how to clean thermal paste underneath the cpu
210 (0.06/day)
System Name my creation
Processor Intel core is 4670k
Motherboard gigabyte z97x gaming 5
Cooling cooler master hyper 212 evo
Memory Kingston hyper x fury 2x 8 gb
Video Card(s) Msi r9 390
Storage Seagate 1tb samsung ssd
Display(s) asus 27 inch
Case corsair 450d
Power Supply evga g2 750watts
Keyboard azio gaming led
Hi. I have a Intel code i5 4690k. I noticed it has some thermal paste on the bottom side. I do not know how to clean it. I need some advice of wether To take it to a shop or if it's simple do my self. I don't know if u see it but there's a blob near the bottom left edge and a dot size drop in the middle. How can I wash it?
210 (0.06/day)
Case corsair 450d
How too post pics. I'm clicking on upload file sand choose file but nothing happens
5,226 (0.85/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Don't see a pic. If its on the bottom of the proc itself then get some alcohol(isopropyl) on a paper towel and wipe it off gently. If it's down in the pins on the motherboard then about the only thing I could recommend is get a soft bristle toothbrush, dab it in some isopropyl alcohol, and gentle brush it out of the pins.
  • Like
Reactions: xvi
210 (0.06/day)
Case corsair 450d
No its only on the cpu. I m switching motherboards
sneekypeet
Retired Super Moderator
29,445 (4.38/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Kenkickr hit the nail on the head. Some alcohol and something to rub it off with will do. You dont have to be very gentle on the bottom of the CPU around the outside where the pads are.
210 (0.06/day)
Case corsair 450d
Can I do it or do I need to go out.
Is the process easy or hard
4,666 (0.72/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
Very easy. You'll most certainly want to touch something metal that's plugged in to the wall (the metal case of a running computer would be perfect) to discharge any static you might have built up. Other than that, just carefully remove the CPU, clean up the pads on the bottom as kenkickr described, let it dry, carefully mount the CPU back in place.
Edit: Use your judgement though. If all that makes you uncomfortable, you could certainly consider having someone else do it.
210 (0.06/day)
Case corsair 450d
Should I let it air dry ND for how long?
203 (0.06/day)
isnt this about the same situation from your last thread? why didnt you continue in there? why create another thread?
still stuck on the same thought even after all the wiser recommendations from forum members? go ahead then, buy a new board and be done with it
(in b4 you end up with 2 broken boards and a broken cpu)
why do people do this, ask for advice only to do what they had in mind in the 1st place...
210 (0.06/day)
Case corsair 450d
Thanks. Awesome answer
203 (0.06/day)
so you actually read my reply? im impressed. what about what the other members recommended, about this very same topic, on the other thread? did you read any of that? and you still felt the need to create another thread? do you want a "previously on an aasim1111 thread":
-my computer doesnt boot
-ends up being silver (conductive) thermal paste all over the socket
-members recommend to either take the computer to a proper shop or take a gander at cleaning it himself
-ignores advice and asks local friend for help
-friend backs up what members previuously said
-ignore everything and everyone and says hes gonna buy a new motherboard
what am i missing about this "awesome thread" that wasnt said in the other one? knowledgeable people already told you how to clean the socket (very carefully) in details, might i recommend you to _actually read_ the replies on the other thread again instead of ignoring it and brute forcing your way through?
stay tunned for an all new "too expensive, im gonna do it again" episode...
12,307 (2.31/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Lighten up. He asks a lot of questions and makes a lot of threads. We have already talked about this.
aasim1111, youtube is your friend
203 (0.06/day)
although ive picked on his "multithread", the thing that really grinds my gears is asking for help, ignoring it, do the oposite and then ask for help again only to ignore it again. im sure everyone knows someone that acts this way, and i hate to see that he was taking that path too.
there is no shame or problem in asking for help/advice, or even to ignore that advice and take another course of action, just dont come asking for help again on the same subject only to ignore it again
besides, there is plenty of instructions on that thread on how to clean the socket without damaging it, the punch line being be gently with it: remove backplate, remove front enclosure, rinse multiple times the socket area with a fast-drying non-corrosive very-low-conductive liquid like 95+% alchool, making sure to tilt the board during the rinse to avoid liquid (caring traces of thermal paste) to sweep under other connectors/smds (like the ram, io ports), allow some hours for it to dry at room temperature in a ventilated area, dont touch the socket pins during all this and it should be fine (hopefully). or visit a professional and let them figure things out
12,307 (2.31/day)
Oregon
Ya it can be frustrating. But it reminds me of a quote a mentor said to me one time. "The more you charge someone the more they respect your opinion" Dude was a genus too a Wozniak if you will
1,491 (0.21/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
i feel sorry for OP... was better to pay 10-20 € to a PC service guy to assemble all...anyway much cheaper than a new MB...
i would go with that MB to a car wash and clean all paste from socket and nearby using a pressure washer... and than dry it....
