How to crimp Cat 6 cable?
OrbitzXT
1,969 (0.31/day)
New York City
System Name AX-01
Processor Intel Core i5-2500K @3.7 GHz
Motherboard ASRock Z68 Extreme3 Gen3
Cooling Zalman 9700
Memory Kingston HyperX T1 Series 8GB DDR3 1600 MHZ
Video Card(s) GTX 590
Storage Intel X25-M
Display(s) 42" Samsung LED HDTV
Case Antec Twelve Hundred
Audio Device(s) HT | OMEGA STRIKER 7.1
Power Supply Kingwin 1000W
Software Windows 7 64-Bit
I've done this a handful of times before but it was partially guess work as well. I was using something like this as a guide:
My only small issue is once you have the wires in the correct order...which way do I hold the termination piece to put them in? I'm not sure if I'm putting them in correctly or reversing the order. Does it matter as long as I do it consistently on both ends?
1,364 (0.25/day)
TX
System Name Beast
Processor Core i7 10700K 4.5GHZ 24/7
Motherboard MSI MPG Z490 Gaming Plus
Cooling Master Liquid 240
Memory 32 gigs DDR4 3600Mhz Gskill RipJaws
Video Card(s) AMD Raedon 5700XT
Storage 1TB Samsung NVME, Western Digital 4TB storage
Display(s) Dell UltraSharp 34" HD
Case Cooler Master HAF XB EVO
Power Supply EVGA 1000 Watt full modular
Software Win10 ENT 64Bit
The clip needs to be down. It really doesn't matter as long as it is consistent on both ends and all of them are done the same.
There are 2 ways to put them in order, A is orange white, orange, green white, blue, blue white, green, brown white, brown, B is green white, green, orange white, blue white, blue, orange, brown white, brown.
brandonwh64
19,542 (3.52/day)
You need to climp via the B method. White-Orange, Orange, White-Green, Blue, White-Blue, Green, White-Brown, Brown.
Use a set of ratchet crimpers for better results :)
Monoprice.com will help with tools, connector ends, and cable for CHEAP prices :)
My quick guide is to straighten the wires as best a possible then use a side to side motion to get them aligned then put them in the order above then take a pair of succors and cut them all at one time to a equal length then holding firmly slide the connector clip down onto the wires then into the crimper. make sure you hold firmly during the whole process.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.47/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Click for all their diagrams. I printed it off (there's a PDF link at the bottom of the page) and keep it with all my networking equipment.
Edit: You hold it literally as it is shown in the diagrams: the metal bits facing you (clip is away from you) and the wire goes in from the bottom. You can always look at a professionally-created (read: bought and working) cable to check the order and compare.
brandonwh64
19,542 (3.52/day)
If you need further help I can make a video using my droid :)
aharvey
113 (0.02/day)
Maryland, USA
System Name Aaron1200
Processor Intel QX6850
Motherboard Asus P5Q Pro w/ Ket's mBIOS 1406
Cooling Xigmatek S1283
Memory 4GB G.Skill Pi RAM @ 1066
Video Card(s) Palit 4870 Sonic Dual BIOS
Storage OS: Crucial c300 64GB, DATA: Seagate ES.2 250GB
Display(s) 24 inch Dell Ultrasharp LCD
Case Antec 1200, Red Antec Intake Fans, Ultra Kaze Exhaust
Audio Device(s) On Board w/ Logitech Z2300's
Power Supply Corsair 1000HX PSU
Software Windows 7 Home Premium 64-bit
Get a pair of electricians snips too. This will make it easier to cut your wires at a straight angle, which makes them fitting into the rj-45 a lot smoother. Also, with some practice, you can use the snips to strip the outer jacket without nicking the inner wires as well.
Electricians snips are your friend.
Zhriver
16 (0.00/day)
Out of curiosity, why are you doing this? patch cables are dirt cheap this day and age.
Also if you happen to do this every know and then, the correct tool for it is also rather cheap. It cuts them in the correct length without touching the copper.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.47/day)
IA, USA
System Name BY-2021
If you're using shielded cables/connectors, let me know. Virtually no guides cover the shielded (good) stuff.
Wrigleyvillain
PTFO or GTFO
7,702 (1.23/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Heh, used to have that memorized. Haven't had to make a cable in many years tho.
brandonwh64
19,542 (3.52/day)
Well normally you terminate them in a female socket and then switch to a small patch cable between that and the computer.
But the cable used from the female socket to the patch panel in his work place in CAT5E and he's changing that to CAT6A
brandonwh64
19,542 (3.52/day)
Oh god do I have to use this EVERY SINGLE DAY lol
There is always a need for some type of termination around here wither it be copper or fiber
Zhriver
16 (0.00/day)
Tbh, as a professional you would never crimp that yourself once you transition to cat6.
If the 1Gbit connection offered by the 5e isn't enough and you really need the 10Gbit+ from cat6 then you would be better off just buying a proper one.
brandonwh64
19,542 (3.52/day)
Most of our cable has been ran by a licenced cabling company, we have 10 miles of copper and 7 miles of fiber in our facility but for small jobs such as his and also since he wants to same money then crimping and punching down the cable is a better choice as long as he has the time.
Using female ends such as SYSTIMAX GigaSPEED X10D91B he will be able to change everything from the workstations to the patch panel in his network cabinet.
