How to add fans for Thermaltake Armor?
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Do I have to buy these hard drive cages in order to add fans? I really don't want to pay for these creppy fans that come with the HDD cage.
2,597 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
WarEagleAU
Bird of Prey
10,812 (1.59/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
kind of sucks if that is the only way to add fans. I was thinking that the armor case had holes to mount 120mm fans in the front panel.
sneekypeet
not-so supermod
29,685 (4.31/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Zip ties, Velcro, double sided tape? Think outside the box a bit an I bet even with some bread bag twist ties you could get a fan pretty secure in there!
This is done with a 120mm fan and zip ties! http://www.techpowerup.com/gallery/1553/11.jpg
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
No, The iCage is the way to do it all though you can put them any were in the case.
These are what i have in mine due to the amount of HDD's in it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999141&Tpk=icage
http://www.newegg.com/Product/Product.aspx?Item=N82E16856999209
IF you only have 1 or 2 HDD you could do what sneekypeet is talking about.
A problem is with he icage is that it has way to much metal to it. I dremeled mine to give much better airflow.
4,016 (0.66/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
I second sneekypeet, I have an extra fan in the front suspended with elastic. If it's to cool more hdd's though, then yeah, might as well get an iCage and dremel for airflow. Or suspend the drives on elastic for even better airflow, and less noise.
5,717 (0.93/day)
I just wanna increase airflow
sneekypeet
not-so supermod
29,685 (4.31/day)
System Name EVA-01
Get creative and look at the side where the Icages mount. Are there holes? run skinny wires, zipties....whatever is around the house and just suspend a fan in there.
4,016 (0.66/day)
Ohio
Yeah, there's plenty of places you could fit a wire or ziptie or something through to suspend a fan.
