How to connect this to 4 pin molex
696 (0.17/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi Guys,
Please guide me on this, I recently bought one croner led rod, but is has different connector just like female laptop power connector, see pics,
and suggest me how to connect it to 4 pin molex?
however it has one text asking to ciut in order to connect to molex.
3,842 (0.91/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
yellow is 12v positive and black next to it is negative on the molex
looks as tho your lead, the one with the white stripe is 12v positive.
white stripe to yellow pin. black to black
someone else may confirm this.
12,062 (2.67/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
http://www.tomshw.it/forum/attachme...8-dubbio-sul-neon-dentro-al-pc-molex_9192.jpg
I've done a similar thing with server fans (their wires are all silly blue and green colours).
Easy way to test, touch one half of the wire to a + 9V battery and the other half of the wire to the - on the battery. Whichever way causes it to light up is the way you wire it. I soldered mine to a correct male end I cut off another component, so try to find a Molex Male end and solder it to the component, then there's no mucking around in future.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.53/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Yellow + Black next to Yellow = +12v circuit
The connector you posted a pic of is likely to be +12v on the center rod and ground around the outside. It kind of looks like a standard RCA plug. You might be able to salvage one from AV cable/equipment, solder it to a molex cable, and make yourself a quick connector.
696 (0.17/day)
India
Processor i7 3770k
Done. solved!
