How Low Can You Go? Memory Latency Competition - AIDA64
1,150 (0.49/day)
Upstate NY
System Name Dual Socket HP z820 Workstation
Processor Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T)
Motherboard HP Dual Socket Motherboard
Cooling Stock HP liquid cooling
Memory 64GB Registered ECC memory kit (octal channel memory on this rig)
Video Card(s) MSI RX 5700 XT Gaming X 8GB
Storage 2 x 512GB SSD in raid 0
Display(s) Acer 23" 75Hz Gaming monitors 1080P x2
Case Brushed Aluminium
Audio Device(s) Integrated (5.1)
Power Supply HP 1125W Stock PSU
Mouse gaming mouse
Keyboard Dell
Leaderboards are located at the bottom of this post - *Updated 3/14 4:00am*
I thought it would be cool to get a "pulse" on some of the newer systems and see how modern platforms perform in terms of memory latency. We can compare and contrast to older generations as well (DDR3 vs DDR4 vs dual channel vs quad-channel, etc). So this is more of a fact-finding mission turned latency competition. And by all means, if you have an old system you are more than welcome to use it, as the more data we have, the better. Matter of fact, I will start this off with my Old Phenom II system. You can follow this basic outline with your submission:
CPU..........................AMD Phenom II X6 1600T @ 3.8Ghz
COOLING................Fractal Designs S36 360mm AIO
MEMORY.................8GB (4GB x 2) Corsair XMS3 CMX4GX3M1A1600C7
MOTHERBOARD…..Biostar A880GZ
Basic ground rules:
*AIDA64 Extreme or Engineer Edition (They use the same benchmark engine)
*Multiple submissions are allowed
*Laptops are allowed
*Old school rigs are allowed (please note on your sub if competing for the Red Lantern Award)
Instructions for running the benchmark (Go to tools, then select Cache and Memory Benchmark):
Then take a snip of your result and post it here.
There are multiple facets to this competition and one main objective:
*Memory Latency Champion:*
The overall win goes to the rig with the lowest possible memory latency result. Open to all systems, absolutely zero restrictions here.
*Points Competition:*
In cycling, the green Jersey represents the winner or current leader in the points classification.
So we will transfuse this idea into our benchmark competition here. Hence the term "green jersey"
The Green Jersey will be awarded to the rig that dominates the competition across multiple categories. It will be calculated based on an average of your latency results: (Memory + L1 + L2 + L3 / 4). The rig with the lowest avg latency average wins.
*Combativity Award*
The combativity award is a prize given to a participant for the most combative overclocker overall.
*Red Lantern Award*
Self-explanatory. System with the highest possible latency. (a slug)
*We will use your single BEST result PER rig* That means you can benchmark multiple rigs
If two users are tied for first place, we will go to a sudden-death elimination round using an average of your r/w/c scores. The system with the highest bandwidth wins out. In no other cases are we looking for your read/write/copy speeds---but it should be fine for just the elimination round - if needed at all.
The overall winner will receive an AMD 965 Black Edition (RB-C3 Deneb core) CPU that overclocks to 4.1GHz (If you want it)
Leaderboards
Memory Latency Leaderboard:
Points Classification (Green Jersey) Leaderboard:
Red Lantern Classification Leaderboard:
4,840 (1.56/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
CPU..........................AMD Ryzen 5 3600 @ Stock
COOLING................Scythe Kotetsu
MEMORY.................16GB (8GB x 2) PNY Anarchy-X XLR8 Red DDR4 3200 MHz - MD16GK2D4320016AXR
18,585 (2.72/day)
System Name AlderLake
1,150 (0.49/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
I think with the scope narrowed we may get some interesting results, that is if we get enough interest. If not, we will let this go.
sneekypeet
Retired Super Moderator
29,470 (4.37/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I'm going to allow this, since the other threads OP with the charts has not been updated for nearly a year.
Deleted member 178884
CPU..........................i5-6600K @ 4.5ghz core 4.3ghz cache 1.25V (Delidded) 1.2V VCCIO/VCSSA
COOLING................Snowman T6 Air cooler
MEMORY.................32GB (4X8) Flare-X 3200 14-14-14-31 @ 1.35V (running 1.45V @ 3600 cl15-15-15-35 2T)
MOTHERBOARD.....Z270X gaming 7
1,862 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Any questions ?
PS. Here's 2400MHz result, but I would like 1866MHz one to be counted :
1,824 (0.77/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
Dragged this old screaming beast out from under my bed to test it...
CPU: Intel Celeron M 370
RAM: 2GB DDR2-400
Higher latency is better, right? :p
Also my secondary laptop:
CPU: i5-4310U
RAM: 4+8GB DDR3-1333
...and my main PC.
CPU: AMD R5 2600X
RAM: 2x8GB DDR4-3000
Cooling: Cryorig R1 Ultimate
Mobo: MSI X470 Gaming Pro
1,150 (0.49/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
Looking good guys! Thanks for the submissions.
@agent_x007 That is absolutely hilarious. What was AMD's flagship quad core at the time running at a blistering 50Mhz. Very impressive underclock... How long did it take you to boot into windows?
I'm working on the leaderboard templates now and I'll post those up a little later tonight.
Any questions ?
Memory type/model and amount please. (for your 1866Mhz result)
1,862 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Booting took ~7 minutes, and AIDA64 needed another 4 to show a window :)
1866MHz :
DDR3 16GB, A-Data 2000X 2GB (x8)
1,150 (0.49/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
...and my main PC.
