock Profile and chose to "Overclock 30%" and got this...
But BIOS is now saying my RAM is PC2 3200...
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
Okay... When I go into BIOS's overclocking area if I choose to overclock manually, I and presented with a field that allows me to choose the frequancey.... from 200 to 450 I think. Why can't they just say x.xxGHz...?
2,318 (0.33/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
you mean this page
or
thoughtdisorder
1,818 (0.29/day)
Just South of Mars
System Name Decent Lappy
+1. The Jizzler knows the deal! Bump the bus, watch your temps. That simple. What kinda oc'ing have you attempted with your ram? (If any) Not a necessity, but if you can it will help out..................
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
you mean this page
or
the bottom one. I set it to around 260 and got 3.9GHz, but at 4GHz, so as Windows tried to load it shuts off for a couple seconds and then powers back on...
Actually, if I overclock even just a little bit, when i save the settings made in BOIS or Restart from Windows, the tower completely shuts off for a couple seconds and then powers back on; that's not normal, so should it worry me?
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
Well, if I choose to overclock via the Overclock profile, it underclocks my RAM... BIOS will say it's PC2 3200 but CPUZ says overwise.... atm, the RAM is still set within the PC2 5300 range... Anything above that and Windows will not start.
2,318 (0.33/day)
Mouse Rat7
^^ Asus Mb will do that some times with the bios reload [more ofton than not it shows it's ??? it self as to post or give you the 'F1' option
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
So Asus should exit the mobo arena and just make over priced shity laptops? :p
2,318 (0.33/day)
Mouse Rat7
thoughtdisorder
1,818 (0.29/day)
Just South of Mars
Dude, don't use oc profiles. Oc manually, for stability reasons. Start by reading Kursah's OC guide here on TPU, because it's a great guide, seriously! Kurash knows his stuff....(respect)
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
no it's just it "really don't like" the setting you set but it will post any way but not stable ...
have a read ....http://www.digital-daily.com/motherboard/asus-p5ld2-deluxe/index4.htm
....... http://www.digital-daily.com/motherboard/asus-p5ld2-deluxe/index5.htm might give you some insight
:toast: ty.
I honestly don't know why Asus won't release a BIOS update to support core 2 Duos and Quads... The board supports upto a 1333MHz FSB (but only PC2 6400 RAM), so it's perfectly capable or running the Core 2s with a new BIOS... *sigh*
2,318 (0.33/day)
Mouse Rat7
^^ LOL because they are a money hungry corp that wants to sell sell sell the latetest & greatest only :)
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
I'm going to try to make this bitch hit 4GHz... =D *slaps Intel for not having Hyper-Threading on the regular Pentium D and then kicks them them releasing chips that run hot enough to heat an Antartic orphanage* Asus, you guys are bastards too! lol.
2,318 (0.33/day)
Mouse Rat7
Memory info
Asus P5LD2 Deluxe
Stable DDR667 Timings - 2 DIMMs
(2/4 slots populated - 1 Dual-Channel Bank)
Clock Speed: 200MHz (800FSB)
Timing Mode: 667MHz - Default
CAS Latency: 3
RAS to CAS Delay: 2
RAS Precharge: 2
RAS Cycle Time: 8
Voltage: 2.1V
4,267 (0.67/day)
Sanford, FL, USA
Case Lian Li PC-Q25
About 58-59 under load.
Using a Scythe Ninja in a Lian-Li A17 (I need to update my system specs).
The P4D is decently lapped, though I didn't do that good on the Ninja. Dropped 2 degrees overall.
4,267 (0.67/day)
Sanford, FL, USA
Case Lian Li PC-Q25
Good goal. At 266 FSB, you should be able to get the memory at 333Mhz.
On my board it would be like this:
-img gone-
4Ghz with your 15x mult chip.
If not stable, probably have to bump up the voltage a bit.
beyond_amusia
1,140 (0.17/day)
Baltimore, Maryland
Storage 500GB
I tried 4GHz and Windows would not even start up. I had the memory timing set to Auto and Bios decided I had PC2 4800, so I lower the CPU freq. to 250 and I am sitting at 3.75GHz... I'll keep trying. The voltages are all set to auto; I'm scared of changing them and having my CPU or RAM get fried.