12,307 (2.31/day)
Oregon
Just wipe it off
210 (0.06/day)
Case corsair 450d
It is not in the socket. Only the back of the CPU
But ya I get it . U don't want to help further cuz I don't listen. This thread is going off topic so if I can ask a mod to delete it
1,846 (0.33/day)
UK Warwickshire
System Name PC-Chips
Processor AMD Ryzen 7 5700x3D
Motherboard Asus ROG Strix B550-F Gaming.
Cooling Thermalright Peerless Assassin 120 SE CPU Air Cooler 6 heat pipes.
Memory Patriot Viper 32gig dual channel 3600mhz
Video Card(s) PowerColor HellHound RX 7900 GRE OC
Storage 2 Samsung 860 EVO's 500gig / 2TB crucial P3-NVME / WD-BLUE SN550 1TB M.2 / SP A55 512gig / 8TB HDD
Display(s) Panasonic 40-inch 4k TV
Case Modded NZXT H510
Audio Device(s) Realtek S1220A - Yamaha A-S501 AMP - Wharfedale diamond 9.1 speakers - Wharfedale SW150 sub
Power Supply EVGA SuperNOVA G6 750W 80+ Gold
Mouse Some cheap wireless thing
Keyboard Razer Cynosa lite
VR HMD Oculus Quest 2 128gig version
Software Windows 11 pro 64bit
FFS if there is a bit of paste on the back of the cpu get a cottom bud and clean it off carefully it is that bloody simple its not rocket science.
As long as you get the gold pads clean there should be no other issues, all you really need to be carefull of is them little transister things or what ever they are. Oh and don't over rub the gold pad bits.
dorsetknob
9,106 (1.28/day)
those that want to help will post offers of help
BUT you seem to ignore their suggestions and same or similar problem is posted by you in a new thread
that does exasperate members that have tried to help you
You seem reluctant to accept the advice given and to act upon said advice
Nuff Said hope you sort it out this Time
210 (0.06/day)
Case corsair 450d
I have decided to go to a shop for cleaning
2,332 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
1,846 (0.33/day)
UK Warwickshire
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
Just use a piece of toilet paper with some Contact Cleaner if needed , could use Q20 Or WD40 but will leave a residue on the chip , then might accumulate dust sticking to it over time , other than that should not cause any harm.
Contact cleaner Or electronic cleaner available at hardware stores .
contact cleaner's dry nearly instantly with not much residue.
peche
Thermaltake fanboy
6,709 (1.87/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
sh*ts you might need....
Toilet paper, coffee filters, or whatever you could use for cleaning, must be lint free, coffee filters is the cheapest thing in this world for this ...
Plenty isopropyl alcohol, also is pretty easy and cheap to get,
Patience
how to:
1-Power off your computer, unplug power from psu,
2-Remove CPU cooler,
3-Remove processor from socket tray,
4-Take the processor pretty carefully to a table, take a seat
5-Wash the processor with isopropyl alcohol, no maters how much you will use, processor is not gonna drown, take the cofffee fileters and use to clean the processor, take out every single TIM leftover, no matter how much you take, be patient, isopropyl alcohol will dissipate pretty fast so you wont damage the processor, just take care about al the contacts it has downside, be careful
6-When done... leave the processor getting dry alone, put it over a couple of coffee filters or a plastic case / older [if you have the supplied plastic container that comes with the processor will be great!]
when new, retail or OEM processor cames in the followgin pastic tray
just the plastic tray:
This a OEM processor with plastic tray:
This is a full package or reail processor incluiding the plastic tray:
7-the when the processor is 100% dried, put it back in to the desired motherboard socket tray [you said you are switching motherboards]
8-properly tighten CPU cooler following manufacturer's directions,
9-plug your PSU
10-turn of your PC
11-watch porn ....
is a pretty simple process, if you are able to repaste your processor, you should be able to clean the processor,
Take a watch ... is not complicated, even girls are able to doit!
