How important are X3D processors at 1440p and beyond?
390 (0.34/day)
Denmark
Processor AMD Ryzen 7 3800X
Motherboard ASUS Prime X470-Pro
Cooling bequiet! Dark Rock Slim
Memory 64 GB ECC DDR4 2666 MHz (Samsung M391A2K43BB1-CTD)
Video Card(s) eVGA GTX 1080 SC Gaming, 8 GB
Storage 1 TB Samsung 970 EVO Plus, 1 TB Samsung 850 EVO, 4 TB Lexar NM790, 12 TB WD HDDs
Case Corsair Obsidian 550D
Audio Device(s) Creative X-Fi Fatal1ty
Power Supply Seasonic X-Series 560W
Keyboard Glorious GMMK
Title almost says it all. I'm going for an AM5 build with an interim processor (have my eyes set on "Medusa"). Thinking of a 7700, because it's fairly cheap and according to Passmark is about 33% faster than my 3800X. I believe I've heard somewhere, that X3D processors make less sense the higher the resolution is. Right now, I'm using 1440p and I certainly won't go lower ever again.
Solaris17
Super Dainty Moderator
27,230 (3.82/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Not exactly; CPUs are less constrained at higher resolutions because it’s all on the GPU. But cpu tasks and thread handling still benefit from fast CPUs and fast cache. You still want the best you can get you just don’t expect 100% load avg.
59 (3.69/day)
If you use dlss/fsr/xess in any mode other than native, it will reduce rendering resolution and increase CPU load.
4,831 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
I assume we are talking about gaming? If so, depends on the exact games. Some games they make no difference, in some they make some difference and in some they make a big deal. Look at the games you play and like to play and check out some benchmarks @ 1440p just realize if you are sticking with your GTX 1080 the difference between CPUs will be less than most modern benchmarks that are run with a RTX 4090
1,245 (1.82/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
Serious lack of info here - we need your full specs.
Also, what games are you playing, and what is your fps goal.
3,578 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
Long story short: CPUs don't care about the resolution. If the CPU can only give you 200 FPS then if the GPU allows for that, it'll be 200 FPS in any resolution.
So it might be reasonable to cut CPU spendings a little bit if you go high resolutions such as 4K in favour of a better GPU but generally speaking, you better buy the best CPU you can afford instead of overthinking it.
bug
14,074 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Just read the reviews on TPU. Spoiler alert: performance-wise, not that important.
And that's with a 4090.
1,245 (1.82/day)
Software Win10 pro
Again, depends entirely on what games are played - if it's esports, then cpu will deffo matter. But op gave us close to zero info...
3,229 (0.54/day)
System Name White Custom Loop Fractal North XL
Processor Intel Ultra 7 265K Overclocked 5.6Ghz P-Core / 5.1Ghz E-Core / 4.2Ghz Ring / 3.2Ghz D2D & NGU
Motherboard ASUS STRIX Z890-A GAMING WIFI
Cooling AlphaCool Core 1 White CPU Block - 2x Heatkiller 360-L - Alphacool Core 120mm Resevoir
Memory 48GB 7200Mhz Corsair Dominator DDR5 - Overclocked to 8000Mhz
Video Card(s) RTX 5090 32GB Palit Gamerock - Alphacool Waterblock Incoming
Storage 4TB WD Black NVME Gen 4
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Fractal North XL Chalk White Mesh
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair RM1200x Shift White
Hmm I balanced my build because of this since I use a 4k monitor, a CPU thats current and mid range and up arent really going to make any meaningful difference in games, it didnt make sense for me to get the 9800x3d hence why I went intel. Really I was going to end up with a similar performing CPU for a whopping 400 aud more since no meaningful difference in games at 4K and comparable production power and significantly less rendering prowess
938 (0.51/day)
Not much unless you've got a very high end gfx card as well. Or you do other tasks on CPU.
If you're gpu bottlenecked, any modern cpu will do. I'm still using a 4790k in one rig and don't see any reason to change it due to that.
Ultimately, it depends on your use case.
bug
14,074 (3.96/day)
Having read your reply, I was 90% sure you bought a 3DVCache CPU before I looked at your system specs.
Yeah, esports is something else, you'll 3DVCache for those regardless. For anything else, at QHD or above it's just a nice to have.
ir_cow
4,729 (0.79/day)
USA
This is a nice way of explaining it actually.
