How to apply firmware with ISO?
Data Salvage
2 (0.01/day)
hello could you update the firmware? may i ask where did you get the ISO file? i cannot find it
854 (1.22/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Extreme
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
hello could you update the firmware? may i ask where did you get the ISO file? i cannot fin dit
You have to download this program as listed above. This will update your SSD, IF there is any update available. If storage executive says nothing, then you have the latest firmware already installed.
Data Salvage
2 (0.01/day)
hello and thank you for the answer.... storage executive doesnt show any drive under ubuntu
854 (1.22/day)
Belgium
Memory 32GB DDR5
Is it connected to M.2 PCIE slot in your PC? What Micron type SSD you use and what version firmware has it now?
Updating Firmware only works if the SSD is connected directly with your PC, an USB external adapter usually does not work and is not safe.
This occurs either from an outdated or incompatible Chipset/SATA (Serial Advanced Technology Attachment) driver, or wrong installation.
So you have to either use an SATA cable or an M.2 slot in your PC to update any given SSD.
3,389 (1.09/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Micron releases firmware in .bin files here: https://www.micron.com/products/ssd/firmware-downloads
Of course I recommend simply using the software to update your drives. If the drive isn't showing in the software it could be any number of issues. First check to see if your operating system can see the drive and if you have the proper drivers installed. I'd also check the drive itself to ensure all cables are properly connected.
854 (1.22/day)
Belgium
Memory 32GB DDR5
Not all SSD are listed there, for the newest firmware's you have to use Storage executive now.
And as said External USB cases does not work at all. It's the same with Samsung, they list many ISO's but not for all of the SSD available, why i have no idea.
Administrator or root user privileges are required to update an SSD in Linux. This also can be the reason it does not find any SSD in your system.
An ISO file is meant to be burned to an USB stick, and boot your PC from it to update Firmware in Linux session.