OrbitzXT
1,969 (0.31/day)
New York City
System Name AX-01
Cooling Zalman 9700
Storage Intel X25-M
We have Cat 5 ran everywhere here, and it's an electrical contracting business I work for so we have the Cat 6 cable laying around already. I've terminated cables before, but like I said I wasn't 100% sure if I had the termination piece oriented correctly. The cables worked, but I think that's just because I was consistent with how I did it.
4,267 (0.68/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Not really a big deal for a small job like this, but if any one was interested, these QuickTreX plugs with loadbars improved my speed, saving a decent amount of time when doing large jobs.
(they also have shielded)
OrbitzXT
1,969 (0.31/day)
New York City
System Name AX-01
Cooling Zalman 9700
Storage Intel X25-M
The termination pieces I ordered came, I have a small issue. The ones I used to use came with this other piece that let you put the wires in the proper order, then you can cut them to be the same length and then slide that whole piece into the termination piece. I'm not sure what it's called, but these didn't come with it. Does anyone know what I'm talking about? I'd like to order them for when I do this.
Edit: The poster before me has exactly what I'm looking for. Gonna order those =)
3,059 (0.44/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
IDK about those load bars do they go over the outer jacket and grip it or are they some EMF gimick ?
if there griping the internal wires and putting the the weight on them i think they would do more harm then good.
As for tools just get one of these RJ-11/RJ-45 Crimp/Cut/Strip Tool its all your ever need to do cat wires besides maybe a pair of needle nose to flaten the wires.
after 30 or so your finger tips will get sore
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.47/day)
IA, USA
System Name BY-2021
CAT6 are really hard to stick in there and have them all fall in the same place. A friend of mine can do do it right almost the first time, every time. Me, I spend hours just to do one. A shame those "loadbars" won't work with my CAT6 shielded connectors. :(
59 (0.01/day)
Processor Intel Core i5 3570K @ 4,1 Ghz
Motherboard Asus P8Z77-M Pro
Cooling Gelid Tranquillo rev.2
Memory 2x4GB Corsair 1600Mhz DDR3
Video Card(s) Sapphire Radeon RX580 8 GB
Storage Samsung 850 EVO 500GB SSD, Western Digital WD7501AALS; Seagate Barracuda Green 2000DL003
Display(s) Philips 272B7Q
Case Fractal Design Arc Mini
Audio Device(s) Asus Xonar DX
Power Supply Seasonic S12II-520 Bronze
Mouse Logitech MX Master
Keyboard Logitech MK540
Software Windows 10 64-bit
sorry for reviving an old thread, but i have a problem with Cat6 cables:
i never made any cables before, but now i purchased 50 m of cat6 cable, some connectors with load bars and this crimping tool http://www.b2b-hydraulic-tools.com/rimages/622/HT-500R-compressed-tool-b.jpg
however i cannot do a successful crimp. i arrange the cables in loadbar, put it into the connector, but the cable doesn't work and i can easily pull out the whole darn thing from the connector after crimping (what shouldn't happen).
i have read and watched tens of tutorials, i am leaving some outer skin of the cable in the connector (to hold in the cable), wasted like 10 rj45 connectors, but no success.
i have no idea what am i doing wrong. any ideas and help would be extremely appreciated.
thanks
1,230 (0.21/day)
Metro Atlanta
Processor AMD Ryzen 1700
Motherboard Gigabyte AB350 GAMING 3
Memory 16GB (2x8) 3200MHz
Display(s) Acer 24" LCD
Without seeing your work its hard to tell you what your doing wrong. However, here are some tips:
1) When inserting the wires into the connector make sure the clip is facing down. This is to be done with the same color code on both ends. Orange-White, Orange, Green-White, Blue, Blue-White, Green, Brown-White brown.
2) Notice the pins on the connector and how they are sticking out before you crimp. After crimp they should NOT be sticking out. I just run my finger across the top to make sure.
3) Make sure the load bar is pushed all the way into the connector, use a jewelers screwdriver to make sure its all the way in.
4) Look at the tips of each connector after being crimped, with a properly made cable you will be able to see the copper at the tips of each wire.
5) Invest in a cable tester with a mapping feature. This will check each wire to make sure its terminated on both ends.
-Mojo
41,939 (6.61/day)
u can always use a multimeter instead of a mapper to determine the continuity (Symbol of Omega) of the cable and ensure the wires are in the right spots
-Mojo
2,786 (0.56/day)
thanks
1) Have you inserted the cables into the load bar, then cut the ends off so that they all terminate in the load bar at the end? A good set of wire dikes are invaluable here.
2) How far in have you forced the load bar? It is generally impossible to force it in all the way by hand, so a small screw driver or set of pliers make life easier.
3) Is the crimper pushing the friction fitting all the way down? Cheaper crimpers often skimp on force at the friction fitting, because with cat 5 the friction at the wire was more than enough to hold the connectors together for a few plug/unplug cycles. A good crimper is worth splurging on.
4) Are you sure the wire is cat 6? Trying to use a cat 6 connector with cat 5 wire, there won't be enough friction to keep the wire together. This may not be a concern, but you'd be surprised how often untrustworthy online retailers "rebrand" lower quality wires in order to sell them for more money....
Finally, pictures are needed. These are all guesses until you show us what we are working with.
41,939 (6.61/day)