1,884 (0.40/day)
Romania
It dose matter if you play online stuff that requires it. For example when your fps drops from 80 to 40 when a hoard of enemies comes at you and your allies in Darktide or Vermintide, you would have wanted an X3D or a more powerful CPU. But in a single player title, it dose not matter if you die, cause you can quick load at any time.
390 (0.34/day)
Denmark
Thanks for all your input. My new system will use an RTX 4080. And yes, I'm asking for the gaming part of things. I'm pretty sure the 7700 would cover my needs since it's faster than the 3800X I'm using now. However, I don't want to get either a 7800X3D or 9800X3D, because they're way too pricey at the moment. I just need something useful until Zen 6 ("Medusa") comes around. If nothing else, the 9000 series would probably be quite a bit cheaper by then.
721 (1.78/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
How important? Yes.
If it's 1st gen X3D you're all set for 1440p until next generation GPUs.
For now the 5900X and similar non-X3D are good at maxxing 5K capable GPUs at 100%.
So if you're on newer X3D or just need lots of cores, your big honkin chonkin GPU will push ALL the pixels that it can.
2,467 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
It's 'important', period.
IME, X3D improves performance 'all around', with emphasis on 1% and 0.1% FPS avgs.
IIRC, a 5800X performs (near) universally worse vs, 5800X3D, regardless of resolution
100 (0.13/day)
Processor Ryzen 7 9800x3d
Motherboard Asrock X870E NOVA wifi
Cooling Noctua NH-D15 g2 LBC
Memory Gskill Trident Z Neo DDR5 6000 2x32GB
Video Card(s) Inno3d 4070 TI
Storage 4 TB SSD Samsung 990 Pro + 2 TB SSD Samsung 980 pro + Toshiba 18TB
Display(s) MSI MAG274QRF-QD
Case Antec Flux Pro
Audio Device(s) Creative Soundblaster AE-9 + Klipsch R-51 PM
Mouse Razer Basilisk V3
Keyboard Razer Blackwidow V3
The biggest benefit is the overall smoothness, especially in CPU intensive games like WoW, its litterally day and night, even playing at 1440p all maxed, and I mean all.
A lot less fps spikes.
4,831 (0.97/day)
anything you do to lower core latency will impact WoW performance which is why the 5800X3D will outperform a 7700x with DDR5 (still very good results)
dgianstefani
TPU Proofreader
5,254 (2.02/day)
Swansea, Wales
Benchmark Scores Legendary
Balanced builds are bullshit. You buy the best CPU you can afford and upgrade it maybe in five years. GPU upgrades are priority.
When your GPU isn't at 100% it's wasted budget.
"Matching" a CPU to a GPU is pointless because you're going to end up buying a faster GPU eventually.
Toothless
Tech, Games, and TPU!
9,747 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
5700x3d would be your friend. Fits same socket as your 3800x.
39 (0.14/day)
Motherboard MSI Pro B550M-VC Wifi
Memory 2x16GB G.Skill RipJaws DDR4-3600 CL16
Video Card(s) Asus DUAL OC RTX 4070 Super
Storage 4TB NVME, 2TB SATA SSD, 4TB SATA HDD
Display(s) Dell S2722DGM 27" Curved VA 1440p 165hz
Case Fractal Design Pop Air MIni
Power Supply Corsair RMe 750W 80+ Gold
Keyboard GMMK TKL RGB Black
VR HMD Oculus Quest 2
Like others have said, as the resolution increases, the CPU becomes less important for overall performance because it increases the GPU load, not the CPU load, outside of a few games where the 3D cache provides enough benefit to still provide a notable performance boost at higher resolutions. And you could get a 5700X3D instead which would be a nice upgrade and probably allow you to feel comfortable enough to skip AM5 entirely, that's my plan with my 5800X3D.
However, there is one benefit of the 3D cache at higher resolutions, and that's better stability. If your GPU is getting ~200fps at 1080p, but there's a momentary dip down to ~150fps, that's not very noticeable. However, if your GPU is getting ~80fps at 1440p and there's a dip down to 50fps, that will be a very noticeable stutter. The X3D CPUs provide much better stability and fewer stutters like that, and stutters are more noticeable at higher resolutions where your average framerate is lower.
1,245 (1.82/day)
Software Win10 pro
And again you gave us fack all details - what games are you going to be playing, and what is your fps target...