CPU: AMD R5 2600X
Sam, I need your specific memory make / model
thx
1,824 (0.77/day)
Arizona
498 (0.09/day)
System Name Dell Vostro 5630 | PHaS3-XXI
Processor Intel Core i7 1360P | AMD Ryzen 7 5700X PBO
Motherboard Asus ROG Strix B450-F Gaming
Cooling Corsair H105 (AM4 Retention yay!)
Memory 16GB Quad Channel LPDDR5 4800 | Crucial 64GB DDR4 Pro 3200 C16
Video Card(s) Nvidia RTX 2050 | Gigabyte Radeon RX 5700 Stock Cooler @ XT BIOS
Storage Kioxia 512GB NVMe |Crucial MX200 SSD + Samsung 980 1TB + 870QVO 1TB + 12TB HDDs
Display(s) Dell Laptop Display 1920x1200 | Dell UltraSharp U2719D
Case Fractal Design Define R4
Power Supply Corsair RM750
Mouse Logitech G403 | Logitech G Pro
Keyboard Logitech MX Keys
Software Windows 11 Pro x64
Benchmark Scores @_@
Stock:
CPU..........................AMD Ryzen 7 1700 @ Stock
COOLING................Corsair H105 240mm AIO
MEMORY.................16GB (8GB x 2) Corsair Vengeance Pro RGB 3200 C16 CMW16GX4M2C3200C16
MOTHERBOARD…..MSI X370 Gaming Plus
CPU 4GHz:
CPU..........................AMD Ryzen 7 1700 @ 4GHz
1,824 (0.77/day)
Arizona
Here's my main laptop
CPU: i5-6500T
RAM 2x8GB Samsung M471A1K43BB0-CPB DDR4-2133
Also will there be another table to keep track of all submissions; maybe hidden behind a spoiler?
57 (0.03/day)
System Name MIXED
Motherboard ASUS TUF Gaming X570-Plus Wifi
Memory G.Skill Trident Z RGB DDR4 2x16 3600MHz
Video Card(s) RTX 4080 GameRock
Storage Gigabyte AORUS NVMe Gen4 1TB
Display(s) LG 27GL850-B 27" IPS 144Hz + LG 65" C3 OLED 120Hz
Audio Device(s) iFi Audio Zen DAC V2 + Hifiman Sundara
Power Supply Corsair RM750x
Keyboard X Box Elite2
CPU.........................Ryzen 7 3700X
COOLING................Noctua NH-D15
MEMORY.................32GB (2X16) G.Skill Trident Z RGB 3600MHz CL16-19-20-36
MOTHERBOARD.....ASUS TUF Gaming X570-Plus WiFi
10,563 (1.71/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.4GHZ UV - 220W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
8700K @ 5.1Ghz
16GB of Team Tforce 3200 cl 14 @ 4000 cl 17
motherboard - MSi z370a
cooling - compact custom water - 120mm thick push pull
I could probably tweak it lower @4200 17-18 but havent had time to stabilize it yet.
11 (0.00/day)
Russian Federation
Processor i9-9900kf 5.0GHz
Motherboard ASRock Z370 EXTREME4
Cooling Arctic Liquid Freezer II 280
Memory F4-3600C15D-16GTZ @4270 16-17-17-30 CR2
Video Card(s) Palit GTX1080 JetStream up to 2265/12265 1,175V
Storage SSD OСZ Vertex 4 256Gb
Display(s) ViewSonic XG2401 - 24" 144Hz
Case NZXT Guardian 921 blue rebon
Power Supply Corsair rm850x
Mouse ZET Fury
Keyboard Genius GK-07001
Software Win10
Benchmark Scores Time Spy Graphics Score 9018
CPU..........................i9-9900kf 5.28GHz
COOLING................Arctic Liquid Freezer II 280
MEMORY.................16GB (8GB x 2) G.Skill F4-3600C15D-16GTZ 4334MHz
MOTHERBOARD…..ASRock Z370 EXTREME4
on the screen, the frequencies are slightly lower due to the fact that I drove the bus after the launch of AIDA64
1,824 (0.77/day)
Arizona
Bumped clock speed to 3200MHz with similar timings.
CPU: R5 2500X
RAM: 2x8GB Crucial Ballistix Sport LT DDR4-3000 @3200MHz
4,840 (1.56/day)
CPU: R5 2500X
You should give it another bump, and try 3333/3400 MHz.
1,824 (0.77/day)
Arizona
8,180 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
default afaik.
4,840 (1.56/day)
461 (0.23/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
Ryzen 7 3700x / Scythe Ninja 5
Asus ROG Strix X470-F Gaming (BIOS 5406 - AGESA 1.0.0.4B)
1,824 (0.77/day)
Arizona
Yes, I had a 2933 MHz kit that would run at 3400 MHz with stock voltage, and primary timings.
Got it to boot at 3333MHz after adjusting timings. If I can't get it to boot at 3400MHz, I'll run memtest at 3333MHz to see if it's stable.
Going right to 3400MHz got me a black screen, and not adjusting timings at 3333MHz got me a BSOD on boot.
CPU: R5 2600X
Cooler: Cryorig R1 Ultimate
RAM 2x8GB Crucial Ballistix Sport LT DDR4-3000 @ 3333MHz
