How much voltage does a Ryzen 5 5600 take?
103 (0.06/day)
Hello everyone, I got a new CPU recently and temps are a bit high. I want to get new cooling and thermal paste soon but cannot afford it. So currently I want to make sure my voltage is right.
Right now it's running at 3.50 GHz (With 6 cores for those who don't know)
Right now as I'm writing it CPU-Z says it's running at 1.088 V (I forgot what it's clocked at in my Bios and don't feel like restarting rn lol) When it came it came pre-overclocked with horrible voltage and what not so I just changed it to manual not overclocked and didn't touch anything else. I'm wondering if I'm giving it maybe too much power and if it can go any lower. Does anybody know? (If I should restart to check what it is in my Bios just lmk)
3x0
955 (1.32/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Stock 5600 should boost to 4.45GHz at 1.35+V under single core load
5,701 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Define "a bit high".
5,701 (0.80/day)
Ikenai borderline!
40C idle. Only reason I'm not panicking is because I don't do crap that is intense enough to get it into damaging temps
That is incredibly cool. I suggest you educate yourself as to what safe temperatures are for Zen 3 CPUs before you start wasting your time and others' with unfounded alarmism.
16,747 (4.61/day)
the title of this thread and comments are not "alarmist" its a legit simple question, lol
I get 1.200 volt, override voltage no offsets, just override, at 1.200 volt even, i can do 4.6 all core fully stable. YMMV and I get like 65 celsius to 70 celsius in games at full load.
only older chips needed 1.35v. newer chips can use less voltage to achieve same 4.6 oc.
103 (0.06/day)
Yeah but it goes to 60C under 20% load sooo
tabascosauz
8,025 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
You must be new around Ryzens. You get high Vcore up to 1.35-1.5V for low current loads (ie. single threaded), hence the relatively high temps under lightly threaded loads. Vcore comes down gradually as current increases (ie. number of cores and "load").
You haven't specified any details about your specs - stock Wraith Stealth cooler is sucktastic and those temps are about expected. As for idle, CPPC responsiveness blurs the line between idle and light load so "pure" idle is hard to achieve.
Honestly I'm surprised this is still a mystery to some. It's been nearly 4 years since Ryzen has worked this way and there must be billions of guides and help threads out there.
14 (0.02/day)
System Name Eif PC
Processor Ryzen 9 5900x / Ryzen 5 5600 / ryzen 3 3100
Motherboard ASROCK B550 EXTREME4 / TUF GAMING B450M-PLUS II / B450 M aouros elite
Cooling Cooler MasterLiquid Lite 120 / COOLERMASTER MASTERLIQUID ML240L V2 ARGB
Memory 32 gb gkill 3600 cl 16 / 32 gb 3200 cl 14
Video Card(s) GIGABYTE GEFORCE RTX 3070 GAMING OC / Zotac GTX 1660 super 2200 mghz /
Storage 120 gb M2 / 1 TB 7200 / 2 TB 5400 / 500 GB SSD
Display(s) GIGABYTE G24F 2- 24" - 165HZ - IPS / GIGABYTE G24F 2- 24" - 165HZ - IPS / GIGABYTE G24F 2- 24" - 165
Case NZXT 510
Power Supply GIGABYTE P850GM - 80 PLUS GOLD / GIGABYTE P850GM - 80 PLUS GOLD
Mouse LOGITECH G203 Prodigy / LOGITECH G502 HERO
Keyboard REDRAGON K585 DITI / RAZER CYNOSA LITE - RGB-ESPAÑOL
Software win 10 / win 11
It's very rare to see these CPUs get hot, but if it's with the stock heatsink, chances are high that temperatures will go up to 80 degrees.
freeagent
8,214 (3.72/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Except 4650 is stock boost on the older CPUs, +200 brings it to 4850..
1,058 (0.69/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 sumpin'
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) PColor 6800 XT / PNY RTX 4060 Ti
Storage 4TB Team MP34 / 2TB WD SN580
Case Corsair 4000Air / TT Versa H18
Audio Device(s) Dragonfly Black
Power Supply EVGA 650 G3 / EVGA BQ 500
Mouse JSCO JNL-101k Noiseless
Keyboard Steelseries Apex 3 TKL
Software Win 10, Throttlestop
R5 5600
Idle 29C
Converting a 1080p h.264 video in Handbrake to h.265. rf17, Slow:
Stock, no tuning: 4417MHz rare peaks, 1.15v, 76W, 66C with Cryorig M9A
PBO, no other tuning: 4442MHz more consistently, 1.24v, 100W, 80C
CPU-Z stress:
Stock, no tuning: 4372MHz, 1.17v, 76W, 65C
PBO, no other tuning: 4449MHz, 1.21v, 82W, 69C
5,701 (0.80/day)
Ikenai borderline!
'Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.'
20 (0.04/day)
Processor AMD Ryzen 5 5600
Motherboard MSI B450 TOMAHAWK MAX
Cooling Arctic Freezer 34 eSports DUO
Memory Team Group 32GB (2 x 16GB) DDR4 3600MHz Dark Za CL18
Video Card(s) MSI NVIDIA GeForce GTX 1660 Super Gaming X
Storage Samsung SSD 860 EVO 500GB / INTEL SSDSC2BW120A4 120GB / Seagate ST4000DM004-2CV104 / WDC WD40EZRZ-22
Display(s) AOC 24G2U IPS 23.8" 144Hz
Case Coolmaster N300
Power Supply Seasonic PRIME Ultra 550W Platinum
Mouse Razer Basilisk V2
Keyboard Corsair K55 RGB Pro
Software Windows 10 Pro 64
Don't worry. Look at mine! :)
krisdee
13 (0.02/day)
Newer Ryzen 5 5600 should do 4.6Ghz all cores at 1.2V.
I'm running auto voltage in bios, CPU boost clock override +150, Curve Optimizer per core negative 18,30,14,14,22,20
PBO limits, manual 90/60/90
In Cinebench multi all cores are 4.6Ghz@1.181V
Sweet spot in my opinion.
1,935 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) G.Skill Trident Z5 Neo (6000Mhz)
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
1,230 (1.67/day)
System Name Windows
Processor 7950X3D
Cooling Arctic LF III 420
Memory 64GB 6000 CL30
Video Card(s) RTX 4090
Display(s) MSI MAG401QR
Case Asus ProArt PA602
Audio Device(s) Two Turntables and a Microphone
Power Supply Vertex GX-1000
Software Win 11
Whatever you do, never look at temps of Intel 12/13th or Ryzen 7000 CPUs.
Hey, red text 100c readings in HWinfo is kinda seksi. :pimp:
Signed,
13900k on air
freeagent
8,214 (3.72/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
1,230 (1.67/day)
System Name Windows
Processor 7950X3D
Software Win 11
