How important is P_GFX_TXN[9]?
30 (0.03/day)
ur dads house
System Name Oh wow it's actually good now
Processor AMD Ryzen 9 5950X
Motherboard MSI Prestige X570 Creation
Cooling Scythe Fuma 2
Memory Patriot Viper Steel 64GB @ 3800MHz
Video Card(s) EVGA GeForce RTX 2080 Ti Black
Storage 2TB Kingsman KP800, 2TB WD Black SN750, 2TB WD Blue SATA SSD
Display(s) Viotek GNV27DB, Acer CB271HU, Acer G247HL
Case Fractal Design Pop Air
Audio Device(s) Integrated ALC1220 (temporarily)
Power Supply EVGA SuperNOVA 850 G6
Mouse Logitech G700
Keyboard EVGA Z20 (Linear)
Software Windows 8.1
I bought a used 5950X with bent pins, however one of the pins is broken, and that pin is P_GFX_TXN[9]. I'm wondering how important it is and if I might need to find someone that can replace it
85 (0.09/day)
Do you get any errors, does it boot up?
30 (0.03/day)
ur dads house
Mouse Logitech G700
30 (0.03/day)
ur dads house
Mouse Logitech G700
Does the current owner say it boots up.
He had bent some pins, and apparently hasn't tried to bend them back, and just listed the chip online.
Solaris17
Super Dainty Moderator
27,498 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I had a CPU witha broken pin. wouldnt even boot was an AM2 system IIRC. cut a staple to length and put it in the socket where the pin was supposed to be. Worked mint and lasted years. There are proper ways to repair with like a heatgun and solder if you have the know how and spare pins.
The machine might just boot and work. Not sure what that pin does specifically though.
30 (0.03/day)
ur dads house
Mouse Logitech G700
I looked at guides, my assumption is iGPU. I also thought it could be PCIe lanes, but there's not enough of them for it to be that. If it does prevent startup, I could try stealing pins from a dead AM2 CPU or a DP0 pin.
Solaris17
27,498 (3.84/day)
Alabama
VR HMD Quest 3
For what its worth my first thought was iGPU as well.
85 (0.09/day)
the 5950x doesnt have a igpu.
30 (0.03/day)
ur dads house
Mouse Logitech G700
3,902 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
Found something here:
Its not exactly the same but could be a hint...
P_GFX_TXP/TXN[15:0] = PCIe GFX Transmit Data Differential Pairs
Dont forget that these chips today are SoC type (system on chip) and communicate directly to a lot of system parts, like the PCI-E GPU
