How should I overclock my gtx 1060 3gb
Castino
12 (0.00/day)
So, I really want to squeeze out that power out of my graphics card with the MSI afterburner. Could anyone tell me what to and how much to change in the program?
4,994 (0.70/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
Which graphics card do you have?
You need something to stress the card to to check stability, you can use a game with vsync off, or download a benchmark like Unigine Heaven.
Generally it's just a case of setting a custom fan curve, or manually apply a fan %. Then adjust your power limit if it's a modern card with gpu boost, apply and play games/run benchmark to check thermals are still okay, try to stay <80c if you can. If that's all fine, start applying an offset to the gpu and memory, do them one at a time - find the max for gpu, drop it back to 0 and move to the memory (I'd go up in 100mhz increments at first, when it crashes start going up in smaller increments), then once you found the edge of stability for both, set them a little below maximum to avoid crashes. If you go too far you might notice glitches/artifacts, or the graphics driver will just crash, you'll get a black screen for a while and when it comes back it will have reset the clocks on the card.
If you have the option to adjust the voltage, do it in small increments while testing and watching the temps. It's worth setting up the on-screen display to watch temperatures. I have vram used, load %, cpu % etc (settings - monitoring tab, select the readings you want to see and tick the box below that says 'show in on-screen display'.)
Good luck, let us know how you get on and give us a shout if you get stuck :)
Castino
12 (0.00/day)
If you have the option to adjust the voltage, do it in small increments while testing and watching the temps. It's worth setting up the on-screen display to watch temperatures and I have vram used, load %, cpu % etc (settings - monitoring tab, select the readings you want to see and tick the box below that says 'show in on-screen display'.)
I have the gtx 1060 3gb, but thanks.
4,994 (0.70/day)
South of England
*facepalm* it was in the title all along haha, my bad :laugh::kookoo:
477 (0.13/day)
System Name Rtxoned
Processor Intel i5 8600k
Motherboard Msi Z370 Sli Plus
Cooling Cooler Master Ml240r
Memory Corsair vengeance 8x2 DDR4 2400mhx
Video Card(s) Zotac Rtx 2080 Amp
Storage 250gb SSD, 500Gb SATA, 250Gb SATA
Display(s) Alienware 25” 240hz
Case Nzxt H700i
Power Supply Thermaltake toughpower 1000w 80+ Gold
Mouse Logitech 403
Keyboard Hyperx alloy fps mechanical keyboard Cherymx Blue
117 (0.03/day)
System Name Snizzle
Processor AMD Ryzen 9 3900X
Motherboard ROG STRIX X470-F GAMING
Cooling CORSAIR Hydro Series™ H100i PRO RGB
Memory CORSAIR VENGEANCE® RGB PRO 16GB (2 x 8GB) DDR4 DRAM 3200MHz C14 Memory Kit
Video Card(s) EVGA GeForce RTX 2080 Ti XC ULTRA GAMING, 11G-P4-2383-KR
Storage SAMSUNG 970 EVO M.2 2280 500GB
Display(s) ASUS ROG Swift PG279Q
Case NZXT H500
Power Supply EVGA SuperNOVA 850 G2 220-G2-0850-XR 850W
Mouse SteelSeries Sensei
Keyboard Ducky DK2108S
9,414 (3.29/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Use MSI Afterburner , right besides the core clock slider there will be a little chart icon , click it and from there you can set a frequency/voltage curve. That's how will get the most out of your overclock , basically you just need to set a frequency for which voltage steps you want. In my case I just have the frequency set to 2164 from the 1.093 V all the way down to 1.050V. Of course because of the way GPU Boost works you will not get those clocks at all times.
Castino
12 (0.00/day)
Can you please send me a screenshot of the voltage frequency so I can understand more?
8,253 (1.20/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
one thing i will say.. it aint really worth pushing everything to its absolute limit.. to make things easy see if you can find a review of the same card as yours and see what they get..
trog
4,288 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
If you want to do this the easy way, just grab MSI afterburner and set the voltage limit and temp limit up to max. That by itself will let the card clock higher and will net you more performance. From there you can adjust your fan speeds as needed (Favoring temps or noise). If you want to go further then you start messing with the frequency slider on your own and test things (Normally I would say in 50mhz increments) to see how far before the overclock fails and bump it back to the last stable state.
Thats about the easiest way to overclock in this day and age. Beyond that there are alot of things you can do to go further but I would not worry about it in your shoes.
477 (0.13/day)
System Name Rtxoned
Case Nzxt H700i
Mouse Logitech 403
Is voltage change necessary for small overclock? I mean 100 or 200 mhzcore clock, im soory if im wrong im familiar with oc.
9,414 (3.29/day)
Case Phanteks NV7
That straight line is at 2164 mhz , but that's just in my case.
If by voltage you mean that slider , it actually doesn't do much. You can't go over 1.093V (it wont even stay at 1.093) on any 1000 series card so your pretty safe maxing that slider out.
2,707 (0.76/day)
On The Highway To Hell \m/
Don't forget the power limit. You want to max that too. As shown in the post above.
4,288 (1.11/day)
Texas
Mouse Logitech G5
I meant to say Power Limit not Voltage limit :p
